Seastar helm wedge install?
CC Rider
City/Region: Tsawwassen
Vessel Name: CC Rider
Photos: CC Rider
PostPosted: Sat May 01, 2021 12:37 pm    Post subject: Seastar helm wedge install? Reply with quote
Just wondering if anyone has installed this wedge on their helm?
https://www.amazon.ca/SeaStar-degree-Dash-Mount-Wedge/dp/B0000AXYNB
If anyone has, did you like the results? How was the install?
Is there a procedure to disconnect all the hydraulic lines, install the wedge and reconnect? I'm assuming the system will need to be bled....
Thanks in advance,
Chris
MMSI#: 316033635
PostPosted: Sat May 01, 2021 2:27 pm    Post subject: Reply with quote
I didn't use the wedge but I did cant the helm a bit so my legs would fit between the seat and the wheel. I didn't even know they made a wedge for it, and at the price listed I wouldn't have bought it anyway.
I just took the boat down to the marina so I will have to look at it for you later, but it seems to me I used extra nuts and washers on the mounting studs to jack out the bottom side to tilt it upward and was able to cover the gap with the bezel that came with it. Mine is the standard helm that mounts on the outside of the bulkhead.
Funny - right after I put it in years ago I mentioned on here that I wished I had bought the tilt helm model and Joel (SEA3PO) asked why I didn't just tip it up. It was a forehead slapping moment.
CC Rider
Photos: CC Rider
PostPosted: Sat May 01, 2021 8:56 pm    Post subject: Reply with quote
Thanks for the reply Mike.
I just installed a new helm seat, and raised it a few inches so that I could see out better (vertically challenged people need to do this) and sure enough, it's a pretty tight fit to get one's legs between the seat and the wheel.
I will take a closer look to see if it's possible to make a wedge, or just use spacers....sure would save a ton of work not having to disconnect lines. Thanks again!
Chris
Page generation time: 0.0416s (PHP: 58% - SQL: 42%) - SQL queries: 20 - GZIP disabled - Debug on
