New to me .... 1991 Pro-Angler! 😎
Gary5410
City/Region: Kempton
C-Dory Year: 1991
Photos: Gary5410
PostPosted: Tue Oct 13, 2020 1:49 pm    Post subject: New to me .... 1991 Pro-Angler! 😎 Reply with quote
Just picked up my 1991 C-Dory 21’ Pro Angler. Interesting, the motor capacity is 140 HP according to the sticker on the dash. ?? Thanks Jamison Thomas
1991 C-Dory 21’ Pro-Angler
PostPosted: Tue Oct 13, 2020 9:52 pm    Post subject: Reply with quote
Welcome aboard, and congratulations on the purchase. Is this the boat which was in Deland FL?
Ask the administrators for an album so you can post some photos. The Pro Angler is a very rare boat. (Da Nag and TyBoo are the administrators).
Gary5410
C-Dory Year: 1991
Photos: Gary5410
PostPosted: Fri Apr 09, 2021 2:33 pm    Post subject: Reply with quote
Yes, from Deland, Florida
PostPosted: Fri Apr 09, 2021 2:53 pm    Post subject: Reply with quote
pictures or it never happened. There was one in this area that was a open top but with windshield and powered by a jet. How much v does your hull have?
Gary5410
C-Dory Year: 1991
Photos: Gary5410
PostPosted: Fri Apr 09, 2021 5:07 pm    Post subject: Reply with quote
Not sure how to post pics...
Gary5410
C-Dory Year: 1991
Photos: Gary5410
PostPosted: Fri Apr 09, 2021 10:33 pm    Post subject: Reply with quote
https://gary5410.smugmug.com/C-Dory-21--Pro-Angler/Pro-Angler/i-GmV9jTK
Can anyone tell me what type, size anchor goes with this anchor roller bracket? Look at other pics to see bracket
https://gary5410.smugmug.com/C-Dory-21--Pro-Angler/Pro-Angler/i-2xMfDSs
clayhubler
City/Region: La Center
Vessel Name: Hammerhead
Photos: Hammerhead
PostPosted: Sat Apr 10, 2021 1:05 am    Post subject: Reply with quote
That's the stock anchor roller from what I can tell. The size and type of anchor you are going to want will depend on where and what type of anchoring you are going to be doing. The anchor roller can be easily change out if the anchor that is best suited to your needs doesn't fit or work well with that roller.
The type of bottom where you are anchoring and the depth will determine what you need. Also if there is current, ect.... Lots of variables.
That is a cool boat. Has a lot more vee than my 22 cruiser.
Clay on Hammerhead
PostPosted: Sat Apr 10, 2021 1:22 pm    Post subject: Reply with quote
Any of the standard anchors will work well there. A 14" Delta, one of the Ronca, Mantus or Manson Supreme's in the similar size will work. A Fortress FX 7 is also a possible choice.
What is the bottom like where you will be anchoring most of the time? I see you are PA. Lakes or Salt water? How much fetch will there be?
PostPosted: Mon Apr 12, 2021 12:37 pm    Post subject: Reply with quote
That is a great looking boat. I bet that deeper v hull is good in the chop and tracks better then a flatter cdory hull.
Page generation time: 0.0405s (PHP: 48% - SQL: 52%) - SQL queries: 26 - GZIP disabled - Debug on
