C-Wolfe
Joined: 16 Sep 2020 Posts: 261 City/Region: Anchorage
Vessel Name: Valhalla
Photos: C-Wolfe
Posted: Tue Apr 13, 2021 9:04 pm Post subject: Removing old sealant. |
I had to remove the hatch in the v-berth because of a slow drip during rain. The core was wet but barely starting to rot, I decided to remove it on the 3 side since there is only about an inch of core or so, remove about 1-1/2 inch on the back side. I will refill with thicken epoxy, I do have marine plywood that I might use also. Any other recommendation as to the best process to fill the gap?
Alos, what will be the best product to use to remove the sealant stuck on the underside of the aluminum hatch frame?
![](http://www.c-brats.com/albums/album3247/IMG_2616.sized.jpeg) |
tsturm
Joined: 01 Nov 2003 Posts: 1136 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Tue Apr 13, 2021 11:22 pm Post subject: Re: Removing old sealant. |
C-Wolfe wrote: | I had to remove the hatch in the v-berth because of a slow drip during rain. The core was wet but barely starting to rot, I decided to remove it on the 3 side since there is only about an inch of core or so, remove about 1-1/2 inch on the back side. I will refill with thicken epoxy, I do have marine plywood that I might use also. Any other recommendation as to the best process to fill the gap?
Heat gun & wooden scraper ![Thumbs Up](images/smiles/emthup.gif) |
