SOLD- 2004 22' C-Dory, 2021 90 HP Honda
bshillam
City/Region: Bellingham
C-Dory Year: 1981
Vessel Name: Heaven To Me
Photos: My Heaven
PostPosted: Wed Jun 15, 2022 1:19 pm    Post subject: SOLD- 2004 22' C-Dory, 2021 90 HP Honda Reply with quote
I have a 04 22' C-Dory that I am transporting across the country. Can drop anywhere in the lower 48. New Honda motor with less than 10 hours! If you have been looking for a ready to cruise CD this would could be the one. Pictures in my album. Newer 2016 dual axle trailer too!
Full camper back
Fenders
Raised cockpit floor!
Some of the stats,
2004 C-Dory 22 Cruiser
HULL I.D. NUMBER: CDO22191A404
TOTAL POWER: 90 hp
CRUISING SPEED: 16 Mph
MAX SPEED: 28 Mph
FUEL CAPACITY: 46 Gallons
DC POWER: 2x, 12 Volt Batteries
TYPE: Gasoline Outboard
MANUFACTURER: 2021 Honda
MODEL NUMBER: BF90D
SERIAL NUMBER: 1413208
ENGINE HOURS: Reported to be 9 hours.
PROPELLER: Stainless Steel 3 Blade, 14” diameter.
BATTERIES: Two, group 24 starting batteries.
Both were properly secured in battery boxes,
And properly wired.
BATTERY CHARGER: Pro-mariner,110 Volt, 12 amp.
Mounted at the transom
And connected to both batteries. The charger
Must be connected to shore power with an
Extension cord. Was Operational.
GENERAL CONDITION: Both batteries were dated 2021 and were
Properly secured. All
Components of the charging system were
Well maintained and operational.
FUEL SYSTEM
NUMBER OF TANKS: Two
MATERIAL & CAPACITY: Plastic tanks, 23 gallons each.
Tanks are secured properly
And are clean and leak free
In areas that are visible.
TANK LOCATION: Tanks are located at the transom.
FILL PIPE LOCATIONS: Port & Starboard side decks
Marked “GAS”.
HOSE MATERIAL: Fill hoses are Type A2 and
Are clamped and secured
Correctly.
STEERING SYSTEM
TYPE: Manual
MANUFACTURER: Teleflex
NUMBER OF STATIONS: One
LINES & FITTINGS: Reinforced flexible lines with
Metallic fittings.
TRIM TABS: Lenco Trim Tabs.
ELECTRICAL SYSTEMS
VOLTAGE: Lead acid battery powered
12 volt system.
BATTERIES: Two, group 24.
Were properly wired & secured
MAIN BATTERY SWITCH: Rotary type, mounted in
A transom compartment.
PANEL: Main Electrical panel and load
Center is located in cabin.
BREAKERS & SWITCHES: Panel with switches and
Breakers is located at the
Helm station.
OUTLETS: One Cigarette lighter style
Outlet at the helm station.
CONNECTORS: Round lug captive type
GALLEY
STOVE: Wallas, 2 burner, alcohol stove.
Was not tested due to no fuel on-board.
SINK: Stainless steel sink, with manual foot operated
Pump. Was operational. No leaks sighted.
ELECTRONICS & NAVIGATION EQUIPMENT
STANDARD HORIZON Matrix GX2000 VHF radio
Was operational
RITCHIE 3” Compass
Was operational
GARMIN GPSMAP with Sidescan Sonar
Was operational
UNIDEN QT-206 Depth Gauge
bshillam
C-Dory Year: 1981
Photos: My Heaven
PostPosted: Wed Jun 15, 2022 1:55 pm    Post subject: Reply with quote
Upgrades/installs/recent maintenance
October 2018
West Marine dual battery charger
March 2020
West Marine auto 800 bilge installed
Sep 2020
New battery cut off installed
Trailer serviced
Upholstery repaired cover
October 2020
Fuel filter replaced
Replaced 50amp waterproof thermal circuit breaker
Added Stainless steal Solars propeller
June 2021
2 New West Marine batteries installed
July 2021
New foam for all cushions
New Honda BF90 installed with new shift lever and cables. *Hour meter read 948 when motor was replaced
New filler water hose and new hoses to sink installed
New foot pump for sink installed
New bilge discharge hose installed
All L-brackets in cabinetry replaced with new stainless steel and ss screws
Significant mentions
2016 Load Rite tandem trailer w/ spare tire
Swim platform, factory upgrade
Lenco trim tabs
Full enclosure bikini with plastic windows as well as screened windows
Full boat cover
Cabin door screen
Anchor and 150’ anchor rode
bshillam
C-Dory Year: 1981
Photos: My Heaven
PostPosted: Wed Jun 15, 2022 1:58 pm    Post subject: Reply with quote
Sorry, tried to edit the original post. Boat is being sold for $40k. Transportation is negotiable.
Feel free to call, 503-781-9967 or email bshillam@hotmail.com
Esmi2
City/Region: San Luis Obispo, CA
Photos: Esmi2
PostPosted: Thu Jun 16, 2022 12:20 am    Post subject: Reply with quote
Very very nice.
Note to lookers: This boat for sale is on Page 2 of his album in the last folder. (I made some incorrect assumptions the first time I looked for it!)
2006 Cape Cruiser 23 w Yamaha 115 -- "Scoot"
bshillam
C-Dory Year: 1981
Photos: My Heaven
PostPosted: Thu Jun 16, 2022 11:44 am    Post subject: Reply with quote
Esmi2 wrote:
Very very nice.
http://www.c-brats.com/modules.php?set_albumName=album3439&op=modload&name=gallery&file=index&include=view_album.php
bshillam
C-Dory Year: 1981
Photos: My Heaven
PostPosted: Sun Jul 03, 2022 11:28 am    Post subject: Update Reply with quote
Looking over the boat gelcoat is in need of repairs in several areas. So I am going to reduce the price to reflect the work I believe it should have.
$38k.
Bonus, has Wallas cooktop! Full camper back. Icebox was removed but not replaced. Build out drawers or fit in a better cooler/frigerator?
Boat is in Portland, OR.
bshillam
C-Dory Year: 1981
Photos: My Heaven
PostPosted: Tue Jul 05, 2022 10:04 pm    Post subject: Reply with quote
More pictures added to the album just taken a few days ago.
CB76
PostPosted: Sat Jul 09, 2022 12:27 pm    Post subject: Reply with quote
Hi Bill,
Interested in the boat, sent you a PM.
Chris
Looking for a C-Dory to call my own!
bshillam
C-Dory Year: 1981
Photos: My Heaven
PostPosted: Tue Jul 12, 2022 8:53 pm    Post subject: Reply with quote
https://www.youtube.com/watch?v=FU9Zl0x437s
https://www.youtube.com/watch?v=yp00w35t2lg
Tours of exterior and interior of the CD 22'
haakebecks
Vessel Name: Next Adventure
Photos: haakebecks (Name TBD)
PostPosted: Mon Jul 18, 2022 8:13 pm    Post subject: Reply with quote
Sent you a DM.
bshillam
C-Dory Year: 1981
Photos: My Heaven
PostPosted: Thu Jul 21, 2022 12:04 am    Post subject: Reply with quote
Offer received, pending.
bshillam
C-Dory Year: 1981
Photos: My Heaven
PostPosted: Tue Aug 02, 2022 5:09 pm    Post subject: Reply with quote
Check deposited, boat is considered Sold.
Thanks for everyones interest!
Page generation time: 0.0946s (PHP: 46% - SQL: 54%) - SQL queries: 29 - GZIP disabled - Debug on
