22’ Cruiser Air Draft
sailorman718
City/Region: Leesburg
C-Dory Year: 2016
Vessel Name: C-Bird
PostPosted: Mon Jan 18, 2021 8:43 am    Post subject: 22’ Cruiser Air Draft Reply with quote
Howdy C-Brats. I’ve purchased a 2016 C-Dory 22’ Cruiser. I’ll pick the boat up on Feb 6th. I’m looking at dry stack storage options but am not sure of the height clearance for a 22. The roof has nothing mounted on top.
I’ve searched the site for an answer but no luck so far.
Anyone have a quick answer?
Thanks!
Mike Johnson
2016 C-Dory 22 Cruiser “C-Bird”
2004 C-Dory 22 Cruiser “C-Horse” sold 3/2018
Byrdman
Photos: FreeByrd and C-Byrd
PostPosted: Mon Jan 18, 2021 10:39 am    Post subject: Reply with quote
Mine is cross country...but I had to get a top shelf for mine at first but then as ski boats with high tower/arches and blearing sound systems became more common, the racks were adjusted in one of our local faculties. Our radar and AC systems add about 18". Sorry I can find my numbers... Good luck...
Patrick Byrd "Byrdman"
Miss B - CD22A, Aug 2018
Aloysius, Hull # 440 RF-246
TC24, Hull #51, Sold Feb06
CD16A, Sold Dec03
Karl Konecny
City/Region: Glide
Vessel Name: Nowhere Fast
Photos: Nowhere Fast
PostPosted: Mon Jan 18, 2021 11:25 am    Post subject: Reply with quote
The C-Dory web site lists 9'1" for the height on trailer for a CD-22, if that helps.
PostPosted: Mon Jan 18, 2021 1:43 pm    Post subject: Reply with quote
What you are looking for is the distance from the extreme bottom of the C Dory to the highest part of top of the cabin roof. Not what the boat is on the trailer.
You want the clearance for a storage rack. The headroom in a standard 22 is listed as 6' 2" . Having owned several. and shrunk with age and water, I think that is fairly close. Add in 2" for hull thickness below and 2" above, that would give you a minimum of 6'6". But the attitude of the boat aft may be deeper..the fork lift needs at least 8" clearance below the hull, and I sure would want a foot above the hull. So if I was spacing racks, I would want at least 8 1/2 feet to prevent scraping the cabin top and give clearance to work.
PostPosted: Mon Jan 18, 2021 1:51 pm    Post subject: Reply with quote
Probably between 7-8'. Midnight flyer on the water with a radome on the roof was just under 7' That was with a high top roof as well.
clayhubler
City/Region: La Center
Vessel Name: Hammerhead
Photos: Merlin and Hammerhead
PostPosted: Mon Jan 18, 2021 3:48 pm    Post subject: Reply with quote
I just went out and measured my 2003 22 cruiser. Top of cabin to keel is 6'-8". I measured right above the side windows towards the front of the cabin. Keep in mind that is the bare roof, and it is the standard roof, NOT the high top.
Clay
Hammerhead
2003 22’ Cruiser
Merlin
1986 26’ Cruiser
sailorman718
C-Dory Year: 2016
Vessel Name: C-Bird
PostPosted: Mon Jan 18, 2021 11:52 pm    Post subject: Reply with quote
Thanks all for this information.
Bob - I found this 2016 model and should be at Hontoon. We are staying in our RV at the KOA and will keep the boat there. Look forward to joining in.
Page generation time: 0.0365s (PHP: 62% - SQL: 38%) - SQL queries: 24 - GZIP disabled - Debug on
