PNW_Wesley
C-Dory Model: 19 Angler
Vessel Name: Zenith
Photos: Zenith
Posted: Wed Sep 30, 2020 9:37 am Post subject: Installing Hand-Holds on Windshield Visor |
I would like to install 2 hand-holds on the visor forward of the L + R windshields, similar to the factory ones in the cockpit.
These would only be intended to aid my balance as I move to/from the bow along the gunwale, and not for fenders or any loads.
If you have done this mod, could you please post a picture or 2?
Did you use a backing plate, or just fender washers?
I assume the visor is fiberglass without a core. _________________ Wesley and Karen
Prior water toys:
15' Smoker Craft
14' SOAR Inflatable Kayak
18' Sea Ray
28' Bayliner
19' Smoker Craft
16' Duracraft
14' Starcraft |
Joined: 27 Oct 2012 Posts: 3592 City/Region: SW Michigan
Posted: Wed Sep 30, 2020 12:48 pm Post subject: |
I did this to my boat, they are very useful. Sorry, don't have any pictures. It is an easy task. I just used fender washers. The brow on my boat is about 3/8" solid FG.
If you are adding rails, having some at the back outside roof top is also very handy. They are useful when getting onto the side walks from the cockpit and can be useful at the dock. I put 36" long rails on each side of mine. The rails bolt to the roof through the lip the runs outside of the cabin. |
Clewless
C-Dory Year: 1986
Vessel Name: Clewless
Photos: Clewless
Posted: Wed Sep 30, 2020 1:18 pm Post subject: |
The hand holds are very useful. These are 11" on center, very study with regular size washers.
Photo in my album |
Alyssa Jean
Joined: 02 Nov 2003 Posts: 2376 City/Region: Guemes Is.(Anacortes)
Vessel Name: Alyssa Jean
Posted: Wed Sep 30, 2020 2:39 pm Post subject: |
I added hand holds on the visor of my 25. Used fender washers. The visor is all fiberglass. _________________ David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51 |
Joined: 02 Nov 2003 Posts: 21505 City/Region: Pensacola
Posted: Wed Sep 30, 2020 3:54 pm Post subject: |
I have used regular washers. Installed on all of my c 'Dory, except Tom Cat which comes with a nice railing all around the front visor. _________________ Bob Austin
Posted: Wed Sep 30, 2020 7:56 pm Post subject: |
Mine:
This image shows the rails at the back of the cabin roof:
PNW_Wesley
Vessel Name: Zenith
Photos: Zenith
Posted: Thu Oct 01, 2020 10:18 am Post subject: |
Thank you for all of the excellent replies.
I will post some pictures when my project is complete. |
Posted: Fri Oct 02, 2020 1:56 am Post subject: |
Lots of good ideas here.
A couple of thoughts:
1. The older you get, as you get weaker and less steady, the more useful handholds become. Add them on the inside and outside as needed, keeping the cosmetic look of the boat the best you can. Be sure they're placed in the best, safest, most ergonomic position possible. Think it through.
2. Usually you want to use marine specific hardware outside, but inside, it's probably just as easy, and often much cheaper, to use regular stainless domestic safety hardware, as long as it looks "right". Stainless, whether 316, 304, or whatever, won't rust or corrode inside the cabin, unless you're on a long-term visit to Davey Jones Locker. Take a look at the safety handholds available at your favorite hardware store/outlet.
3. Lifelines, railings, and the like are often smaller in diameter than optimal for safety's sake. 3/4", 7/8", and even 1" diameters and such are really too small to fit into a man's full size hand comfortably and give the maximum griping strength or holding power. 1-1/4" and 1-1/2" diameter tubes often fit your hand better and afford a better grip. Do some experiments with your own hands and various diameters to see this in action.
4. Also, if I were placing a handhold somewhere it would often be wet and my life would depend on it, I'd add some non-skid tape to the fitting rather then depend on the polished metal to a provide life-saving grip. "Slippery does as slippery is", or vis-a-vis, your choice. -Anonymous.
Good Luck and Stay with the Boat!
