Posted: Sat Sep 05, 2020 4:25 pm Post subject: |
Quote: | "Would someone please explain why the "pivoting" anchor roller has advantages over the fixed type?" |
Barry, I think the advantage is that the pivoting one allows the anchor to self launch easier. For me, I had to move the swivel bolt about 1 inch for the self launch to work, but now it does, every time.
PNW_Wesley
C-Dory Model: 19 Angler
Vessel Name: Zenith
Photos: Zenith
Posted: Sat Sep 05, 2020 4:51 pm Post subject: |
clayhubler wrote: | I just put a pivoting bow roller on my 2003 22 and it was cored there.
Wesley- If you need only need a little epoxy and filler I have some and I believe you have my number from a previous PM. No need to buy it if that is the only thing you need it for. |
Clay - Thank you for your offer. I may also be doing some other mods, and I have on hand some materials for backing.
I don't have epoxy or filler, but I will order some to ensure I have enough. I'm not sure exactly what to order.
I will be using 3/8" bolts to mount the roller.
What is the diameter of the larger hole, for access to cut back the core?
How far back do I need to cut the core?
For the large hole, what type of bit did you use? Spade? Hole saw?
I have to admit, I am a little intimidated by drilling into my deck! |
Joined: 02 Nov 2003 Posts: 20818 City/Region: Pensacola
Posted: Sat Sep 05, 2020 7:08 pm Post subject: |
The 1990 vintage built boats may be entirely different than the later boats.
Same or similar deck molds have nothing to do with the coring. That has to do with the "lay up' and where the coring is placed.
The pivoting roller allows many anchors to be "self launching" when they are not with the solid roller. If don't want self lanuching--then.....
Yes, a photo which shows the "bulge' of the 3/4" deep coring will help. The hull to deck joint is an edge to edge joint, and not a "shoe box" joint where the top or deck molding drops over the hull molding. The hull to deck joint is glassed together on the inside, instead of an extrusion with a "H" section profile. Thus is much stronger than many hulls. This allows full inspection of the upper deck mold. _________________ Bob Austin
clayhubler
Joined: 03 Aug 2019 Posts: 280 City/Region: La Center
Vessel Name: Hammerhead
Photos: Hammerhead
Posted: Sat Sep 05, 2020 7:42 pm Post subject: |
The core doesn't need to be "cut back" really. Using a dremel tool with some kind of rotary file works to kind of ream out the core around the hole. I actually only drilled 7/16 holes and then sealed the core with epoxy because I thought that would suffice.
I suppose the best way would be to drill a 1/2 or slightly oversized hole through the top skin and core but not the bottom that way you could easily fill with thickened epoxy. Then drill your holes all the way through after it cures. _________________ Clay on Hammerhead
