Drilling holes in a C-Dory
ccflyer
City/Region: Bradenton, FL
Vessel Name: Retriever
Photos: ccflyer
PostPosted: Sun Apr 02, 2006 6:37 pm    Post subject: Drilling holes in a C-Dory Reply with quote
I'm trying to determine the best way to install stuff like speakers in the cabin, a holder for a boat hook beneath the gunwale, a shelf in the forward berth, etc.
Is there a best way to do this?
I hesitate to be drilling a bunch of holes so should I use some kind of epoxy adhesive?
PostPosted: Sun Apr 02, 2006 6:45 pm    Post subject: Reply with quote
For the things you are talking about, it can all be done without drilling a hole through the hull. The speakers can be mounted on/under the electronics shelf. Or, and this is a general technique, "glue" a piece of marine grade plywood or teak where you want to mount something using one of the 3M adhesives and then screw items into the wood (of course use screws that are short than the depth of the wood). 3M 3200 is a good silicone and can be failrly easily removed in the future. 4200 is stronger and 5200 is damn near permanent.
Edited to correct the error noted below (e.g. without previously read with).
PostPosted: Sun Apr 02, 2006 7:34 pm    Post subject: Reply with quote
For the things you are talking about, it can all be done with drilling
roger said.....
I think he meant without drilling a hole through the hull which is very negative for most of us....
ccflyer
Photos: ccflyer
PostPosted: Sun Apr 02, 2006 7:44 pm    Post subject: Reply with quote
Just finished the ...... whoops! So what's the preferred technique for filling 4 1/4" holes below the gunwale? Cry
Thanks guys
Luv ya Very Happy Very Happy Very Happy
SEA3PO
City/Region: Chester
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Sun Apr 02, 2006 8:05 pm    Post subject: Reply with quote
I understand what ya'all are saying about not drilling holes.... but not bad....heck ya gotta drill some to mount some things.... holes are easy to patch...the boats are made of polyester resin, which patches really well, and a dab of paint will cover any mistakes...it won't hurt the boat a bit...besides it's your boat...make it the way you want...
Alyssa Jean
Vessel Name: Alyssa Jean
PostPosted: Sun Apr 02, 2006 10:47 pm    Post subject: Reply with quote
I mount most all my stuff inside the cabin with 5200. Haven't had anything in the 22 or the 25 fall on my head yet. However there is still tomorrow.
David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51
PostPosted: Mon Apr 03, 2006 9:18 am    Post subject: Reply with quote
And David, just think about it. Since you work with Pat Anderson all the time, even if it did fall on your head, either wouldn't hurt or wouldn't do any damage!! Rolling Eyes
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Mon Apr 03, 2006 11:36 am    Post subject: Reply with quote
So, when you all are smearing adhesives to the inside of the hull (guess I should say applying adhesives) do you rough up or sand the surface to get that paint out of the way?
Fairbro
City/Region: Prescott
Vessel Name: Minnie Swann
Photos: Minnie Swann
PostPosted: Mon Apr 03, 2006 12:26 pm    Post subject: Reply with quote
My theory for mounting things on the boat is to try and use existing holes and screws. A lesson I learned from the factory by the way they route and attach the wiring. So far I have been able to mount a fire extinguisher, speakers and other holders by utilizing the window frame screws. I think it not only looks cool but keeps the spirit of the boat. If the brackets don't match up I modify them. Good luck, Gary on Minnie Swann
It's something in the water!
Alyssa Jean
PostPosted: Mon Apr 03, 2006 12:31 pm    Post subject: Reply with quote
I usually rough it up a little with some 150 grit. Although a couple of times I didn't and the stuff is still in place.
PostPosted: Mon Apr 03, 2006 6:49 pm    Post subject: Reply with quote
When ever I glue a bracket or a mounting board to the hull or wall I cut small grooves in the peaice that I am glueing so that the glue has a little more to hold on too. Gives a better surface then just a flat piece of wood or metal. So far the 5200 has really done a great job holding my speakers in place.
james
City/Region: CRYSTAL RIVER
Vessel Name: COOL CHANGE
Photos: COOL CHANGE
PostPosted: Thu Apr 13, 2006 3:27 pm    Post subject: adhesives Reply with quote
I used 2 part epoxy(no screws) to mount a transducer on my old boat.
never came off...
by the way, I am new here, have just bought a 2000 22 crusier.
hi! everyone
james
james
Photos: COOL CHANGE
PostPosted: Thu Apr 13, 2006 3:30 pm    Post subject: Reply with quote
by the way...anyone in central florida looking for a used C-DORY,
check out THREE RIVERS MARINE...great people!
James
PostPosted: Thu Apr 13, 2006 3:44 pm    Post subject: Reply with quote
Welcome aboard James. Glad to have you. How about some Pictures of your boat? The nerds can set you up if you but ask!!
james
Photos: COOL CHANGE
PostPosted: Fri Apr 14, 2006 12:29 pm    Post subject: Reply with quote
thanks Charlie, going to post some pics soon....
wanted to get her name on her ,"COOL CHANGE". also I had to put her back in the shop for some carb. related problems . first time out we had to be towed back in Crying or Very sad , just got her back. but she seems to be running fine now, at least on the hose. will be taking "COOL CHANGE" out for the weekend tonite.
James
Page generation time: 0.035s (PHP: 75% - SQL: 25%) - SQL queries: 32 - GZIP disabled - Debug on
