stevej
Vessel Name: Shearwater
Photos: Shearwater
Posted: Sat Jan 22, 2022 12:41 pm Post subject: |
Going to be working on the boat today and will grab some measurements for you Hardee.
Fairly sizable package, if I remember right believe it’s loaded with 170’ of 1/2 rode and 30’ of 3/8 chain. Not a deep water system but good up to 40’ or so. _________________ 1995 25' Cruise Ship #3 |
robhwa
Joined: 04 Dec 2013 Posts: 295 City/Region: Anderson Island
Vessel Name: Marcia C
Photos: Problemadela
Posted: Sat Jan 22, 2022 1:39 pm Post subject: |
stevej wrote: | Going to be working on the boat today and will grab some measurements for you Hardee.
Fairly sizable package, if I remember right believe it’s loaded with 170’ of 1/2 rode and 30’ of 3/8 chain. Not a deep water system but good up to 40’ or so. |
For a smaller total and deeper water (i.e. anchoring for Halibut), I've been thinking about a 3-part system. Anchor, chain, 50-100 ft or so regular rode, and then a lot of finer (and lighter) but very strong Spectra. I've been very impressed with using Spectra in runners (the sling between the protection "piece" and the rope) for rockclimbing, as it increases strength and reduces overall weight of what you carry. The stretch and energy absorption of a fall is absorbed by the climbing rope, not the runners, and Spectra is the primo material for them now. Obviously, fine, slick, Spectra won't feed into a regular puller as the chain and regular rode will, but with a drum system that won't matter. I'm also not crazy about the gunk going into my bow cabin. For regular anchoring, you won't even get to the Spectra. This stuff is amazingly strong, but doesn't stretch, so Spectra direct to chain would be too jerky, and maybe put too much stress on the anchoring system. Anyone tried this or seen it? Also, I was able to splice the regular rode to the chain nicely, but I'm not sure how to approach Spectra. Actually a knot or two probably wouldn't snag the reel system too much. Any advice or experience? |
NORO LIM
Photos: NORO LIM
Posted: Sat Jan 22, 2022 4:34 pm Post subject: |
robhwa wrote: | . . .
I toyed with the idea of this exact kind of system several times. Things to keep in mind about Spectra (Dyneema, as well):
As you noted, they have about zero stretch;
The are not well-suited for most knots - too slippery;
They float. _________________ Bill, Formerly on NORO LIM
2001 CD 16, 2001-2006
2006 CC 23, 2006-2014 |
Posted: Sat Jan 22, 2022 5:44 pm Post subject: |
I like the concept of keeping the rode and chain out of the V-Birth. I also like the Spectra/Dyneema size weight and working load ratio. Still, that takes a pretty good chunk of space (Thanks Bob, for the brochure link), and don't have measurements but that foredeck on a 22 is just not huge.
SleepyC
Joined: 02 Nov 2003 Posts: 21375 City/Region: Pensacola
Posted: Sat Jan 22, 2022 5:57 pm Post subject: |
I agree that Dyneema or Spectra would be ideal materials for the drum windlass. The joining of the Dyneema and a nylon section would easily be made by an eye place or Brummel splice in the Dyneema, into an eye splice into the nylon. There nylon would be a rope to chain splice to the chain.
One disadvantage of the Spectra or Dyneema is that you cannot make a bridal to the dyneema or spectra. (only if you were at the end where you could make an eye splice. )
On the other hand, many fishing boats world around use steel cable spliced to the chain on a drum windlass for their anchoring system. No more shock absorbing system other than the catenary of the chain. We do know at about 40 knots of wind, (depending on the vessel type) that the catenary disappears, and the chain starts to b some bar tight- and no shock absorbing effect. _________________ Bob Austin
stevej
Photos: Shearwater
Posted: Mon Jan 24, 2022 9:27 pm Post subject: |
hardee wrote: | I like the concept of keeping the rode and chain out of the V-Birth. I also like the Spectra/Dyneema size weight and working load ratio. Still, that takes a pretty good chunk of space (Thanks Bob, for the brochure link), and don't have measurements but that foredeck on a 22 is just not huge.
SleepyC
 | r
Be pretty big on a 22’
22.5” long
14.5” wide
13” tall (12” spool)
No wet anchor line inside the boat was one factor, along with using the locker space for an extra battery as part of the Alaska bound preparation.
