Alyssa Jean
Joined: 02 Nov 2003 Posts: 2375 City/Region: Guemes Is.(Anacortes)
Vessel Name: Alyssa Jean
Posted: Fri Feb 02, 2007 8:47 pm Post subject: |
Do you think the CD got more than the molds? Maybe the names too??
Thanks Tom for the line drawings. I may take you up on a tour of the Bow/Edison facility. _________________ David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51 |
Joined: 02 Nov 2003 Posts: 20812 City/Region: Pensacola
Posted: Fri Feb 02, 2007 9:07 pm Post subject: |
As I often do, I will play the devil's advocate. I understand this is a concept boat currently--but once the build begins, it gets mighty expensive very quickly. My first thought is that prop has no protection. This is a real negitive in a trailerable boat--and probably would be a deal killer in the SE waters. Is there a keel? Where is the rudder? Not in the rendering--inboard or stern mounted? Tunnel hulls have been associated with some handling problems.
No swim step--understand if this is a sportfisher--but you need to offer a swim step as an option or standard item. Some like transom doors, others do not. The flimsy starboard transom. door which is found on many production boats is a real detriment. These are easily broken, the hinges deform, latches often missalign. If you are adding a transom door, consider a full thickness, heavy duty hinge unit, like a real sportfisher. The other issue is seas aboard thru the cockpit door, with a engine access thru the floor. One of the major issues with many express cruisers and sport fishers is the potential water intrusion into the engine space/bilge from a boarding sea aft.
Is this a self bailing cockpit? Where is the engine box?--this will take up a lot of the cockpit--unless the cockpit is very high. Where is the tankage--what is the tankage. An engine to push this size boat at 18 knots is going to use a fair amount of fuel. (consider 10 gallons an hour)
The 10 degree deadrise V--this is no longer a semi dory--and the question becomes how about the speeds between displacement and full plane?--this is where the semi dory excells. A 10 degree dead rise will not do will in heavy chop or seas. You will have to slow to displacement or semi displacement speeds.
Sleeps 6!-lets get real--where are you putting the third double bunk? I agree with the comment about weight distribution. This is an issue that was missed on the Tom Cat 255, with more weight on the stb side on standard boat.
I would also like to see what the prospective price will be--as well as the HP of the engine--and what engine is proposed. I suspect that you will need at least 200 hp to get the speeds which are "advertised". Then the issue becomes what is the fuel capacity?
I do like putting the spring line cleat near the foreward cabin window--but in a boat this size, a second spring line is really not necessary.
It will be most interesting to see how this project comes along. Again, thanks for the updates _________________ Bob Austin
seahooked
Photos: SeaHooked
Posted: Sat Feb 03, 2007 10:23 am Post subject: Re: C-Dory 29 Venture |
Tom Latham wrote: | A 3-D rendering display is now in place at the Seattle Boat Show and includes base boat show pricing featuring diesel IB power. |
Does anyone know what the 'base boat show price' is? _________________ Chris Brown
Redmond, WA
2006 CD-25 Cruiser "SeaHooked" 2006-2012 |
Alyssa Jean
Posted: Sat Feb 03, 2007 11:03 am Post subject: |
As I remember, Scott said the target price was $169K. Someone else at some point told me between $170-$180K. |
Chester
Photos: Chester
Posted: Wed Apr 11, 2007 11:35 pm Post subject: |
Any updates? |
mrw90
Joined: 17 Jan 2006 Posts: 40 City/Region: Bellingham
Posted: Sun Jul 22, 2007 10:43 am Post subject: |
Saw this boat being pulled by a C-dory factory truck through Bellingham. Must have been heading down to the harbor for the Bellingham gathering. I just got a quick view of the exterior. It was the inboard version, and had a small bow thruster installed. It's definitely big relative to the other C-dories. I couldn't tell if the interior was finished out yet or not. Hopefully the folks at the gathering can give us a more complete update as they start to return home. |
Alyssa Jean
Posted: Sun Jul 22, 2007 6:32 pm Post subject: |
I was on board as were many others at the Bellingham GTG. That it is bigger than the usual C-Dory is an understatement. This puppy is huge in comparison. About 10 ft beam and when Bill stood next to it the top of his head was only about half way up the hull. 220 HP Yanmar in it. Heat pump for A/C and heat, taking the heat out of the water instead of the air. Large gen-set. The interior was not finished, but they wanted to get it to Bellingham. I think the first one should be named C-Monster. Very nice boat, definitely not trailerable.(without a special permit). |
Posted: Sun Jul 22, 2007 6:38 pm Post subject: |
Where is the engine located? Generator? How much fuel tankage? Thanks for updates. |
tom&shan
Photos: Dakota
Posted: Sun Jul 22, 2007 7:07 pm Post subject: Towing |
Here's a photo of the truck that the factory recomends towing the boat with.
SENSEI
Joined: 01 Nov 2003 Posts: 1067 City/Region: Stanwood
Vessel Name: SENSEI
Photos: SENSEI and SERENITY
Posted: Mon Jul 23, 2007 2:58 am Post subject: |
this is a pic from wild blues album taken at the Bellingham debut
Oldgrowth Dave is standing there to give some relativity of the size _________________ Roger on the "SENSEI"
1993 22 Cruiser (sold 2014)
1983 22 Classic (sold 2017) |
dotnmarty
Joined: 03 Nov 2003 Posts: 4196 City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
Posted: Mon Jul 23, 2007 10:29 am Post subject: |
I hope Oldgrowth Dave isn't thinkin what I think he's thinkin. Leave C-Voyager just the way it is. It's perfect. _________________ MartyP
"...we're all in the same boat..." |
Posted: Tue Jul 24, 2007 12:22 am Post subject: |
SENSEI wrote: |
Oldgrowth Dave is standing there to give some relativity of the size |
Sure looks a lot like a 30 ft long cabin Osprey, at least superficially!
Joined: 07 Nov 2003 Posts: 7882 City/Region: marysville
Posted: Tue Jul 24, 2007 12:50 am Post subject: |
looking at the osprey site I would say that they look a lot alike including the forward head. What are the projected speed numbers for the 29 c-monster??? the osprey with twin's is listed at 40 plus. I have driven one of the 26 fisherman models and they are smooth under way. very nice boat.[/img] _________________ Thomas J Elliott
