Aluminum gas tanks
Post new topic   Reply to topic    The C-Brats Forum Index -> C-Dory Boats Wanted
Captain Pete
PostPosted: Sun Dec 11, 2022 3:54 pm    Post subject: Aluminum gas tanks Reply with quote
Anybody know whether the custom aluminum fuel tanks some have are good working items? Ken Frey had them on Pelican, but don't know whether they were good...Thank you very much.
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Sun Dec 11, 2022 4:50 pm    Post subject: Reply with quote
The thing that is nice about custom, to be built for the boat tanks, is that the pickup tube can be placed in a location that enables you to use your entire load of fuel (nearly anyway). You can also have them baffle them to help prevent fuel slosh. A well made alloy tank will last decades.
PostPosted: Sun Dec 11, 2022 5:05 pm    Post subject: Reply with quote
In small boats aluminum tanks are the most common type. There were some made for the C Dory (especially in earlier times) where there was about 70 gallons, this included a center part of the tank which takes up much of the area where the aft sump is locate. Yes they worked fine. Baffles are essential.
But that is putting even more weight in the boat, which may not be all that desirable. I might consider under gunnel or saddle tanks for extra range. That would bring the weight forward. Also there are a number of saddle tanks already available, making the cost less.
-Waypoint-
C-Dory Year: 1998
Vessel Name: Waypoint
Photos: Waypoint
PostPosted: Mon Dec 12, 2022 8:33 am    Post subject: Reply with quote
My boat has one 50 gallon aluminum tank. Divided into two 25 gallons port and starboard tanks it came with this tank. It is original to the boat, when it corrodes, I'll replace it with the same aluminum tank. The tank weighs about 25 lbs. Plus if a fire was to happen, it would take a little longer for the aluminum to melt than a plastic tank. Aluminum tanks require a fuel gauge. Just depends how your going to use your boat just like evrything with the C-Dory.
Mark n' Yuka Elwell
Post new topic   Reply to topic    The C-Brats Forum Index -> C-Dory Boats Wanted All times are GMT - 5 Hours
Page generation time: 0.0268s (PHP: 59% - SQL: 41%) - SQL queries: 22 - GZIP disabled - Debug on
