Tomcat self bailing issues
Captain Starbucks
City/Region: Tacoma
Vessel Name: DOUBLE BARREL
Photos: Captain Starbucks
PostPosted: Thu Jul 17, 2025 9:21 am    Post subject: Reply with quote
Hi John,
Yours are probably just missing but at the back of the boat just right above the water line are the 2 deck drains, one port, one starboard. There should be a very stiff plastic disc in there that is screwed to the deck drain assembly. Most likely, there is what's left of a small stainless fastener and no stiff plastic disk. Probably fell off. So I removed the tiny stainless fastener, drilled and tapped for 6/32, maybe 8/32 I can't remember, and installed this cool plastic disk I 3D printed. Works great.
Current boats
12' Lund with oars
17' Grumman expedition
Previous boats
Captain Starbucks
City/Region: Tacoma
PostPosted: Fri Jul 25, 2025 4:09 pm    Post subject: Reply with quote
I should mention, if anyone has any interest in making these flappers for your boat or you want to become a self made millionaire and print and sell these, PM me your email and I'll send you the file for free (if you're a C-Brat with more than a day of association).
Captain Starbucks
City/Region: Tacoma
PostPosted: Fri Aug 29, 2025 9:38 am    Post subject: Reply with quote
Captain Starbucks wrote:
I finally solved the problem with this 3D printed part I made.
I finally had a chance to run my boat offshore last weekend in the open ocean and I can say with complete confidence this part works. No, it can't fix the poorly engineered design of only a 2" delta between the deck and drain port, but the flapper I've designed and made keeps water out, and easily drains the deck.
PostPosted: Fri Aug 29, 2025 3:53 pm    Post subject: Reply with quote
Sell these on line or to the factory, so they will be factory issue on all of the boats with scuppers.
John S
City/Region: Sterling
C-Dory Year: 2021
Vessel Name: TomCat
Photos: TomCat
PostPosted: Fri Aug 29, 2025 4:01 pm    Post subject: Reply with quote
My scuppers still back flood the back deck. We bought pool pipe plugs.🥴
I see no evidence where any flapper was ever previously installed in my boat.
Very curious if I have the same hardware as others.
I’ve posted some detailed photos to my photo album. Unfortunately, I’m using an iPhone and it is not as easy to view the source as it used to be on a laptop to attach an image to this post.
If you have a moment to check my album and tell me where this flap would go, that would be pretty awesome.
2021 TC255 Tomcat
Suzuki DF175
Previous:
2000 TomCat 24
BF90 Hondas
www.AlaskaAdventureJournal.com
Captain Starbucks
City/Region: Tacoma
PostPosted: Fri Aug 29, 2025 4:22 pm    Post subject: Reply with quote
John,
I looked in your album but didn't see the deck drain output on the outside of your boat. Please let me know if I missed it, I'm happy to help!
Anyway, on my boat, the deck drain goes through a deck fitting, interconnect hose that is very short, then to the through-hull fitting where this little flapper valve is screwed in. The 255's have a very stiff plastic flapper that doesn't work even when new My design discards the factory flapper and replaces it with a 3D printed hinge in the shape of a circle with a stainless pin through it.
Rob
John S
C-Dory Year: 2021
Vessel Name: TomCat
Photos: TomCat
PostPosted: Fri Aug 29, 2025 4:31 pm    Post subject: Reply with quote
Thanks Rob!
The exterior drain outlet is in a sub-album “2021 Tomcat TC255”
It is the 4th photo, titled “Img 6750”
I am here with the boat now and can provide any other photos requested to determine if your fix would work for me.
If text is better, I can text photos too, 832-326-5572
Thanks again!
Page generation time: 0.0278s (PHP: 73% - SQL: 27%) - SQL queries: 24 - GZIP disabled - Debug on
