ijnorton
Joined: 16 Jun 2022 Posts: 4 City/Region: Friday Harbor
Vessel Name: Puka Kai
Photos: ijnorton
Posted: Fri Jun 17, 2022 10:51 am Post subject: Purchasing a C-Dory |
Hello all,
First post so I apologize if this is a repeat topic. I am currently in the process of purchasing my parent’s 2007 C Dory Cruiser 22 as it is a second boat for them. It has 260 total hours on a mercury 90 and seems to be in overall great condition mechanically (the outboard looks new). The older gentleman they got it from apparently wasn’t the greatest boater and struck a couple docks, causing gouges on the starboard side near the stern and a long scratch on the port side.
My parents roughly filled the gouges on the starboard side and I was told that the fiberglass was exposed slightly. The gouge on the port side has exposed fiberglass as well and has not been filled. Should I be concerned with water intrusion and is there a quick test to see?
Above the gouges on the starboard side also appears to be stress cracking. Should I be concerned with this? Everything else seems to be in great condition, it has low hours and is a great price.
Thank you! |
bshillam
Joined: 21 Aug 2007 Posts: 783 City/Region: Bellingham
C-Dory Year: 1981
Vessel Name: Heaven To Me
Photos: My Heaven
Posted: Fri Jun 17, 2022 12:29 pm Post subject: |
Use a moisture meter test a few areas around the damage and in non damaged areas to get a base reading. You can also take the boat to a fiberglass shop and have them take a look see. They'll be able to tell you if the substrate is damaged and how much to properly repair the gel coat too. I personally wouldn't be too worried about the vertical damage above the water line too much. Horizontal and anything below that has had fiberglass showing might be a different story. |
pcg
Vessel Name: C-Quest
Photos: pcg
Posted: Fri Jun 17, 2022 3:33 pm Post subject: |
Bare fiberglass will absorb moisture over time and should not be left exposed. Here's a great resource for DIY boat repair...
https://www.boatworkstoday.com/ _________________ Paul |
clayhubler
Joined: 03 Aug 2019 Posts: 372 City/Region: La Center
Vessel Name: Hammerhead
Photos: Merlin and Hammerhead
Posted: Fri Jun 17, 2022 4:57 pm Post subject: |
None of the areas you pictured are cored, so I wouldn't be concerned about water intrusion. Also, the scratches look relatively minor. The stress cracks look like the boat smacked a piling or something, but again, I wouldn't be concerned if the boat is a good price.
I would recommend doing a very thorough inspection of the boat that would include having a surveyor check for wet core. Do not let the relatively low hours lull you into a lax inspection. _________________ Clay
Hammerhead
2003 22’ Cruiser
Merlin
1986 26’ Cruiser |
Joined: 02 Nov 2003 Posts: 21469 City/Region: Pensacola
Posted: Fri Jun 17, 2022 8:37 pm Post subject: |
From the photos posted, and description, I would not worry about water intrusion. If there is/was, fiberglass exposed, it should be filled and then gel coated.
Good luck with purchase of your parent's C Dory. Nice legacy to pass down! _________________ Bob Austin
