How do you prevent trailer connector contacts from corroding
Karl Konecny
City/Region: Glide
Vessel Name: Nowhere Fast
Photos: Nowhere Fast
PostPosted: Tue Mar 19, 2024 11:02 am    Post subject: How do you prevent trailer connector contacts from corroding Reply with quote
I'm still fairly new at boating in salt water and have a question: what is the best protocol for preventing trailer connector contacts from corroding? I'm having issues with intermittent connections to my trailer that appear to be caused by corrosion.
drbridge
Vessel Name: Susan Marie
Photos: Susan Marie
PostPosted: Tue Mar 19, 2024 11:07 am    Post subject: Reply with quote
I spray some of this stuff on mine when they act up and it seems to do the job. Always make sure you have a good ground to the trailer too.
https://www.amazon.com/CRC-05103-Electronic-Cleaner-11/dp/B000BXOGNI/ref=sr_1_3_pp?crid=1FYDWL3FHLPOW&dib=eyJ2IjoiMSJ9.v4SmyrvDSkglCVs2m1kax1mGsY5XjBLgKfEldhk55DbTg2O99RspWgUCShow5eI9OYggnYkWkyXIVUOnr4mzC34leAkq-fGyTt0qhe_m6GufP8jjnO3gcJF-1lwfn-luQlVeigwLWU9w19lvxJIx0pO4BeXeIfkLaYpfy-0C4IA6Zfj-PR6MbUn2gN_BL5h5h2LSy7yhcYYBomcRqHR47eJR-RmOor_lieTCrPsH01s.8FKylFL7H92eaVfHXceXvLfOplrJ4ibMIvHYdy2vbTM&dib_tag=se&keywords=crc+electronic+cleaner&qid=1710860687&sprefix=crc+ele%2Caps%2C306&sr=8-3
Doug & Susan
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Tue Mar 19, 2024 12:41 pm    Post subject: Reply with quote
Silicone grease. It’s synthetic, won’t damage plastic or rubber products and is a dielectric.
Steve Baum
Homeport of Portsmouth, VA
-Waypoint-
C-Dory Year: 1998
Vessel Name: Waypoint
Photos: Waypoint
PostPosted: Tue Mar 19, 2024 1:20 pm    Post subject: Reply with quote
I second the importance of a good ground. I chased bad grounds last year on my trailer. Found out that the wiring was corroding under its insulation only getting 7 volts to the back of the trailer. Trailer is only 4 years old. I replaced all my wiring with heaver gauge tinned marine wiring, problem solved.
Not cheap at $1/ft. Having lighting issues before going to the ramp could wreck a good boating day.
Mark n' Yuka Elwell
Karl Konecny
City/Region: Glide
PostPosted: Tue Mar 19, 2024 10:44 pm    Post subject: Reply with quote
Thanks for all the tips, I bought some contact cleaner and will give it a try. I've thought about dielectric grease but my truck sees lots of dusty roads and the cover on the trailer hookup doesn't keep all the grime out. I'm concerned the grease will just turn to mud, anybody have that problem?
PostPosted: Tue Mar 19, 2024 11:18 pm    Post subject: Reply with quote
We have used a light coat of the electrical grease or Corrosion block. The contact cleaner is just that: a cleaner. The corrosion block or grease is preventative maintenance.
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Wed Mar 20, 2024 12:41 am    Post subject: Reply with quote
Best wishes preventing it entirely. They always get corroded eventually. The dielectric grease suggestion is good advice.
Schuster
City/Region: Port Orchard
Vessel Name: Sea Witch
Photos: Sea Witch
PostPosted: Wed Mar 20, 2024 12:12 pm    Post subject: Reply with quote
I also agree that a dielectric grease is the proper way to attempt to reduce corrosion. It would also be a good idea to have that cleaner to clean out the dust/grime build up occasionally. The idea is to prevent salt water from contacting the electrical conduction areas and the grease will be most helpful in that regard. Good luck.
(Sea Witch)
25' Cruiser
srbaum
Vessel Name: Osprey
Photos: Osprey
PostPosted: Wed Mar 20, 2024 5:43 pm    Post subject: Reply with quote
This is the grease that I use:
https://www.amazon.com/gp/product/B06WLQ251B/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
You can coat all of your electrical connections with this. I use it almost daily, for my outboard repair hobby and even for household chores.
What I did not mention, but others have, is that I first clean electoral contacts with cleaner with this cleaner, then boat with the silicone grease:
https://www.walmart.com/ip/WD-40-Specialist-Electrical-Contact-Cleaner-11-oz/467402449?wmlspartner=wlpa&selectedSellerId=0&wl13=3214&adid=22222222277467402449_160805772391_20959796377&wmlspartner=wmtlabs&wl0=&wl1=g&wl2=c&wl3=501107745824&wl4=pla-306310554666&wl5=9008589&wl6=&wl7=&wl8=&wl9=pla&wl10=8175035&wl11=local&wl12=467402449&wl13=3214&veh=sem_LIA&gclsrc=aw.ds&&adid=22222222237467402449_160805772391_20959796377&wl0=&wl1=g&wl2=c&wl3=501107745824&wl4=pla-306310554666&wl5=9008589&wl6=&wl7=&wl8=&wl9=pla&wl10=8175035&wl11=local&wl12=467402449&veh=sem&gad_source=1&gclid=CjwKCAjwkuqvBhAQEiwA65XxQKfU0uepnRO0lsKJJOg1fhGvNhpxwtWQI9-glyG7G8uy-5hfaIyZ3hoCqgkQAvD_BwE
Page generation time: 0.0319s (PHP: 64% - SQL: 36%) - SQL queries: 27 - GZIP disabled - Debug on
