sailorman718
C-Dory Year: 2016
Vessel Name: C-Bird
Posted: Mon Jan 18, 2021 8:43 am Post subject: 22’ Cruiser Air Draft |
Howdy C-Brats. I’ve purchased a 2016 C-Dory 22’ Cruiser. I’ll pick the boat up on Feb 6th. I’m looking at dry stack storage options but am not sure of the height clearance for a 22. The roof has nothing mounted on top.
I’ve searched the site for an answer but no luck so far.
Anyone have a quick answer?
Thanks! _________________ Mike Johnson
2016 C-Dory 22 Cruiser “C-Bird”
2004 C-Dory 22 Cruiser “C-Horse” sold 3/2018 |
Byrdman
Joined: 06 Nov 2003 Posts: 3320 City/Region: Cumberland River, Clarksville,
Photos: FreeByrd and C-Byrd
Posted: Mon Jan 18, 2021 10:39 am Post subject: |
Mine is cross country...but I had to get a top shelf for mine at first but then as ski boats with high tower/arches and blearing sound systems became more common, the racks were adjusted in one of our local faculties. Our radar and AC systems add about 18". Sorry I can find my numbers... Good luck... _________________ Patrick Byrd "Byrdman"
Miss B - CD22A, Aug 2018
Aloysius, Hull # 440 RF-246
TC24, Hull #51, Sold Feb06
CD16A, Sold Dec03
Never Deny Yourself The Pleasure of Helping Others. |
Karl Konecny
Vessel Name: Nowhere Fast
Photos: Nowhere Fast
Posted: Mon Jan 18, 2021 11:25 am Post subject: |
The C-Dory web site lists 9'1" for the height on trailer for a CD-22, if that helps. _________________ "Believe me my young friend, there is nothing-absolutely nothing-half so much worth doing as simply messing around in boats."
Rat to Mole, Wind in the Willows |
Joined: 02 Nov 2003 Posts: 20813 City/Region: Pensacola
Posted: Mon Jan 18, 2021 1:43 pm Post subject: |
What you are looking for is the distance from the extreme bottom of the C Dory to the highest part of top of the cabin roof. Not what the boat is on the trailer.
You want the clearance for a storage rack. The headroom in a standard 22 is listed as 6' 2" . Having owned several. and shrunk with age and water, I think that is fairly close. Add in 2" for hull thickness below and 2" above, that would give you a minimum of 6'6". But the attitude of the boat aft may be deeper..the fork lift needs at least 8" clearance below the hull, and I sure would want a foot above the hull. So if I was spacing racks, I would want at least 8 1/2 feet to prevent scraping the cabin top and give clearance to work. _________________ Bob Austin
Posted: Mon Jan 18, 2021 1:51 pm Post subject: |
Probably between 7-8'. Midnight flyer on the water with a radome on the roof was just under 7' That was with a high top roof as well. |
clayhubler
Joined: 03 Aug 2019 Posts: 280 City/Region: La Center
Vessel Name: Hammerhead
Photos: Hammerhead
Posted: Mon Jan 18, 2021 3:48 pm Post subject: |
I just went out and measured my 2003 22 cruiser. Top of cabin to keel is 6'-8". I measured right above the side windows towards the front of the cabin. Keep in mind that is the bare roof, and it is the standard roof, NOT the high top. _________________ Clay on Hammerhead
sailorman718
C-Dory Year: 2016
Vessel Name: C-Bird
Posted: Mon Jan 18, 2021 11:52 pm Post subject: |
Thanks all for this information.
Bob - I found this 2016 model and should be at Hontoon. We are staying in our RV at the KOA and will keep the boat there. Look forward to joining in. |
