2003 c-dory 22' blister problem
Goto page 1, 2, 3  Next
patrick and linda
City/Region: somerset
State or Province: KY
C-Dory Year: 1986
Vessel Name: "Fan-A-Sea"
Photos: Misty Seas
PostPosted: Mon Oct 30, 2006 10:01 am    Post subject: 2003 c-dory 22' blister problem Reply with quote
hi all,
in the cinti oh area the 2006 boating season is just about finished.
so, on this past saturday i pulled our "misty seas" from her slip, located on the ohio river. after many hours of cleaning, misty seas looked terrific. one proud owner here. however, to my surprise, i noticed a blister like condition, on all areas below the water line, in the green gelcoat.
that wasn't good!
my immediate response, what the #%**'@ is this?
so, this morning i've emailed the company's rep and explain what had occurred. i'm sure they will respond, but until then, i know other c-brats have experience this problem, so, if you know what steps c-dory took to resolve these problems., i would greatly appreciate your impute. any ideas on how this might ultimately effect the value of my boat, would also be appreciated. i have trust and confidence in c-dory to make this right and will certainly give them the necessary time to do so.
i regard all c-brats as friends and have enjoyed visiting this site for the informative and friendly nature it represents.
hope your season went well.
happy halloween
pat
oldgrowth
City/Region: Rochester
Vessel Name: C-Voyager
Photos: C-Voyager
PostPosted: Mon Oct 30, 2006 1:57 pm    Post subject: Reply with quote
Pat – you might want to read this earlier thread about blistering. In addition, here is a good article about blistering.
Good luck.
patrick and linda
C-Dory Year: 1986
Photos: Misty Seas
PostPosted: Mon Oct 30, 2006 2:52 pm    Post subject: Reply with quote
thanks dave,
i'm still looking for information regarding the actual repairing of damage. if anyone has had their boat repaired by the company and would like to share that experience with the rest of us, i'd be deeply appreciative.
pat
drjohn71a
City/Region: Wichita
State or Province: KS
Vessel Name: Tom-a-Hawk
Photos: Tom-a-Hawk
PostPosted: Mon Oct 30, 2006 3:08 pm    Post subject: Reply with quote
Mike, Passagemaker magazine had an extensive set of articles on blistering and it's cure about 2-3 months ago.
Could you post some pictures of the hull to help us identify what is happening?
You may have to sand the hull down, seal it with epoxy and bottom coat, but if you could get 'hold of that Passagemaker issue, it show's photos of different types of blistering and step by step restoration.
patrick and linda
C-Dory Year: 1986
Photos: Misty Seas
PostPosted: Mon Oct 30, 2006 4:21 pm    Post subject: Reply with quote
hi john
thanks for the info on passagemaker. i'll try and grab an issue.
not sure how to post a picture, but what i can tell you is, this stuff looks like 1000's of 1/8th" or so, irregular bumps, totally covering the green gelcoat, from the water line down. they do not look like the traditional round blister type, never the less, highly visible.
at this point, i'm more interested in exactly what c-dory is going to do for me, rather than thinking about me, having to sand down the damage and reapply gelcoat. i guess it's a warranty item now, thought i had read the hull is warranted for five years.
my history with boats is, only keeping them for perhaps two or three years, so, i'm somewhat concerned about how this situation may effect the resell value.
i'm sure there is someone out there who has experienced this same thing and subsequently had the company take care of this problem, apparently, a number of boats have experienced this, to the point where it might be a manufacturing flaw. i'm not pointing the finger, the company has plenty of time to respond to my need. this is just the fact finding period. a well educated consumer fares better than the latter.
i've been a boater for along time and understand these things happen.
but , having said that, also know, good service is paramount to success.
all responses are greatly appreciated.
this is by far the best web, well meaning, site available.
"sometimes, it takes along time to see there's more to the river than just water".
pat
PostPosted: Mon Oct 30, 2006 8:10 pm    Post subject: Reply with quote
It will be interesting to see how C Dory handles this--there is another green hull which had extensive gel coat blistering. Tony's dory--the thread is "should have gotten a Bayliner". It is worth a read.
I personally feel that any boat which is going to be left in the water long term should have an epoxy barrier coat. The gel coats; even vinlyester, are more permiable to water than are the epoxies.
This just sounds like gel coat blisters, which is much different than the destructive osmosis, which is deeper in the laminate. In either case, the hull needs to be dryed out. After it is out of water for a month or so, take a moisture meter and see if the bottom continues to have a high moisture content. A moisture meter just after hauling is not of much use.
