Why does my steering stiffen up at speed?
Roamad
City/Region: Sacramento
C-Dory Year: 1988
C-Dory Model: 22 Classic
Vessel Name: Fika
Photos: Roamad
PostPosted: Sun Mar 27, 2022 7:07 pm    Post subject: Why does my steering stiffen up at speed? Reply with quote
My steering spins just fine at the dock and at low speeds. But once I open up the throttle, the wheel gets very hard to turn — two hands required! What’s going on and how do I fix this?
Now: 1983 22’ C-Dory Classic, 2001 Honda 90hp
Then: 1988 16’ C-Dory Angler, 2008 Mercury 60hp
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Sun Mar 27, 2022 8:32 pm    Post subject: Reply with quote
Roamad,
Do you have push-pull cable steering, or hydraulic steering?
Steve Baum
Homeport of Portsmouth, VA
NORO LIM
City/Region: Olympia
Photos: NORO LIM
PostPosted: Sun Mar 27, 2022 8:44 pm    Post subject: Reply with quote
Is turning hard in both directions? Did the problem crop up suddenly? Had the boat been sitting for a while before the problem started?
You definitely want to look into this. Losing control, especially at higher speeds - YIKES!
Bill, Formerly on NORO LIM
2001 CD 16, 2001-2006
2006 CC 23, 2006-2014
Roamad
C-Dory Year: 1988
Vessel Name: Fika
Photos: Roamad
PostPosted: Sun Mar 27, 2022 10:01 pm    Post subject: Reply with quote
It’s cable steering with a single cable mechanism behind the helm. Issue has been there since I bought the boat about six months ago. It had an ancient 2-stroke that I had a mechanic replace with a newer (used) 4-stroke. No change in the problem with the engine swap. Previous owner told me he put in a new steering cable, and it does look new. But yes, the boat had been sitting for a long time when I bought it.
Almas Only
City/Region: Richmond
Vessel Name: Alma's Only
Photos: Alma's Only
PostPosted: Sun Mar 27, 2022 10:02 pm    Post subject: Reply with quote
When's the last time the motor's swivel case was lubricated?
2003 CD22 Cruiser with Honda 90
PostPosted: Mon Mar 28, 2022 12:09 am    Post subject: Reply with quote
On most of the boats I've owned, the steering got stiffer with speed. Try trimming the motor up (or down) to find the most efficient fuel burn, and that seemed to give me the most comfortable steering, as well.
srbaum
Vessel Name: Osprey
Photos: Osprey
PostPosted: Mon Mar 28, 2022 10:27 am    Post subject: Reply with quote
Roamad,
Do check the tips already suggested.
In my past experience, with older, well used mechanical steering systems, when the cable was worn out, the helm steering mechanism was also usually worn, so that a new cable did not improve the slop / and pressure in the system.
Also, most newer mechanical systems provide no-feedback alternatives
PostPosted: Mon Mar 28, 2022 12:01 pm    Post subject: Reply with quote
Is it harder to steer in one direction or the other? Maybe the trim tab needs adjustment.
Most systems get harder to steer with increasing speed due to the higher loads on the engine.
Roamad
C-Dory Year: 1988
Vessel Name: Fika
Photos: Roamad
PostPosted: Mon Mar 28, 2022 12:36 pm    Post subject: Reply with quote
Thanks for all the helpful replies. I sort of assumed the mechanic who installed the engine also lubricated all the steering swivel points on the motor and transom mount. He *was* very thorough, but I didn’t ask. So I guess I’ll start with that. I do know there are zerk fittings in a few places for that.
Motor trim doesn’t seem to affect the problem at all.
Also there are no obvious problems with the steering cable — no kinks or sharp bends or anything like that.
It’s just a bit puzzling that the problem remained after the engine swap, which suggests a problem with the steering mechanism and not the motor & transom mount. But if that is the case, why would it only occur at speed?
Barry Rietz
City/Region: Sierra Vista
PostPosted: Mon Mar 28, 2022 2:49 pm    Post subject: Hard to steer at speed Reply with quote
Since the original motor was removed and replaced with the 2007 model, the steering cable would have had to be disconnected. And since there is extreme force being applied to the motor pivot point when on plane, I would check to see if the steering cable may not have been tightened sufficiently. At least start your diagnosis at this point first and work forward. Please reply back with your findings.
Barry Rietz
N9DXC
PostPosted: Mon Mar 28, 2022 2:50 pm    Post subject: Reply with quote
As the speed increases, the dynamic pressure of the water increases as the square of the speed. This should make the steering stiffer, since it makes the motor/rudder harder to turn. One can overcome this with a balanced rudder, where the axis of rotation (steering axis) is divided, fore and aft. Outboard motors don't have this feature, so I would expect the motor is harder to turn at higher speeds.
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Mon Mar 28, 2022 2:56 pm    Post subject: Re: Why does my steering stiffen up at speed? Reply with quote
Trim the motor up.
PostPosted: Mon Mar 28, 2022 3:19 pm    Post subject: Reply with quote
There is something to be said for steering to stiffen as speed increases. This helps limit sudden large steering inputs that could have negative effects if done at speed. However, the stiffening should not result in the inability to actually steer the boat.
My boat has hydraulic steering and there is a definite increase in the helm wheel force as the speed increases. I expect this to happen and it helps keep the boat on course at higher speeds.
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Tue Mar 29, 2022 9:34 am    Post subject: Reply with quote
Trimming the motor up sure does help as others noted. But something isn't right. What? Beats me...But if it did with 2 different motors, I'd be looking at the steering cable and it's casing very carefully.
PostPosted: Tue Mar 29, 2022 5:45 pm    Post subject: Reply with quote
Check to be sure the new cable push pull steering is a "non feed back system". What this means is that the pressure on the cable is not pushed back on the helm. If you have a NF system, it will be much easier to steer. A motor that small should don't be an issue. The NF systems are a few dollars more expensive, but well worth it. The helm itself is less than $150.
There may be something binding when the boat comes up to speed, and pressure is on the steering tube. Even if greased--it may pay to put further grease, until if is oozing out of the end of the tube. Then with steering disconnected, try turning back and forth--see if any place is binding.
Page generation time: 0.0917s (PHP: 69% - SQL: 31%) - SQL queries: 32 - GZIP disabled - Debug on
