Suzuki 90 clearances
The Commodore
Photos: The Commodore
PostPosted: Fri Apr 14, 2023 6:29 pm    Post subject: Suzuki 90 clearances Reply with quote
I'm installing a jack plate for my Honda kicker. How much space do I need to allow between the main engine (a Suzuki 90)? the current adjustable motor mount for the kicker needs to go. The new jack plate will, I think, need to mounted a bit closer to the centerline of the boat. Where do I find this info? thanks
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Fri Apr 14, 2023 7:01 pm    Post subject: Re: Suzuki 90 clearances Reply with quote
Tape measure and transom?
That should do it??
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Sat Apr 15, 2023 9:32 am    Post subject: Reply with quote
Turn your main motor as far as it will go to the side your going to mount the kicker. Turn the kicker towards the main and adjust it so they don't hit each other. Also check them when they are tilled.
Jody Kidd
KE7WNG
Northern, Utah
Page generation time: 0.026s (PHP: 55% - SQL: 45%) - SQL queries: 21 - GZIP disabled - Debug on
