Heaters
Post new topic   Reply to topic    The C-Brats Forum Index -> The Galley
Izzy
C-Dory Year: 1992
PostPosted: Fri May 01, 2020 1:07 am    Post subject: Heaters Reply with quote
I have a 22 cruiser. Any recommendations for a Small, diesel heater? Where I did you install your heater in the cabin?
With gratitude,
Izzy
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Fri May 01, 2020 8:34 am    Post subject: Re: Heaters Reply with quote
With gratitude,
Izzy
I removed the ice box & put a Planar (Russian) diesel heater in.
Guy in Palmer sells them. WAY less complicated than espar or webasto, WAY less maintenance!! After 1500 hrs on mine I took it apart out of guilt, removed/wire brushed a teaspoon of soot out, good for another 1500-2000 hrs Thumbs Up
PostPosted: Fri May 01, 2020 10:12 am    Post subject: Reply with quote
I mounted a Webasto Heater in my Midnight Flyer. You can link over to the photo album and look for a nested album in regards to the heater install. It's a great little heater. In fact, I just ordered another one for the new to us, C-Traveler. For my install, I ordered the parts from 3 different companies as listed below. Colby
Scan Marine - Fuel tank & feed system - 367215 and 2027
Sure Marine - Exhaust insulation blanket - W001-434
- Mounting bracket - W005-216
- Exhaust thru hull - W002_170Nut
Ebay - Webasto Air Top 2000 STC Diesel Heater
Total cost about $1100.
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Fri May 01, 2020 10:57 am    Post subject: Reply with quote
I have a wallas cooktop and it's warm enough most of the time with its 6500 BTUs. I concede though, it isn't the best furnace or the best stove, but it does do both pretty well and doesn't take up lots of space. To supplement heat, which happens when it's really cold, I turn on my Buddy Heater and then it is just plain hot in the cabin with both going.
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
PostPosted: Fri May 01, 2020 11:50 am    Post subject: Reply with quote
I put in the littlest Espar in my CD 16 (in photo album). More than enough heat, in fact it will cycle completely off because even at the lowest setting it gets too warm in the dinky 16 cabin. That isn't great because it then needs to use the glow plug again to reignite, which uses way more electricity and fuel than if it could just reduce to idle. And it was $650 by the time I had all the necessary parts.
My new boat had an older Webasto 11 KW heater. When it cycled off it generally would not reignite without throwing the circuit breaker (Note: don't wire diesel heaters through a circuit breaker). The only part still readily available for it was the glow plug, and those are over $100. Time to replace. I was able to reuse the exhaust through-hull and some of the duct work, which saved a lot of time. And I quickly got $70 for it when sold for parts.
I replaced it with a Chinese model for $100. It has worked fantastic, although I've only used it for 30 hours. If you buy one of these, look closely at what comes with it. There are many options and you have to decide what gets you closest to what you need. Otherwise, you will spend a lot on little things like extra ducting, registers, or a remote control. https://www.ebay.com/itm/WARMTOO-8KW-12V-Diesel-Air-Heater-LCD-Thermostat-Tank-For-Truck-Boat-Trailer/402098403167?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
I got one with a remote control. I can now turn it on from the V berth. It has way more heating options than the old Webasto, including turning on at 6 o'clock every morning (not used as the remote is in the V berth), timed cycles, heat output limitations (whether max temp is reached fast or slow) and probably other stuff. The operation manual is comical in it's attempt to describe how to use the thing. How expensive could it be to have a native English speaker write the manual? I had to go on YouTube and find one of the several explanations of all of the various heating options. After reducing the maximum heat output, I mainly just use the little remote fob on/off and heat up/down.
