Swee Pea
Vessel Name: Swee Pea
Photos: Swee Pea
Posted: Tue May 24, 2005 1:10 pm Post subject: |
I appreicate the suggestion. I will take a look this weekend and see how much room is available.
This is the great thing about this site. Great ideas to "borrow".
Swee Pea |
SeaSpray
Joined: 12 Mar 2004 Posts: 1009 City/Region: Brentwood, CA
Vessel Name: SeaSpray
Photos: SeaSpray
Posted: Thu May 26, 2005 11:24 pm Post subject: |
Dan,
I was looking at the DogonDory pics. Can you post a little more detail abou your kicker mount. What size kicker do you carry on it? It looks like you bolt a mounting board to the bracket and the motor will clamp to it above the current transon level. I need to do something for my small kicker.
Steve |
dogon dory
Vessel Name: DogOnDory
Posted: Fri May 27, 2005 1:41 am Post subject: |
Papillon
Joined: 31 Mar 2005 Posts: 949 City/Region: DeBary, Fl. *On the St. John's River*
Vessel Name: Papillon
Photos: Papillon
Posted: Sat May 13, 2006 12:07 pm Post subject: Adding Bilge Pump and Bulkhead |
As rainy season approches and the boat is kept in the water, I am adding a bottom bulkhead at the end of the cabin area and will be installing a bildge on the cockpit side just off center of the (doorway, if I had one).
My question is: I want to put a recess hole in the hull and need to know how deep I can safely go...1 inch...2 inch?....In other words how thick is the hull at this location?
Respond fast....my battery is almost charged on the drill. _________________ Mike Taylor
330-936-1030
1993 Angler-02' 115 Suzuki 4 Stroke |
Posted: Sat May 13, 2006 3:45 pm Post subject: |
Whaler Go Far
I've heard before that the CD hulls, depending on their vintage are 1-1/2 to 2" thick, but that's not enough information to set the plunge router and have at it!
How big of a depression do you need? Enough for a pickup fitting at the end of a tube or enough to set a whole pump in it?
In either case, I'd use a rotary disk cut off tool on the end of a phenuatic or electric die grinder, and start by cutting out a small square, then pull and or cut the inside of the square out until I could get to the balsa core and work down just to the bottom of it, leaving the outer structural layer 100% intact, Then, knowing the thickiness, you can expand the work area, knowing the outer hull is intact and not compromised.
Be sure to re-seal the sides and bottom with resin once you have the depression carved out. (I know you probably already know this.)
Let us know how it goes! Joe. _________________ Sea Wolf, C-Brat #31