There also seems to be A lot of discussions around failure, almost works most of time, where can I find parts with traditional windless offerings. Which was the real driver to look at drum systems.
Steven |
Nash 22
State or Province: MD
Vessel Name: Anyfin possible
Photos: Anyfin Possible
Posted: Tue Jan 25, 2022 11:14 pm Post subject: Lone Star Marine |
Check out Lone Star Marine winches.
I installed a GX-1 winch on my boat and love it.
I don’t have to go to the bow to tie the rode to a cleat and the winch doesn’t interfere with my line of sight.
The winch holds my boat nicely with a 13 lbs anchor, 20' of chain, and about 200 feet of synthetic rode.
You can also purchase the pre-made wires for the installation.
Check out my album to see a couple of pics. _________________ ----------------
2006 22' Cruiser - 90hp
1999 Chaparral 240 Signature - sold 2018
1986 Regal Bowrider - sold 2007
Home port - Annapolis, MD |
Posted: Wed Jan 26, 2022 11:24 am Post subject: Re: Lone Star Marine |
Nash 22 wrote: | Check out Lone Star Marine winches.
Check out my album to see a couple of pics. |
Thanks for the heads up on the Lone Star Winch! Interesting!
The review of testing showed the Lone Star Marine winch was clearly superior to other's reviewed in Australia.
Where did you buy the Winch, what material and diameter of synthetic line? How did you do the chain to rope splice. What is the capacity of the winch with the line you are using.
Too bad it was not compared with the EZ Anchor puller. But the Lone Star certainly seems like a very good winch. |
NORO LIM
Photos: NORO LIM
Posted: Wed Jan 26, 2022 5:05 pm Post subject: |
When I was toying with the idea of a drum winch, Lone Star was the brand I was looking at. Their testing results were really impressive. As always, a bit of skepticism is in order when a manufacturer tests its own product, but the winches appear to be very well built and durable. I never got far enough down the road to do a mock up to see what an installation might look like, and how it might affect line of sight. Scratch pad drawings had me pretty well convinced it would be doable. My thought on the rode was roughtly: 50 feet of chain, 150 feet of 8-plait or double-braided rope, and however many more feet of Dyneema would fit. I figured the chain catenary and the braided rope would suffice for shock absorption. Generally, the fewer connections the better in almost any system, but anchor to chain to braided rope to Dyneema to drum didn't seem unreasonable. It only adds one connection to a pretty standard set-up. |
Nash 22
Posted: Sat Jan 29, 2022 2:00 pm Post subject: Re: Lone Star Marine |
thataway wrote: | Nash 22 wrote: | Check out Lone Star Marine winches.
I bought the winch through Hammermarine.com which is located in Texas. Great customer service.
I don’t recall the details for the line itself, but i bought it as a package with the chain already spliced to the line.
If you look at the Hammer Marine website, the description of each model of winch has the recommended dimensions for the anchor rod and the drum capacity.
Keep in mind that I bought the GX1 because its hold capacity satisfies my needs for boating in the Chesapeake Bay. Last 4th of July I was anchored across the Naval Academy in Annapolis waiting for the fireworks and it held nicely in some windy conditions. If your boating conditions include offshore or very rough waters, I would recommend the GX2 or GX3 models.
The installation is straight forward aside from drilling oversized holes, filling the holes with epoxy, and drilling the epoxy for the size of the bolts. I did a lot of research about windlasses and i am not a fan of putting wet and muddy anchor rod inside the cabin. At the time of my research the E’Z anchor website did not inspire confidence and I could not reach anyone on the phone or email. I did have the chance to see a used EZ anchor winch for sale in my area but it was out of a fishing boat, old, and it was way too big for me.
