Could this be one of the reasons I get water on the aft deck
Stanley-J
City/Region: Highland, NY
State or Province: NY
Vessel Name: Plan- B
Photos: Stanley-J
PostPosted: Fri Oct 27, 2006 11:36 am    Post subject: Could this be one of the reasons I get water on the aft deck Reply with quote
I posted a new picture in my album (last one #27) After having problems with water on the aft deck with only a moderate weight in the stern I checked the scuppers. I may be wrong, but, I think I should re-mount the scuppers so they are straight up and down rather than parallel with the transom. When I was about to wash the hull I noticed the dirty water line and how low the boat sat with 2 people and a Honda EU-3000 gen. To me in this position when the ball is raised it goes away from the blocking hole letting water into the boat. What's your opinion?
Chuck
WA2YMF
PostPosted: Fri Oct 27, 2006 3:22 pm    Post subject: Reply with quote
How easy is it to "remount" the scuppers? You have a hole in the cockpit/with a bit of a sump--and a hole in the hull--are you going to change these? We never had any water in the cockpit of our TC 255, until some heavy weights came aboard during the recent rathering--I just let the water come and go and not worry about it. If there were a probelm, there is always "dri deck" or other grating.
Stanley-J
Photos: Stanley-J
PostPosted: Fri Oct 27, 2006 4:31 pm    Post subject: Reply with quote
Hi Bob, it would not be a problem re-mounting, just measure the angle and cut a backing plate so the scuppers sit vertical.
I usually go fishing with 2 other guys so I sooner try and resolve the problem rather than building up the deck so the water lays under a mat. In my brain storming I have even investigate the possibility of selling the twin hondas and putting one motor on board with a kicker just to save some weight, if its because my boat is overloaded with a total of 3 people on board
bcarli
Vessel Name: Soulmate
Photos: Soulmate
PostPosted: Sat Oct 28, 2006 12:42 pm    Post subject: Reply with quote
Hi All
I take a lot of people out in my cd-25 because I do whale watching trips on it. I found when 6 people are all on one side I had water coming in the cockpit drain and people were coming away with wet shoes and wondering if we were sinking. I fixed the problem by buying two kitchen plastic turkey "baster" cutting the end off and inserting the bulb into the drain. It's tapered so it fits nice and snug and I can pull them out whenever I want to. It worked good for me and it is about as KISS as possible
bill
bill & chris carli
friday harbor. wa
Stanley-J
Photos: Stanley-J
PostPosted: Sat Oct 28, 2006 5:00 pm    Post subject: Reply with quote
hi Bill,
if I understand you right you insert the baster inside the scupper from the cockpit side as a plug. Is this correct? Also what size eng. are you running?
Byrdman
Photos: FreeByrd and C-Byrd
PostPosted: Sat Oct 28, 2006 5:04 pm    Post subject: Reply with quote
WOW...Bob... I got lucky here.... I never was on the back of your boat. Mr. Green
Patrick Byrd "Byrdman"
Miss B - CD22A, Aug 2018
Aloysius, Hull # 440 RF-246
TC24, Hull #51, Sold Feb06
CD16A, Sold Dec03
Page generation time: 0.052s (PHP: 44% - SQL: 56%) - SQL queries: 23 - GZIP disabled - Debug on