It is only 8 KW but I haven't noticed any difference, probably because I added two more heat registers, one in the head and one in the V berth. The Webasto was set up only to put air into the main cabin. The new duct to the V berth is quite long and through unconditioned space so I was concerned that it would cool off too much and not provide heat that far away (the included duct work is not insulated). Since it was a straight run beginning about 5 feet from the heater, I used "pool noodle" 3 inch foam pipe insulation for that duct. No heat loss through that 8 feet. The entire boat is now evenly heated. I've only tried it in 40 degree weather, but I think it will do just fine in the snow.
Mark
PostPosted: Fri May 01, 2020 12:41 pm    Post subject: Reply with quote
colbysmith wrote:
I mounted a Webasto Heater in my Midnight Flyer. You can link over to the photo album and look for a nested album in regards to the heater install. It's a great little heater. ...
FWIW, a random Google search shows you can get the Webasto Air Top 2000 STC Diesel Heater from here for $744. Some accessories will add a little bit to that price.
https://www.heatso.com/webasto-air-top-2000-stc-gasoline-petrol-12v-heater-kit/?gclid=EAIaIQobChMIhMfGkIyT6QIV5SmzAB0BrAAHEAAYASAAEgIcj_D_BwE
PostPosted: Fri May 01, 2020 3:28 pm    Post subject: Reply with quote
I actually found my Webasto two days ago at an ebay seller for $683. That was about the best price. Several years ago I paid about 800 or so for it. However, it's the rest of the stuff that adds up quickly. The fuel tank with hoses and filter is $115, but then shipping added another $29. The exhaust thru hull is $147, 1' of insulating jacket that wraps around the exhaust pipe is $21 and I bought 3' just to make sure I had enough. The bracket, which one could probably make cheaper, but just makes installation a lot easier, was $51. Total cost $260 + $21 shipping. If you live in Washington near Sure and Scan Marine, you could save $50 on shipping. When I installed the Webasto in Midnight Flyer, I spent a lot of time tracking down everything I would need. I don't know if you can find the extra stuff for less at other dealers, but I didn't then, so I just used the same shops to buy that stuff again this time. You can find the Webasto Heater easily and just chose your cheapest seller. However, this is not a marine unit. You can just about double your expense by buying a marine kit thru a marine outfitter, and then you would get everything you need.
Regarding the Wallis, my wife and I discussed that stove/heater and I have discussed the Wallis with several other boaters. From what I understand the Wallis runs all the time if you use it. You can turn it on low or high or anywhere in between. However, it doesn't kick on and off like the Webasto or a regular furnace, to maintain temperature. So you could end up overheating, or not having enough heat. Most C-Brats I know that have a wallis say they turn it off going to bed, then turn it back on to take the chill out of the boat first thing in the morning. The only thing I don't like about the Webasto, is it is kind of loud. Like a mini jet engine firing up. But it puts out the heat when you boat in some really cold temps. I used it boaterhoming home a few years ago, where the outside temp got down to 18 degrees at night. I still woke up with 60 degrees in the boat. I only had one time where the Webasto stopped working and gave me an error code. It was during that same trip, and I don't know if the fuel had some moisture in it or not. But after shaking the tank a little, moving the pickup tube, and attempting to restart it several times, it finally lit off. The next day I dumped some "heat" additive in it, and didn't have any other problems. The other reason we decided not to go with the Wallis is my wife wants her countertop space. And a brand new Wallis is $2800. So, not putting Wallis down. It's just that the Webasto serves our purpose much better.
Alsp there are some really cheap Chinese knockoff units out there, and I know at least one C- Brat that bought one and installed it and I think it worked well for them. I asked our mechanic at the school bus garage about the units. He use to service semis, and stated the Webasto's were solid units that held up very well, and that I should stick with that rather than going to a knock off.
Colby
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
PostPosted: Fri May 01, 2020 4:46 pm    Post subject: Reply with quote
Ssobol,
Your link is to a gasoline (petrol) heater. I couldn't find anywhere that gasoline fired heaters met USCG requirements, probably because people wouldn't think to blow the bilge before using the heater.