Let us know what the "fix" is--and how the factory stands behind the product.
oldgrowth
Photos: C-Voyager
PostPosted: Mon Oct 30, 2006 9:44 pm    Post subject: Reply with quote
The blistering seems to be more prevalent on boats that are green and in the water for extended periods. This is the third green boat with this problem, that I am aware of.
PostPosted: Mon Oct 30, 2006 10:11 pm    Post subject: Reply with quote
Also, as was noted before, it appears to be a fresh water problem - e.g. doesn't appear to happen in salt water moorage. Might be that now that a lot more boats are be sold in the center of the country, we're starting to learn about things that aren't an issue in salt.
Chris Bulovsky
City/Region: Washburn
C-Dory Year: 1998
Vessel Name: SCOUT
Photos: SCOUT
PostPosted: Mon Oct 30, 2006 10:42 pm    Post subject: Reply with quote
2003 green seems to have a glitch. I wonder if your boat and Tonys were made from the same gel coat. Bad Batch??????
Chris Bulovsky
Washburn Wi
drjohn71a
Photos: Tom-a-Hawk
PostPosted: Tue Oct 31, 2006 9:48 am    Post subject: Reply with quote
The Passagemaker articles about blistering lay the blame on water-soluble-molecules (WSM's) used as binders in the resin mix. Previous blame had been laid heavily upon chopped glass fibers and/or insufficient wetting, but their research pretty well nailed the main culprit. It was interesting to read that, although weak, chopped fibers shot by a gun do not contribute to blistering, but chopped fibers bound into a matte sheet do contribute to blistering due to the water soluble molecules in the binder.
As such, it would make sense that a particular batch might have a higher proportion of these water soluble molecules than another.
I do agree with Bob, that any boat left in the water needs an epoxy coating since it is well established that basic fiberglass/gelcoat combo is NOT WATERPROOF. So, you are just tempting fate to leave those materials submerged for long periods.
It would also make sense that the osmotic pressure differential may be much higher in long term fresh water exposure than in long term salt water exposure. John
patrick and linda
C-Dory Year: 1986
Photos: Misty Seas
PostPosted: Tue Oct 31, 2006 10:58 am    Post subject: Reply with quote
thanks bob, john, chris, roger, c-voyager and all other brother c-dory boaters,
i was unsuccessful in retrieving "tony's dory" post "should have purchased a bayliner", would like to give him a call or email, see what the outcome was for his boat. any knowledge of his where-abouts? tony, are you out there?
could very well be a defective batch of green gelcoat.
have no c-dory dealerships local, probably over 1000 away.
there is a well respected searay dealership, within 10 miles of my location. perhaps the company would allow them to make whatever repairs are necessary.
i will keep you guys informed of my communications with c-dory regarding this matter.
since the boat is pulled for this winter, drying out time, as well as repair time should not be a problem.
thanks again for all the impute
best regards
pat
flagold
City/Region: Abbeville
State or Province: AL
Vessel Name: C-Dawg-E
PostPosted: Tue Oct 31, 2006 12:02 pm    Post subject: Reply with quote
Are these showing up with the same appearance as if you mixed sand in paint? Small dots everywhere?
>Film: C-Dory Buyers Guide<
patrick and linda
C-Dory Year: 1986
Photos: Misty Seas
PostPosted: Tue Oct 31, 2006 12:33 pm    Post subject: Reply with quote
no, there not dots at all. they appear to be irregular bumps, from perhaps 1/8th inch to slightly larger. and just 1000's of them. restricted only to the green gelcoat, from the waterline down. they are highly visible. not the typical round blister type.
hope this helps.
thanks
pat
PostPosted: Tue Oct 31, 2006 2:08 pm    Post subject: Reply with quote
http://www.c-brats.com/viewtopic.php?t=4021&highlight=blisters
Is the link to the previous posts on the green gelcoated 2003 C Dory with blisters
Alok
City/Region: League City
State or Province: TX
Photos: Top Cat
PostPosted: Tue Oct 31, 2006 2:09 pm    Post subject: Reply with quote
Pat:
Put the word "blisters" in the search line and click.
"Should of gotten a Bayliner?" is the fourth thread in the list that comes up. Tony's problem had a good resolution. The factory asked him to monitor the blisters and offered, in writing, to fix the problem if it got any worse.
Alok
C-Dory Tomcat (Topcat) sold January 2012
Page 1 of 3
Page generation time: 0.0677s (PHP: 68% - SQL: 32%) - SQL queries: 32 - GZIP disabled - Debug on
