Kicker motor mount for 22 Cruiser
The Commodore
Photos: The Commodore
PostPosted: Wed Nov 16, 2022 11:31 pm    Post subject: Kicker motor mount for 22 Cruiser Reply with quote
I purchased a 22 cruiser a few months ago. The main engine is a Suzuki 90. The kicker is a Honda 15 on a Garelick up/down motor mount. Unfortunately, the kicker drags in the water even if the mount is raised and the engine tilted up. After talking with Garelick today, I realized the Honda probably has a long shaft. I also realized that the mount should be vertical and it's not. The rep from Garelick suggested installing a shim between the transom and the mount. Then he went on to say that they don't recommend having the motor on the mount when the boat is going down the road on the trailer.
So now what do I do? I've installed motor mounts on sailboats but never on a boat like this.
What's the best practice? Get a smaller kicker?! I have photos of this situation but I don't think I can post them here.
Standas
City/Region: Poulsbo
C-Dory Year: 2013
Vessel Name: C -Time
Photos: C -Time
PostPosted: Thu Nov 17, 2022 9:56 pm    Post subject: Reply with quote
On my boat I got rid of the garelick and replaced it with a mini jack plate. The motor only drags when I first am getting on plane. I have a Honda 9.9 long shaft
PostPosted: Thu Nov 17, 2022 10:22 pm    Post subject: Reply with quote
We used a short-shaft 3.5hp motor on an adjustable Garelick mount on our 25. It did not drag when underway and the short-shaft was better on the dinghy. The 3.5 was light enough to not be a beast to swap between the boat and the dinghy. I did carry the 3.5 in the bed of the truck (locked bed cover) while towing.
The Commodore
PostPosted: Fri Nov 18, 2022 1:09 am    Post subject: Reply with quote
Thanks. Sorry, what's a jack plate?
The Commodore
PostPosted: Fri Nov 18, 2022 1:13 am    Post subject: Reply with quote
[quote="Standas"]On my boat I got rid of the garelick and replaced it with a mini jack plate. The motor only drags when I first am getting on plane. I have a Honda 9.9 long shaft[/quote]
Sorry to be such a blockhead but what's a mini jack plate? Any particular brand?
Thanks!
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Fri Nov 18, 2022 6:21 am    Post subject: Reply with quote
Mini jackplate example:
https://www.basspro.com/shop/en/t-h-marine-mini-jacker-for-clamp-on-outboards?hvarAID=shopping_googleproductextensions&ds_e=GOOGLE&ds_c=BPS%7CShopping%7CSmart%7CBoating%7CGeneral%7CNAud%7CLow%7CNMT&gclid=EAIaIQobChMItYyUnM63-wIVjo7ICh0mlgCuEAQYASABEgLh__D_BwE&gclsrc=aw.ds
Steve Baum
Homeport of Portsmouth, VA
The Commodore
PostPosted: Fri Nov 18, 2022 9:21 am    Post subject: Reply with quote
[quote="srbaum"]Mini jackplate example:
https://www.basspro.com/shop/en/t-h-marine-mini-jacker-for-clamp-on-outboards?hvarAID=shopping_googleproductextensions&ds_e=GOOGLE&ds_c=BPS%7CShopping%7CSmart%7CBoating%7CGeneral%7CNAud%7CLow%7CNMT&gclid=EAIaIQobChMItYyUnM63-wIVjo7ICh0mlgCuEAQYASABEgLh__D_BwE&gclsrc=aw.ds[/quote]
Thanks!
The Commodore
PostPosted: Fri Nov 18, 2022 9:23 am    Post subject: Reply with quote
Do you have a photo of the installation?
PostPosted: Fri Nov 18, 2022 11:21 am    Post subject: Reply with quote
You can look in Midnight Flyer's album, in the nested album for kicker install. I used the mini Jack plate for the Tohatsu 6 on my 22. Colby
http://www.c-brats.com/modules.php?set_albumName=album1889&op=modload&name=gallery&file=index&include=view_album.php
The Commodore
PostPosted: Sun Jul 23, 2023 2:54 pm    Post subject: Motor Mount for C22 Cruiser--updates Reply with quote
Thanks all for your suggestions. The old Garelick adjustable motor mount is gone! Holes plugged. Installed a Jack plate. We had lots of discussion about the placement but in the end, it can only go in one spot due to the constraints imposed by the trim tab actuators and the transom. More holes in the transom with plenty of 5200!
Once we had that in place we had another discussion about the exact position of the engine. Up, down, left right. Actually we mounted it then remounted it for better clearance on the Stbd. side of the transom cutout. I'm happy to report that the lower unit now comes completely clear of the water, drags just a bit when we're at speed but not enough to make any difference.
The engine hangs vertical now and clears the trim tabs by a couple of inches.
This engine is a 15 hp Honda with 20" shaft.
I have photos of the before and after. I just can't figure out how to add them to this post.
Salmon Fisher
City/Region: Arlington
Vessel Name: Kim Christine
Photos: Kim Christine
PostPosted: Sun Jul 23, 2023 7:58 pm    Post subject: Reply with quote
Would be great to see photos of your progress.
Request a photo album from Tyboo or Danag.
Patrick and Kim Walker
2004 25 Cruiser-Present
1985 22 Classic -2019 (Sold)
Page generation time: 0.0455s (PHP: 68% - SQL: 32%) - SQL queries: 29 - GZIP disabled - Debug on
