nwboater
C-Dory Year: 2017
Vessel Name: FastCat
Photos: FastCat
Posted: Tue Oct 31, 2023 12:56 pm Post subject: Winterizing question / in salt water |
I have 25 plus years owning and maintaining diesel trawlers...but OB engines are new for me. My new to me TC255 is in a boat house...but the boat is too long by a couple of feet, so the lower units of my Suzuki 150s are exposed. How best to protect from freezing when moored in salt water? (I will be away from home for next 4-5 months).
I read on the forum where one owner pulled garbage bags over the lower units/props then lowered the motors down to their upright (running) position. I have flushed both engines but can not be 100% certain that some residual water remains. Any suggestions will be appreciated!
nwboater@whidbey.net _________________ Richard Soto
Tomcat 255 "FastCat"
American Tug "Salty"
Selene 47 "Kika"
Willard 40 "Northstar"
Classic Monk cruiser "Annie B" |
Peter & Judy
State or Province: AB
Vessel Name: Mistaya
Photos: Mistaya
Posted: Tue Oct 31, 2023 1:30 pm Post subject: |
Personally I would not store my boat in the water for the winter. if you have a trailer, park it on land and avoid the damage that could be caused by longterm storage in salt water. _________________ Peter & Judy Haase
Buffalo Horn Ranch
HMCB Mistaya
HMCB (Her Majesties Cute Boat) |
T.R. Bauer
Vessel Name: C-Whisperer
Posted: Tue Oct 31, 2023 1:43 pm Post subject: |
You can do what you say if you want. But, if you walk the harbor in Homer or Seward in January, you will not see garbage bags around the engine lower unit with it sitting in the water. They're pretty much all up and out of the water. I use my boat in the winter months and after the outboards have drained and the boat is secured to the dock, I just tilt them up and walk away. If I'm going to be back in a couple hours, I don't even bother tilting them up. I've never had an issue. Your mileage may vary..... |
Joined: 27 Oct 2012 Posts: 3580 City/Region: SW Michigan
Posted: Tue Oct 31, 2023 2:42 pm Post subject: |
Potential issue will storing the motors tilted up and uncovered is that water can get into the passages in the lower unit (e.g. from rain) and freeze and crack things. The hub of the prop is also the exhaust outlet. |
tsturm
Joined: 01 Nov 2003 Posts: 1171 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Thu Nov 02, 2023 12:03 am Post subject: |
T.R. Bauer wrote: | You can do what you say if you want. But, if you walk the harbor in Homer or Seward in January, you will not see garbage bags around the engine lower unit with it sitting in the water. They're pretty much all up and out of the water. I use my boat in the winter months and after the outboards have drained and the boat is secured to the dock, I just tilt them up and walk away. If I'm going to be back in a couple hours, I don't even bother tilting them up. I've never had an issue. Your mileage may vary..... |
32 degreeze F. or below, I leave the lower unit in the water, it sits in the homer harbor 10 - 11 months a year. YMMV!  |
T.R. Bauer
Posted: Thu Nov 02, 2023 3:05 pm Post subject: |
tsturm wrote: | T.R. Bauer wrote: | You can do what you say if you want. But, if you walk the harbor in Homer or Seward in January, you will not see garbage bags around the engine lower unit with it sitting in the water. They're pretty much all up and out of the water. I use my boat in the winter months and after the outboards have drained and the boat is secured to the dock, I just tilt them up and walk away. If I'm going to be back in a couple hours, I don't even bother tilting them up. I've never had an issue. Your mileage may vary..... |
You can do that and as you know from just walking the docks that is not the most common practice. I always worry about the harbor pan ice creating problems, but I know that is a rare occurrence. I have been told by many that if you do tilt the engine up, it is imperative that the lower unit is not higher than the powerhead as water. I can see why. I prefer storing them down as the manual says, but I have stored up and down at the harbor in the winter. As long as they drain, it probably doesn't matter. Yup....YMMV  |
gabi_ross
State or Province: NY
Posted: Wed Nov 22, 2023 12:48 pm Post subject: my life hack |
Schuster
Joined: 25 Mar 2009 Posts: 181 City/Region: Port Orchard
Vessel Name: Sea Witch
Photos: Sea Witch
Posted: Wed Nov 22, 2023 3:38 pm Post subject: |
I like the idea of putting plastic bags over the lower units to keep the sea growth off while they sit in the water protected from possible freezing. That however doesn't help the rest of the hull in the water. I personally put mine on a trailer for the winter. I don't like leaving the boat unattended in the water for any length of time as one never knows what the weather will deal out. I remember a few years ago it snowed hard and brought down the marina roof, so you never know. I guess that's why we carry insurance. _________________ Dave
(Sea Witch)
25' Cruiser |
