center opening window
gary allen
City/Region: Santa Rosa
Vessel Name: Rosy B
PostPosted: Sat Feb 11, 2006 1:40 am    Post subject: center opening window Reply with quote
In an exuberant moment, my friend somehow broke off the the handle that tightens the hinge arm on the centering opening window on my 2004 22 cruiser. Now , of course, the window can't be left in an open position. Does anyone know where I should try to get a replacement. From the factory? From Diamond Sea Glaze, which I believe is the manufacturer?
Thanks...
oldgrowth
City/Region: Rochester
Vessel Name: C-Voyager
Photos: C-Voyager
PostPosted: Sat Feb 11, 2006 1:50 am    Post subject: Reply with quote
You can probably get it from either place, but if it was me I would check with the factory first.
Byrdman
Photos: FreeByrd and C-Byrd
PostPosted: Sat Feb 11, 2006 8:30 am    Post subject: Reply with quote
Rosy B/Gary: Sorry to hear about the accident, but it is great you and your friends are out loving and using your boat. They had a lot of odd and ends at the factory so I would for sure aske there 1st. Who knows what they have laying around.
The Fran Sea
City/Region: St Petersburg FL
Vessel Name: The Fran Sea
PostPosted: Sat Feb 11, 2006 8:39 am    Post subject: Reply with quote
I called the factory to get a second telescoping hatch adjuster so I could have two instead of just one holding the center window open. Offshore when fishing, if it's rough, with just one, the window slowly closes. They weren't very helpful and said I should call their supplier in Canada (forgot their name) and it would cost about $90 US! Rolling Eyes
I passed on that & figured I could get it from West Marine, probably for a lot less money............. let me know how you make out.
Roger on the
"The Fran Sea"
C-WEED
City/Region: New Brockton
State or Province: AL
Vessel Name: C-Weed
Photos: C-WEED
PostPosted: Sat Feb 11, 2006 10:42 am    Post subject: Reply with quote
Roger and Gary:
A simple solution for both problems is to remove the rod from the window. Using a drill press drill several holes about 1-1/2"s along the rod that would run left to right with the rod mounted. I use a finish nail with a slight bend in it. Open the window and slide the finish nail thru the hole and allow it to rest outside the window frame. This will keep the window open in any position when the going gets rough. No need for the plastic adjuster knob.
Chris
Byrdman
PostPosted: Sat Feb 11, 2006 10:58 am    Post subject: Reply with quote
C-Weed / Chris: Great idea. Also, that picture of C-Weed on Thanksgiving 2005 is an awesome picture. My guess is it is a sun set rather than sun rise due to the lack of moister in the air. What lake were you on?
Byrdman in Montgomery
Moxieabs
City/Region: Cape Neddick
State or Province: ME
Vessel Name: Widget
Photos: Widget
PostPosted: Sun Feb 12, 2006 11:33 am    Post subject: Reply with quote
There is a pic of a slightly fancier pin you can use in the Widget album. Works great.
Moxieabs on WIDGET
gljjr
City/Region: Fall City
C-Dory Year: 1982
Vessel Name: Migratory Dory
Photos: gljjr
PostPosted: Mon Feb 13, 2006 12:02 am    Post subject: Reply with quote
Here is the picture Moxie was talking about...
Great idea to use a standard R clip! But I would put a piece of fishing line on it attached to the hinge so you don't loose it! Smile
Gary Johnson
KB7NFG
gary allen
Vessel Name: Rosy B
PostPosted: Mon Feb 13, 2006 7:30 pm    Post subject: Reply with quote
Thanks for the good suggestions--the cotter pin concept is an elegant solution. Simpler is definitely better!
Gary
C-WEED
Vessel Name: C-Weed
Photos: C-WEED
PostPosted: Mon Feb 13, 2006 11:46 pm    Post subject: Reply with quote
Byrdman:
The same lake ol FreeByrd floats on... I would have thought we would have bumped into each other by now. That weekend I demo'd the boat for a couple down from Huntsville. Impressed, they ended up finding a 2000 22' at Three Rivers Marine. One with the six passenger seating. Maybe when they get done customizing their baby they might sign up and say hey.
Page generation time: 0.0429s (PHP: 58% - SQL: 42%) - SQL queries: 27 - GZIP disabled - Debug on
