And so it begins Bottom Painting
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Mon Jan 10, 2022 7:14 pm    Post subject: Reply with quote
All the sanding is done. Next is to dewax again and I can start the barrier coat.
Jody Kidd
KE7WNG
Northern, Utah
pcg
City/Region: Sherwood
Vessel Name: C-Quest
Photos: pcg
PostPosted: Mon Jan 10, 2022 8:22 pm    Post subject: Reply with quote
I'm curious why some want to raise the bottom paint line several inches. Why?
Paul
PostPosted: Mon Jan 10, 2022 9:15 pm    Post subject: Reply with quote
Depending on the load on the boat, the actual waterline can be a number of inches higher than the colored part of the lower hull (boot stripe) particularly at the stern. Raising the paint line protects the parts of the hull that are in the water. The factory should raise the color line of the lower hull a bit in the build process.
PostPosted: Mon Jan 10, 2022 9:54 pm    Post subject: Reply with quote
Totally agree that the factory should raise their bottom color pan. Their lines are based on an empty boat, without an engine. I raised mine to the bottom of the next strake line. Also raised the bow to follow that strake line forward to just below the tow loop. That was to keep from growing a seasonal moustache from slow cruising, especially in tannic water.
This is the old line level
jkidd
PostPosted: Tue Jan 11, 2022 8:21 am    Post subject: Reply with quote
I ended up raising the waterline 4 inches and that should be pretty close to right for what I carry. My guess is the boats with the glass interior and the glassed in rear deck weigh at less 400 lbs heavier than the factories bad missed published weight. I sure wish they would weigh one of the new hulls and correct that. At Yellowstone Jay and I were comparing how his boat sits in the water as to mine and mine sits a lot deeper than his.
jkidd
PostPosted: Wed Jan 12, 2022 10:22 pm    Post subject: Reply with quote
First coat of epoxy.
jkidd
PostPosted: Thu Jan 13, 2022 9:34 am    Post subject: Reply with quote
I put the second coat of epoxy on and here is some info that might be useful.
Two coats and I have reached 10 mils of thickness. The can says you want to be 12 mils thick for the barrier coat to do its job.
It takes 2 quarts to do the bottom of the boat so a gallon will do two coats.
I am going to put the third coat on today and will see where that puts me. I was planing on at least 4 coats.
Oh and did I say I hate painting !!!!
zuunami
City/Region: Fort Bragg
Vessel Name: Oh Buoy!
Photos: zuunami
PostPosted: Fri Jan 14, 2022 2:04 pm    Post subject: Reply with quote
Hang in there, looks like you're doing a great job!
jkidd
PostPosted: Fri Jan 14, 2022 10:19 pm    Post subject: Reply with quote
4 coats and the epoxy is done.
Salmon Fisher
City/Region: Arlington
Vessel Name: Kim Christine
Photos: Kim Christine
PostPosted: Fri Jan 14, 2022 10:26 pm    Post subject: Reply with quote
Wow! You really saved a lot of money doing it yourself, even if it was a pain. I redid the bottom paint on the 25 we used to have. Wasn't as mechanically inclined as you so I took her to the local marina yard and paid to have her put up on blocks, but I cleaned and repainted. It lasted a good long while.
It was a pain for me, too, but a money saver, for sure!
Patrick and Kim Walker
2004 25 Cruiser-Present
1985 22 Classic -2019 (Sold)
jkidd
PostPosted: Tue Jan 25, 2022 12:42 pm    Post subject: Reply with quote
Ok the bottom paint is on and the only thing left to do is move the stands and do the whole process again on the 3 8X8 spots.
PostPosted: Tue Jan 25, 2022 1:41 pm    Post subject: Reply with quote
Nice job Jody! Want to do mine next? Laughing
jkidd
PostPosted: Tue Jan 25, 2022 8:26 pm    Post subject: Reply with quote
It will be a good project for you after you get that new shop built.
PostPosted: Tue Jan 25, 2022 8:50 pm    Post subject: Reply with quote
Yeah, you don't know how bad I'd like to have a nice warm shop big enough for the boat! Crying or Very sad Maybe once the wife retires and we move somewhere that doesn't hurt our face to go outside! (-14 forecast for tonight...) But I keep dreaming! Cool Colby
jkidd
PostPosted: Sat Feb 05, 2022 7:50 pm    Post subject: Reply with quote
All of the bottom paint is finished. Started making the new wheels to put the trailer under the boat again. It took about a half a day to get trailer out from under the boat with flat tires ( they don't roll very well when all 4 are flat) had to winch it out from under the boat. New wheels are 1/2" baltic birch plywood.
Page 2 of 3
Page generation time: 0.3157s (PHP: 18% - SQL: 82%) - SQL queries: 32 - GZIP disabled - Debug on