I really cannot say enough of my anchor winch. Easy to use from inside the cab and holds my boat well for the type of boating i do. |
Punkin Drublic
Joined: 22 Feb 2025 Posts: 30 City/Region: Port Alberni
Posted: Tue Mar 25, 2025 11:23 pm Post subject: |
Given the anchor swivel topic going on, thought I'd necro this topic. Anyone with more to add on the subject of drums in the last couple seasons? Was a option I was considering myself. Sounds like its a tight fit on a 22, is the 23 venture any better or worse? _________________ 2017 Weldcraft Rebel 188 - Skeleton Crew |
Donald Tyson
Photos: Thistle
Posted: Wed Mar 26, 2025 11:28 am Post subject: |
Punkin, I second your enthusiasm for the drum winch. I was a pesticide operator earlier in my life and came to appreciate the hose winches that are exposed for all to see what is going on. They were dependable, visible and easy to use...jump ahead 48 years, I'm a boater looking for a solution for anchoring convenience. The style of the drum winch impresses me. So I'd like hear first hand from users and if the GX-1 wouldn't just be the cats meow for the 22.
Also, I'll have to go back and re-check, but did I hear that with a GX-1 you don't have to tie off the anchor when completely up (completely retrieved) or deployed? That would be a worthwhile attribute.
If I could use the Drum winch then I would repurpose the deck pipe to hold a spare rode, ready to hook to a spare anchor, and yet be protected by the cover. I've been on a number of sailboats that had a rode ready to use should the main anchor fail in some way. |
Donald Tyson
Photos: Thistle
Posted: Wed Mar 26, 2025 1:15 pm Post subject: |
I may have just found a reason to avoid these winches but I seriously am interested in your take on it. Look at the table below. As far as which model I would need for the weight reasons I would be wise to have GX-1 or GX-2. Then I happened to notice that, although they used heavier rode in their videos like 1/2" or so the recommendations below call for only 1/4 or 5/16 rope. Well "this changes everything". I don't think these arthritis ridden hands would enjoy fumbling with such a small diameter rope. Any thoughts on this?
225ft 1/4 inch D/B rope & 20ft of 1/4 inch S/L chain
300ft 5/16 inch D/B rope & 25ft of 1/4 inch S/L chain
330ft 3/8 inch D/B rope & 35ft of 5/16 inch S/L chain
425ft 3/8 inch D/B rope & 40ft of 5/16 inch S/L chain
450ft 1/2 inch D/B rope & 35ft of 3/8 inch S/L chain
500ft 7/8 inch D/B rope & 39ft of 1/2 inch S/L chain |
Donald Tyson
Photos: Thistle
Posted: Wed Mar 26, 2025 2:26 pm Post subject: |
I had the time so I called the owner of Lone Star. He was very genuine and sincere when He explained that he has sold many of these GX-1 & 2 with very fine spectra line. In fact he mentioned Halibut fishermen in Alaska using his setups as they need to put out a lot of line to anchor in several hundred feet of water.
He uses 4mm Spectra or Dyema for CD22 sized boats and they all have 25 or so feet of a larger top line ahead of your chain. Very I'm impressed. What are your thoughts on 4 or 6 mm as your primary anchor line? Could you set a 4mm anchor line and go sleep soundly?
As we discussed his products further I became convinced that I should pay attention to this technology and learn what I can. It offers a lot to Loopers that are in mostly calm waters that are usually of a shallower nature. Especially CD22 owners where storage space is at a premium.
Penny for your thoughts and big bucks for actual, users, testimonials. |
Posted: Wed Mar 26, 2025 2:54 pm Post subject: |
I personally would not want to give up the deck space for a reel type of windlass. They are used on commercial fishing boats on a regular basis--far more often than on recreation vessels. Perhaps if you were going to anchor every night in a different place or multiple times a day---I might consider. But for the usual. use in a C Dory, it does not make a lot of sense.
Yes, the synthetic lines have a very strong weight and size ratio to the safe working load. They would be a devil to work with if necessary by hand. They have no shock absorbing ability. You have to figure some ways to give shock absorption for the rode system. Although these ropes are reasonably. resistant to abrasion, they would not take much of a cut to be weakened substantially.
I have used the original deck pipe for a second rode as Donald describes--net to "fence off' the primary rode. If length of rode is an issue ref space, then the 8 plait makes sense, even if you have to go down to 3/8" (for most boats 1/2" works very well). I have never found storage of anchors or rodes to be a problem in C Dorys--usually a generatio 3 or 4 anchor on the bow, and a Fortress or 2 or 3 for stern and mud works well. The Fortress and Guardian break down very easily and fairly quickly for storage.
These drum anchor windlasses are rarely seen on full time long distance cruising recreational boats. There are reasons. Even the mega yachts where money is not an issue rarely use these systems. |
