Merc50 imploded/exploded VST float
zuunami
City/Region: Fort Bragg
Vessel Name: Oh Buoy!
Photos: zuunami
PostPosted: Tue Jun 07, 2022 5:55 pm    Post subject: Merc50 imploded/exploded VST float Reply with quote
Our Mercury 50hp (2006), running great until a few weeks ago, started spewing fuel. On taking it apart, it appears that the float inside the VST has either imploded or exploded! Smile We've ordered the parts to fix it, but wonder if anyone has any idea why this might happen? thanks! - Karen
Byrdman
Photos: FreeByrd and C-Byrd
PostPosted: Wed Jun 08, 2022 3:38 pm    Post subject: Reply with quote
Thankfully no fire!
Hope parts are available.
Patrick Byrd "Byrdman"
Miss B - CD22A, Aug 2018
Aloysius, Hull # 440 RF-246
TC24, Hull #51, Sold Feb06
CD16A, Sold Dec03
PostPosted: Wed Jun 08, 2022 6:33 pm    Post subject: Reply with quote
I'd hate to lose an engine off FT. Bragg, that's open ocean.
Whats a VST?
In ignorance, Boris
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Wed Jun 08, 2022 7:51 pm    Post subject: VST. Vs FSM Reply with quote
On Yamaha you have a Vapor Separator Tank
On newer Mercury they call it a Fuel Supply Module
They both do the same thing .They usually have a lift pump to pull up from the fuel tank and then there’s a high pressure pump for the fuel rail ( fuel injection) engines
So what might have happened your lift pump didn’t shut off ( there’s a. Float that can jam up ) and pressure built up cracking the plastic casing or just a very old engine with plastic FSM that cracked You might have to buy the whole FSM ?Good Luck
zuunami
Photos: zuunami
PostPosted: Thu Jun 16, 2022 7:37 pm    Post subject: Reply with quote
thanks folks, we replaced the imploded float and associated parts (still $150 but better than $1k for the whole unit), and it runs great again.
Thanks Jennykatz for the possible cause, it's a mystery to us still, but will look at the lift pump as a potential cause. The motor is an original 2006 to the boat, and from the history we have, not used much. But at least all is well now Smile
jennykatz
City/Region: naples
Photos: Jennykatz
PostPosted: Mon Jun 20, 2022 7:19 pm    Post subject: Vst Reply with quote
Make sure you change out your water /gas separator filter (I change mine every 50 hrs also same with your eng filer and try to use non ethanol gas Good luck
zuunami
Photos: zuunami
PostPosted: Mon Jun 20, 2022 10:17 pm    Post subject: Reply with quote
Thanks, did both. No non ethanol fuel anywhere near here Smile We use Mr. Filter when we get our gas, not sure if it helps or not, but can't hurt Smile
Page generation time: 0.0261s (PHP: 64% - SQL: 36%) - SQL queries: 24 - GZIP disabled - Debug on
