dingy lift
Steveeverton
City/Region: Twin falls
State or Province: ID
Vessel Name: ValHalla
Photos: Steveeverton
PostPosted: Sun May 16, 2021 12:03 am    Post subject: dingy lift Reply with quote
Does anyone use a lift to load and unload a dingy from the roof of their boat?
PostPosted: Sun May 16, 2021 11:02 am    Post subject: Reply with quote
There have been several threads on this recently:
Here are photos of how I use the Garhauer Lift--on both 22 and 25--also Tom Cat, with a removable base plat.
. Link to album
PostPosted: Wed May 19, 2021 3:05 am    Post subject: Reply with quote
Just a hand up and overhead. 53 pounds -- Alaskan.
PostPosted: Wed May 19, 2021 12:11 pm    Post subject: Reply with quote
I just drag it over the bow rail. It's more awkward than heavy, so it's doable. Boat weighs less than 60 lbs. I do use a Garhauer davit to install the small outboard, however, as I can do it from the safety of the cockpit.
I suppose I could make a bar, like Dr Bob did, but it would take some testing to see if our davit actually has enough height/length to get the boat onto the roof. From looking at his pics, his davit seems much taller than ours. I've never tried but I can see the advantage of not wrestling with it on the foredeck.
PostPosted: Wed May 19, 2021 1:34 pm    Post subject: Reply with quote
Our davit on the 25 has a foot extra on the lower f the two vertical poles. It is only. a few dollars extra to extend--basically the cost of the SS pipes. Garhaueer is easy to work with for customization.
We used to lift all sorts of dinghies up onto decks--some in the 120# range. Most likely that is why we have back problems in our elderly years.
We have oriented our cockpit mount so that a motor can be transferred from the kicker mount to the dinghy along side of the C Dory. We have also used similar davits, but custom made in our larger boats to pick up motors up to 25 hp from larger dinghies.
Page generation time: 0.0488s (PHP: 39% - SQL: 61%) - SQL queries: 22 - GZIP disabled - Debug on
