How much chain and rode for Salish Sea?
C-Wolfe
Vessel Name: Valhalla
Photos: C-Wolfe
PostPosted: Tue Nov 07, 2023 4:42 pm    Post subject: Reply with quote
pcg wrote:
Thanks everyone! I just ordered 275' 1/2" 8-plait, 50' 1/4" galv. chain, and a 5/16" SS shackle from Dark Horse Marine.
Probably goes without saying but…Make sure your chain match your windlass gypsy.
Stephan
Hunkydory
State or Province: WY
Vessel Name: Hunkydory
PostPosted: Tue Nov 07, 2023 8:24 pm    Post subject: Reply with quote
The chain that Bob mentioned earlier “1/4” ACCO ISO G43 (G4)1/4” chain” is what I have on our Lewmar H700 windless, so it will fit yours.
pcg
City/Region: Sherwood
Vessel Name: C-Quest
Photos: pcg
PostPosted: Wed Nov 08, 2023 4:19 pm    Post subject: Reply with quote
Thanks for the alert. Yes, I went with chain and rode type/size that Lewmar recommended.
Paul
Foggy
C-Dory Year: 2014
Photos: W B Nod
PostPosted: Wed Nov 08, 2023 5:56 pm    Post subject: Reply with quote
For those concerned with vessel weight forward and if the goal is to increase bottom
holding, another option, in stead of adding more chain*, is to increase the size of
your anchor.
* 1/4" chain weighs about 0.75 lb/ft; add 20 ' of chain to yours = 15 lbs more weight
Increase anchor size for about a 23' boat:
Rocna 6 Kg anchor weighs 13.3 lbs; holds about 4K lbs
Rocna 9 Kg anchor weighs 19.8 lbs ; holds about 13K lbs
Therefore, the difference of 6.5 lbs more anchor weight may have 9K lbs of
holding power vs an unknown extra 20' of chain holding power weighing about
15 lbs.
Aye.
Grandpa used to say, "The devil is in the details."
"I don't want any cake" - said no one ever.
If someone tells you they don't eat cake, unfriend them. You don't need that kind of negativity in your life.
B~C
City/Region: Bend
Vessel Name: Blue~C
Photos: Blue~C
PostPosted: Wed Nov 08, 2023 7:42 pm    Post subject: Reply with quote
50' of chain is nice to have on the Columbia if you're fishing. with that chain you can have that anchor on a short leash when parked in hog line. be sure to rig your anchor to break away. Here's a video on rigging a break away, he's using one zip tie, you need at least two to center the chain on the shank so it doesn't get hung up on the bow roller when retrieving.
https://www.youtube.com/watch?v=aTe8DJj3w8o
enjoy
Ken
1999 22' boaterhome
PostPosted: Wed Nov 08, 2023 8:01 pm    Post subject: Reply with quote
enjoy
I've seen this method a few times and wonder how well it works. Any chance that in heavy seas or a heavy blow that the zip tie could break off? Especially if the wind changes directions, blowing the boat back over the top of the anchor, so that the anchor line ends up pulling across the anchor and rather than the anchor resetting, the zip tie breaks? Colby
B~C
City/Region: Bend
Vessel Name: Blue~C
Photos: Blue~C
PostPosted: Wed Nov 08, 2023 8:09 pm    Post subject: Reply with quote
a pair of heavy duty zip ties hold pretty good for most applications. In AK where we regularly anchored in 200' of rough water we used gangion with several wraps
PostPosted: Thu Nov 09, 2023 10:48 pm    Post subject: Reply with quote
pcg wrote:
You can also use a variant of the "taut line hitch".
My all-time favorite knot from Boy Scout days. Thank you for sharing your knowledge Bob!
Thank you.
Yes, the "taut Line hitch" stems from my Boy Scout days also.
westward
C-Dory Year: 1985
Vessel Name: TBD
Photos: Steady Eddy
PostPosted: Sat Nov 11, 2023 8:20 am    Post subject: Reply with quote
The "breakaway" anchor rig shown in the YouTube video is intended for day use only. Unless you wish to trust your fate to the strength of zip-ties.
Sitting at the window, watching a gale blow as I type Smile
B~C
City/Region: Bend
Vessel Name: Blue~C
Photos: Blue~C
PostPosted: Sat Nov 11, 2023 11:22 am    Post subject: Reply with quote
that's why you use gangion for heavy duty applications
westward
C-Dory Year: 1985
Vessel Name: TBD
Photos: Steady Eddy
PostPosted: Sat Nov 11, 2023 3:37 pm    Post subject: Reply with quote
I guess I'm not understanding this setup? I thought it was designed for easier breakout of a stuck anchor? If that is the purpose, then anything significantly weaker than your main rode would in theory increase your risk of failure under full strain, and (as was mentioned earlier) tend to impede a re-set of the anchor. I've seen this setup many times, but always with the warning not to use in foul anchoring weather, especially at night, when not under continuous watch.
My personal thoughts are: when do deployed anchors tend to fail? Pretty much always in a heavy-weather situation under strain, and pretty much always when one's boat is near rocks, other boats, the shore, etc.
I've heard this setup called a "fisherman's anchor"
Maybe it warrants another thread, such as: "anchor failure experiences and lessons learned" ?
Page generation time: 0.0315s (PHP: 69% - SQL: 31%) - SQL queries: 28 - GZIP disabled - Debug on
