Oblio13
State or Province: NH
Vessel Name: Brad Rohdenburg
Posted: Sat Jul 15, 2006 8:43 pm Post subject: Anyone familiar with both C-Dory's and Eastern boats? |
Care to compare and contrast the two makes? |
Papillon
Joined: 31 Mar 2005 Posts: 949 City/Region: DeBary, Fl. *On the St. John's River*
Vessel Name: Papillon
Photos: Papillon
Posted: Sat Jul 15, 2006 11:21 pm Post subject: |
Remarks withdrawn....opening mouth and removing foot as we speak. _________________ Mike Taylor
330-936-1030
Joined: 02 Nov 2003 Posts: 20860 City/Region: Pensacola
Posted: Sun Jul 16, 2006 12:11 am Post subject: |
I suspect that he is asking to compare a semi dory and a Down East type of boat. The lobster boats, Duffy, and the nearest to the C Dory is the Rosborough 246. There are a fair amount of cross over between these two boats--and some Rosborough owners have been C Dory owners.
The Down East type of boat is often straight run aft, flat buttocks with a round chine, , and a moderate V foreward. It is also a semidisplacement boat. My personal opinion is that all in all the C Dory is a more stable and better sea boat.
The Rosborough often are much slower than the C Dory and are run at displacement speeds--with twins up to 15 to 17 knots and occasionally with large engines up to 30 knots. My feeling is the C Dory is more effecient in use of fuel. But the Down East boats are less likely to pound.
They are good boats, and I had considered one when I was making the decision on the Tom Cat 255. I am still a member of their list and plan on making a cruise with this group later this year.
It is a little like comparing a C Dory and A Sea Sport--both have some good features. The Rosborough has pilot house doors on the side--I see this as a negitive, because of water intrusion. The Rosborough has perment foreward facing seats, the V Berth is slighly shorter than the C Dory, and the head is more cramped than the 25 or Tom Cat--and below the helm console. The side deck access is about the same as C Dory. There is an extended cabin top over the aft cockpit--and a high and low freeboard model.
There are a number of other down east boats--but the Rosborough comes to mind when thinking of comparison with the C Dory. _________________ Bob Austin
Posted: Sun Jul 16, 2006 12:27 am Post subject: |
No - when he said "Easten Boats" I believe he was referring to the brand Eastern Boats. The most comparable model to the CD seems to be the 24' lobster boat. Take a look at the link to see. I've never seen one other than on-line. _________________ Roger on Meant to be |
Posted: Sun Jul 16, 2006 1:58 pm Post subject: |
Roger,
Most likely he was. I had looked at that web site before I replied--and the 24 does have a typical "down east" hull. Some of the other boats are a harder chine.
Looks like good construction and lamination. |
New Hampshire Guy Dealer
Photos: New Hampshire Guy
Posted: Sun Jul 16, 2006 2:58 pm Post subject: |
The Eastern is an excellent boat, very well made (here in NH) and with a great reputation. It is a different hull but with many of the same qualities as a C-Dory.
The 22' Model Eastern closest to the C-Dory is only enclosed on 3 sides and is 600 lbs heavier. Min recommended power is 115HP (which is the New C-Dory 22's max HP).
They are simple and self bailing boats and will achieve a higher max speed in rough weather due to the deeper V shape. The price you pay is a bigger engine and not so efficient MPG in transit.
They are similar boats in the excellent construction, reputation, and durability catagories. But they have very different attraction in the all weather, cruising, and overnight sleeping/anchor-out possibilities.
The people that own Easterns' swear by them and keep them for years if not decades (like the C-Dory).
Final sentence, an excellent boat but with different abilities.
Good luck!
John |
Rick from Maine
Joined: 02 Nov 2003 Posts: 308 City/Region: No. Berwick
State or Province: ME
Vessel Name: Hunky Dory
Posted: Sun Jul 16, 2006 3:54 pm Post subject: |
Since Eastern's are built near our house, I checked them out thoroughly when determining which boat to get. As John says, well made, good value.
A signifcant factor that made the 22' Eastern unacceptable to me is the very narrow deck going forward without good hand rails especially when trying to get around the corner of the cabin to the foredeck.
I didn't feel that I could safely anchor. So, I crossed it off my list. I haven't checked the access to the foredeck on the newer 24' model.
Rick from Maine |
Oblio13
Posted: Sun Jul 16, 2006 5:33 pm Post subject: |
Sorry I've been off for a few days - traveling.
I've seen a few Eastern 22's, and they seem comparable to the C-Dory 19, although with the aforementioned higher weight and vee hull. The model I'm most curious about is their 27' - I've only seen that one in brochures. It looks on paper much like the C-Dory 22. |
gljjr
Joined: 27 Jan 2005 Posts: 908 City/Region: Fall City
C-Dory Year: 1982
Vessel Name: Migratory Dory
Photos: gljjr
Posted: Mon Jul 17, 2006 12:42 pm Post subject: |
That 27 looks like a great fishing boat. It would be interesting to see how much cockpit space you would have with a full cabin like on my 27. It looks like their cabin sits further back on the boat leaving you with less room in the cabin and less room in the cockpit. Still I like the looks of it. Kind of reminds me of a Shamrock but with an I/O instead of direct inboard. _________________ Gary Johnson
KB7NFG |
