Downrigger Mounting
hammerhead
City/Region: Sacramento
Vessel Name: Hammerhead
Photos: Hammerhead
PostPosted: Sun Dec 31, 2006 12:01 pm    Post subject: Downrigger Mounting Reply with quote
I have ordered the Scotty 1106 downriggers and would like to see some pics or get any advice on mounting on my cd-22. I am mounting the removable side mount dive ladder today and would like to check with the sea brats before i mount the riggers, rod holders, and the weight holder cups as I know some of you have found the wheres and whys of mounting and wiring.
Any advise or pictures will be greatly appreciated.
Doug aka Hammerhead CoolSmile
The New Hammerhead is looking good, ready for fishing and diving, pictures coming soon Smile
CAVU
City/Region: Spokane
Vessel Name: CAVU
Photos: CAVU
PostPosted: Sun Dec 31, 2006 6:50 pm    Post subject: Reply with quote
Doug,
I mounted mine (same Scotties as yours) on the gunnel as far aft as possible and still be able to open the lazerettes. It was a little tedious to do, but when I wired the outlet I put it up under the gunnel with the outlet pointing down to protect it from spray. Other things to consider are if you have canvas-will it still fit after downriggers are mounted? If you type "mounting downriggers" in the search feature you will find many other discussions about the subject and links to photo albums with good pix.
Ken Trease
22 CD Cruiser, CAVU
Twin 40HP Hondas
Da Nag
Vessel Name: Wilbur
Photos: Da Boats
PostPosted: Sun Dec 31, 2006 7:20 pm    Post subject: Reply with quote
Pic of mine above - I've got the rod holders on the Scotty base, but you can see where the base is mounted.
The gunnels are just barely wide enough to mount the bases - triple check before drilling. I used the bases as a template, but drilled each hole slighly towards the center of the base.
Even so, I had to grind flat the edges of the fender washers underneath, as the bolts were so close to the inside hull edge.
Tux Will, C-Brat Nerd Tux
Ted Osborne
City/Region: Des Moines, WA
C-Dory Model: 24 Tomcat
Vessel Name: Tabbycat
PostPosted: Sun Dec 31, 2006 7:56 pm    Post subject: Reply with quote
Ken. Rather than install the ball holders you might consider the Scotty Downriggr Weight Hook #1147 for 1" booms or 1148 for 1 1/4" booms. I think they are more handy. The holders you could just place in the side pockets loose for travelling if you want. I just leave mine on the boom.
Ted & Donna
hammerhead
Photos: Hammerhead
PostPosted: Sun Dec 31, 2006 9:12 pm    Post subject: Thank you Reply with quote
Thanx guys very helpful Thumbs Up
Pandy Girl
City/Region: Westfield, NC
Vessel Name: Pandy Girl
Photos: Pandy Girl
PostPosted: Sun Dec 31, 2006 10:30 pm    Post subject: Mounting Downriggers Reply with quote
Hi Hammerhead
I mounted ours where Dag Nag mounted his, I have not got a good Pic. of this but it works good for me
Pandy Girl
Chris Bulovsky
City/Region: Washburn
C-Dory Year: 1998
Vessel Name: SCOUT
Photos: SCOUT
PostPosted: Sun Dec 31, 2006 11:57 pm    Post subject: Reply with quote
I think the general consensus is to mount the downriggers just forward of the fuel holes. This position gives ample elbow room for cranking the balls up. As for ball holders ( this is sounding dirty) Embarassed I mount them in the shelf just below the the downrigger.
Sometimes I remove the downriggers when I go duck hunting or on a Party Cruise. Having the balls out of the way and out of sight makes for a cleaner cockpit. ( this is going downhill fast Crying or Very sad )
This is what works for me despite the sound of it.
Chris Bulovsky
Washburn Wi
PostPosted: Mon Jan 01, 2007 1:24 am    Post subject: Reply with quote
Chris, good luck with that. I always want to have my balls out of the way when I go on a Party Cruise.....; Shocked Or maybe not...;. Disgust
Thanks for the first smile of 2007.... Laughing
charlie
hammerhead
Photos: Hammerhead
PostPosted: Mon Jan 01, 2007 9:07 am    Post subject: Happy New Year Reply with quote
Yes I think I like Da Nags set up as well Pandy Girl, Very nice boat you have there as well. Charlie I am going to try tucking my balls below too. Now that you pointed out the visual, I think we all agree its best to keep them tucked away. CoolSmile
Doug
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Mon Jan 01, 2007 12:51 pm    Post subject: Scotties Reply with quote
Doug, I put flush mount rod holders in the gunnels on Constant Craving, then bought the Scotty mounts that go into the rod holders. That way, the mount pads are not on the gunnels when you don't want to use down riggers, plus you have another set of rod holders if you want. I also did the samething for my barbeque mount.
Steve
PostPosted: Mon Jan 01, 2007 12:57 pm    Post subject: Reply with quote
For a different idea, and one I wish I had gone with. look at the "Searam" from bc. His boat has the rod holders mounted on custom made alum. brackets in the splash well. This gets the downriggers out of the way when not in use and sets the wire farther back making it less likey to cut the wire with the prop when making sharp turns, which you should not do. I think there are photos in my ablum under princess luisa trip.
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Mon Jan 01, 2007 1:44 pm    Post subject: Reply with quote
What do you guys think of THIS?
Doryman
M/V Lori Ann
Anacortes, WA
Da Nag
Vessel Name: Wilbur
Photos: Da Boats
PostPosted: Mon Jan 01, 2007 2:17 pm    Post subject: Re: Scotties Reply with quote
This is how mine was originally rigged...but I opted to remove the flush mounts, and place the base plates in their place.
I did like the lower/smoother profile of the flush mount setup when the downriggers were off, along with the versatility of being able to use other rod holder attachments. However, I found the downrigger stability to be troublesome...they rocked back and forth a bit too much for my comfort.
Could very well be paranoia on my part - I've never heard of anyone losing a downrigger with the rod holder mounts, and last I heard, one of our senior fishing pros (Dusty) used them without issue.
But...the downriggers are definitley more stable on the gunnel-attached base plates than they were on the rod holder mounts.
Regardless - if somebody wanted to try the flush mount rod holder setup first, there's no harm done assuming they are placed such that the base plates could cover the hole if it doesn't work out. There's a large hole under my Scotty base plates where the flush mounts were, but nobody would know about it unless they were removed.
RogerM
City/Region: Mukilteo
C-Dory Year: 1998
PostPosted: Tue Jan 02, 2007 2:14 am    Post subject: Reply with quote
Doug,
One comment to add: Make sure you note that the hole pattern for the Scotty bases is not square on the mounting bolts. There is much more (or some?) clearance inside the gunnel installed one direction. I had mine 90 degrees off at first, fortunately I noticed this before I got out the drill!
Roger M.
Page generation time: 0.0515s (PHP: 68% - SQL: 32%) - SQL queries: 31 - GZIP disabled - Debug on
