Tomcat Electronics dash removal
SounderSolutions
City/Region: Whidbey Island
Vessel Name: Frequent-C
Photos: FREQUENT-C
PostPosted: Mon Jan 24, 2022 12:17 am    Post subject: Tomcat Electronics dash removal Reply with quote
Good evening all! I am trying to figure out how to remove the dash above the helm on a 2009 Tomcat. I have two radios that need to be replaced but cannot get the dash loose. I thought maybe the buttons would unscrew but no luck.
Any hints or help would be appreciated.
Steve and Launa
Frequent-C (2009 Tomcat 255)
2009 Trophy Pro 2359
Frequent-C (2006 Tomcat 24)
Tired Again (2011 Thundjet Luxor)
PostPosted: Mon Jan 24, 2022 10:36 am    Post subject: Re: Tomcat Electronics dash removal Reply with quote
Are you talking about the shelf in the overhead? Don't know about the Tomcat, bit on my 22 cruiser the fit is really, really tight. The shelf can only be removed on hot days when the cabin expands due to the heat. Even then it is a tight fit.
PostPosted: Mon Jan 24, 2022 10:44 am    Post subject: Reply with quote
How about a photo? The buttons could cover screws. "Buttons" usually pop right off. I don't remember anything like that on my 2006 TC 255.
Can you access this area from the bunk forward of the console?
SounderSolutions
Photos: FREQUENT-C
PostPosted: Mon Jan 24, 2022 7:49 pm    Post subject: Reply with quote
Yup, that's the shelf/dash I'm talking about. It houses the stereo and VHF which I would like to replace.
I will post a photo when she comes back from the rigger. Getting a couple items installed before the big splash day.
The forward part of it butts right up to the bulkhead above the windows. No access that way that I can see. I thought maybe the buttons unscrewed but no luck. Maybe they pop off?
PostPosted: Mon Jan 24, 2022 9:09 pm    Post subject: Reply with quote
If it is the shelf above the driver in the center of the boat, earlier boats had that held in place by the same bolts which held the outside hand rail in place.
Buttons would pop off if they are covering a screw.
gulfcoast john
City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
PostPosted: Mon Jan 24, 2022 10:42 pm    Post subject: Reply with quote
Agree, measure topside rail mount distances compared to inside rail mount distances to confirm. Top and bottom rail mounts bolt into each other. Clever.
Cheers!
John and Eileen Highsmith
2010 Tom Cat 255, Cat O' Mine
2024 Yamaha F150xsa x2
SounderSolutions
Photos: FREQUENT-C
PostPosted: Mon Jan 31, 2022 10:18 am    Post subject: Reply with quote
With the boat back from the shop and all your input, I have it figured out. I had never seen a button covering a screw like this before. Appreciate the help!
Steve C
ricka
City/Region: Yreka
C-Dory Year: 2020
Photos: ricka
PostPosted: Mon Jan 31, 2022 11:34 am    Post subject: Reply with quote
Our overhead is held up with screws which are covered with the upholstered buttons, just use something flat to pop the button off to gain access to the screw head.
Hope this helps
previuos vessels
1976 ORION TRIHULL 15
1984 BOSTON WHALER 17 MONTAUK
1996 BOSTON WHALER 21 CONQUEST
2006 BOSTON WHALER 17 MONTAUK
Page generation time: 0.0434s (PHP: 64% - SQL: 36%) - SQL queries: 25 - GZIP disabled - Debug on