I had a heater in a old petrol Mercedes where one could set it to come on every morning so that the car was warm (including the engine oil). Probably fine except that my car was in a garage under my bedroom. I was afraid to ever use it. I thought about ordering a gasoline heater for the Limpet with its open cockpit, but for the amount of diesel that these use the small tanks are good for weeks of heating.
The reason that I said not to run these through a circuit breaker and only use the provided inline fuse is because the have a necessary cool down cycle. A fancy little electrical panel is inside the heater unit. If somebody simply throws a circuit breaker, the fan stops and the residual heat in the heat exchanger melts the cover and circuit board. You can buy Chinese knockoff boards on Ebay, but probably only work (maybe) on the knockoff units. I don't know about the cost of replacement boards for the big name brands.
Mark
PostPosted: Fri May 01, 2020 6:21 pm    Post subject: Reply with quote
Here is another vote for the Espar or Webasto heaters.
I got a used Espar heater that had been removed from a truck. Kind of expensive - it cost me two half racks of Mexican beer (fortunately not Corona) for the stove and controller plus a few hundred bucks for all the ducting, exhaust and fuel pump. Still way cheaper than one trip to the Wallas repair shop.
I used the Wallas for 15 years, and it was 8 years old when I got the boat, so it served me well but it made a few trips to the repair shop so it was pretty costly in the long run. It was nice, and worked as both a heater and a stove. But now that we have the induction cooktop and the ducted, thermostat controlled, forced air heater I would never consider going back to the Wallas.
The Espar is installed under the galley counter. That is where the thru hull exhaust fitting for the Wallas already was so there wondering about some other place to put it. You really do not need a lot of room for the heater, but the exhaust tubing needs to have planty of air space around it. Mounting under the counter worked well for me, and I was able to get it low enough to let me use the hole in the countertop for a resessed mounting spot for the induction cooker.
Lew 25
City/Region: Billings
State or Province: MT
Vessel Name: CAT CLAW
PostPosted: Mon May 11, 2020 12:34 am    Post subject: Reply with quote
Wallas operator's manual "The heater is intended for use at sea level".This is the 1300 model. Does anyone know what other manuals state of the other diesel heaters? Lew
PostPosted: Mon May 11, 2020 1:53 am    Post subject: Reply with quote
I don't remember anything in the Webasto manual about elevation. I know it works going thru the Rockies. Smile
TyraNoah
City/Region: Santa Monica
PostPosted: Tue Jun 08, 2021 9:03 am    Post subject: Re: Heaters Reply with quote
With gratitude,
Izzy
Hello Izzy.
May you kindly let me know where you acquired it from?
I'd like to have one too,
Seems so useful.
PostPosted: Tue Jun 08, 2021 2:32 pm    Post subject: Re: Heaters Reply with quote
TyraNoah wrote:
With gratitude,
Izzy
Hello Izzy.
Seems so useful.
Peter & Judy
City/Region: Olds
State or Province: AB
Vessel Name: Mistaya
Photos: Mistaya
PostPosted: Wed Jun 09, 2021 10:49 am    Post subject: Reply with quote
I installed a Wabasto under my counter last year. Due to covid travel restrictions I have not tested in real life on the water situations yet. In test mode at home it works well.
I bought mine as a complete kit from Cummins in Calgary. I did have to buy a through hull exhaust port from a marine dealer.
Peter & Judy Haase
Buffalo Horn Ranch
HMCB Mistaya
PostPosted: Wed Jun 09, 2021 1:03 pm    Post subject: Reply with quote
I initially bought mine thru Amazon for a great price. It turned out to be a Russian seller and after 2 months I gave up waiting and went through Cummins here in the states. Good outfit with fast shipping and rates were competitive with other North American companies. Thru-Hull and fuel tank purchased as I posted earlier.
Post new topic   Reply to topic    The C-Brats Forum Index -> The Galley All times are GMT - 5 Hours
Page generation time: 0.0346s (PHP: 78% - SQL: 22%) - SQL queries: 32 - GZIP disabled - Debug on
