ken35216
Joined: 12 Mar 2013 Posts: 577 City/Region: Destin, Florida
C-Dory Year: 2017
Vessel Name: Lady Onyx
Photos: ken35216
Posted: Thu Mar 23, 2023 2:19 pm Post subject: 2012 Yamaha motor question. |
I know some of you guys know things so I'm going to ask your opinion.
Would you be scared of a Yamaha 115hp motor, on a 2012 boat, that has been stored since new in a high and dry in SW Florida? It's only had the 100 hour service. I'm sure that was about 7 years ago. It currently has 212 hours on the motor.
I'm thinking the high and dry flushed the motor every time but only 1 service in 10 years scares me.
Thoughts?
Thanks! _________________ 2007 25 Cruiser 150 Suzuki (2013-2016)
2017 25 Cruiser 200 Yamaha (2017-present) |
ken35216
C-Dory Year: 2017
Photos: ken35216
Posted: Thu Mar 23, 2023 2:49 pm Post subject: |
It's also a 2012 motor. |
Schuster
Joined: 25 Mar 2009 Posts: 185 City/Region: Port Orchard
Vessel Name: Sea Witch
Photos: Sea Witch
Posted: Thu Mar 23, 2023 3:39 pm Post subject: |
Ken, first off I don't own a Yamaha and have never worked on one, but believe they are on top of their game. Great motors. If it were me looking to purchase it I would want a sea trial. if that isn't possible I would want to have a certified mechanic look at it. That would probably be at your expense. But really, I wouldn't be afraid of it if it actually has only 212 hours on it. Those hours can be verified by a mechanic. (you can't always trust the hour meters). At 212 hours the motor isn't broken in yet. You need to take the steps to make yourself feel comfortable with the deal If the asking price is right. Good luck. _________________ Dave
(Sea Witch)
25' Cruiser |
T.R. Bauer
Vessel Name: C-Whisperer
Posted: Thu Mar 23, 2023 3:50 pm Post subject: |
I would say the best running boat motor I have ever had is a 40 hp four stroke yamaha jet. Yamaha makes great stuff in my opinion and their outboards are generally fantastic.
If it runs out well, doesn't blow smoke on heavy acceleration, has good oil pressure, and doesn't make any unusual noises, I think it's probably fine. I'd be a bit concerned about rust on machined surfaces because of the prolonged storage, but if it works as it should, it probably doesn't have enough to be that concerned about. |
Joined: 27 Oct 2012 Posts: 3588 City/Region: SW Michigan
Posted: Thu Mar 23, 2023 4:27 pm Post subject: |
When was the motor actually run last?
If it was last week and the motor worked fine I wouldn't worry about it. If it has been years, I'd want to test it out. |
Joined: 02 Nov 2003 Posts: 21493 City/Region: Pensacola
Posted: Thu Mar 23, 2023 9:19 pm Post subject: |
Check the compression, if any question then do a leak down test. I probably would squirt a little light oil in each cylinder and then turn it over by hand a few times before firing it up. You may want to replace all hoses, filters, and the plugs. Definitely do a sea trial. I would not be all that worried if it checks out on the above. _________________ Bob Austin
ken35216
C-Dory Year: 2017
Photos: ken35216
Posted: Fri Mar 24, 2023 11:07 am Post subject: |
Thanks guys! I'm trying to pick up a little lake boat as the C-Dory is at the beach, 4 hours away. |
