Thru hull fitting
D&RLuke
City/Region: Meigs
State or Province: GA
Vessel Name: Salty Peach
PostPosted: Sun May 24, 2020 9:56 am    Post subject: Thru hull fitting Reply with quote
We have finally purchased a 2004 Cdory 25. I'm in the process of getting boat fitted out for us. While under boat on a creeper I noticed a vented thru hull fitting on the starboard side of keel approximately midship. Does anyone know what this is? I really don't care much for holes in the bottom of a boat. From all I know of boats their primary purpose is to keep the water on the outside. Kind of like the fan blade on the front an airplane is there to keep the pilot cool. Because if it stops you'll see him sweat. Very Happy
Gene Morris
City/Region: Eureka CA
Vessel Name: Reef Madness
Photos: Reefmadness
PostPosted: Sun May 24, 2020 10:29 am    Post subject: Reply with quote
Probably a wash down pick up. Is there a hose bib in the cockpit?
tight lines
D&RLuke
City/Region: Meigs
PostPosted: Sun May 24, 2020 11:35 am    Post subject: Reply with quote
That's what I was thinking but I don't see one. There is a ball valve under the step as walk in door
PostPosted: Sun May 24, 2020 11:42 am    Post subject: Reply with quote
That could be the inlet for the head. It is on Journey On, a 2005.
D&RLuke
City/Region: Meigs
PostPosted: Sun May 24, 2020 12:10 pm    Post subject: Reply with quote
Journey On after looking at it further I believe you are right. My project for today is to swap toilet to an airhead. So I probably will use that for raw water wash down. Thanks guys
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Sun May 24, 2020 5:10 pm    Post subject: Reply with quote
Salty Peach,
As to the Air Head, it is absolutely wonderful. I have one in my boat and to date, there has been zero odor, or maintenance issues. I know this is not the topic, but when you "head" down that path, feel free to ask questions.
Steve Baum
Homeport of Portsmouth, VA
PostPosted: Mon May 25, 2020 12:51 pm    Post subject: Reply with quote
When you change over to the air head, put a tee in the thru hull and cap off one end. That way you have a spare supply of water from the thru hull. I used bronze rather than PVC, schedule 80.
I use a tee to supply both the head and the washdown. They don't interfere with each other.
Page generation time: 0.0643s (PHP: 52% - SQL: 48%) - SQL queries: 24 - GZIP disabled - Debug on
