Posted: Thu Apr 16, 2020 9:39 pm Post subject: |
HI John,
What I noticed right off was that the tread depth did not look "normal" but the tires look new. I have not been over to measure them yet but will get to that somewhere before I pull the boat out (if) for some cruising.
".... Now retired, we plan on relaxing my ‘replace at 36-48’ to a ‘48-60’ month regimen since a blowout doesn’t devastate our plans so much."
A blowout can devastate more than just plans. Not sure how much I's stretch out those numbers. A blowout can do severe damage to more than plans -- like trailer and hull damage. Really not worth the gamble I think.
My trailer is inside, out of the sun, we don't get that much heat here. If I don't tow this season, I might add a year on the other end of my 5 year tires this time. Will need to see what they look like buy the. (Might also even have a Tire Pressure Monitor System on board by then.)
Maybe see you at Hontoon next time around. Stay safe.
SleepyC
SeaSpray
Joined: 12 Mar 2004 Posts: 1007 City/Region: Brentwood, CA
Vessel Name: SeaSpray
Photos: SeaSpray
Posted: Tue Jul 28, 2020 3:13 am Post subject: |
I am currently looking at new tires. My last all new set were Goodyears. I guess it was when they were having problems because I had 2 blowouts and one near miss. A trucker stopped me before it could blow out.
The Endurance sound good, but how do you know the set you buy won't be when the are having a problem with manufacture.
My local tires shops all say they are allowed to sell tires up to 23 months past the date code. They also say they are allowed to repair tires under 10 years old and that the life of tires is 10 years, if the tread is good and no damage.
I am also hearing that because of the Covid, some shops are running out of trailer tires. Lots of people are buying and using RVs and boats.
Seems like you just have to make a choice and hope for the best.
Steve |
Posted: Tue Jul 28, 2020 8:21 am Post subject: |
I reiterate my last post here towards the top of the previous page. Also with upgrading to a 25 I recently purchased some new 16” LR E Carlisles for $86/ea on Amazon. |
Deluke
State or Province: GA
Vessel Name: Miss Adventure
Photos: Miss Adventure
Posted: Tue Jul 28, 2020 8:02 pm Post subject: |
On my equipment trailers I’ve gone to Goodyear Unisteel G614 RST Radial Tire - 235/85R16 126R. I’ve just installed a set on the 25. I have used every brand. For better or worse Or might I say richer or poorer. I will only buy USA made tires now. So far I have had really good service from them. |
Chester
Photos: Chester
Posted: Wed Jul 29, 2020 1:17 am Post subject: |
SeaSpray wrote: | My last all new set were Goodyears. I guess it was when they were having problems...
Steve |
Tho old GY Marathon became crappy when GY was moving their production from country to country. Things have changed.
The tire stores can tell you they can sell old tires but you don't have to buy them. |
Posted: Wed Jul 29, 2020 2:19 am Post subject: |
When I finally decided on getting the tires, I went to my local Les Schwab and asked specifically for "USA made, nothing older than a 3 month from manufacture date, Goodyear Endurance with my size and load range (D)" The local said they didn't think they could get them. I called a LS shop in Portland that I have dealt with for many years, and they said "yes, we can get them but it might take a bit" so I told them to go ahead and call me when they are in. I checked them, USA made, stamped as such and were 2 months from mfg to tire store. Another reason I like working with Les Schwab tire stores.
That was right at the beginning of Covid, but I took the wheels off the trailer and put them in the truck, delivered them to the PDX LS shop and had new tires on and was on the way home in an hour.
And even though they are GY tires, I bought them from LS so have the full Les Schwab service warranty and they will honor that in 6 PNW states.
Steve, I would find a shop that will deal with you.I think Discount Tire can get and sell GY.
SleepyC
Chester
Photos: Chester
Posted: Wed Jul 29, 2020 2:16 pm Post subject: |
Discount Tire is where I bought the GYs now on the trailer. |
Posted: Wed Jul 29, 2020 2:26 pm Post subject: |
Chester wrote: | Discount Tire is where I bought the GYs now on the trailer. |
Does Discount Tire do free flat repair, rotation, and balance checks. That is the main reason I do Les Schwab, except that they run out to meet me when I drive into the parking lot.
SleepyC
Catskinner
C-Dory Year: 2022
Vessel Name: Dock Holiday
Photos: Dock Holiday
Posted: Thu Jul 30, 2020 12:38 pm Post subject: |
Several years ago I switched over to LT tires. My tire problems have disappeared! They tow great! I use Maxxis 751 LT Bravo Radial. |
Chester
Photos: Chester
Posted: Thu Jul 30, 2020 8:57 pm Post subject: |
hardee wrote: | Chester wrote: | Discount Tire is where I bought the GYs now on the trailer. |
SleepyC
They do for my car and did for my Jeep. I assume they would for the trailer.
On my Jeep they really earned their money. About but 4 times a year they'd have to clean debris, usually bark, out of the beads to fix the slow leaks. One time a tire had an 11" gash in the sidewall and they replaced it without any fuss. These were BFG mud tires. |
Posted: Fri Jul 31, 2020 2:06 am Post subject: |
Thanks Steve. I may need to branch out when I start expanding horizons out of the NW corner.
SleepyC
Posted: Mon Aug 03, 2020 2:15 pm Post subject: |
Never really got to IF or WHICH is better for valve stems for a boat trailer, OR why, (at least in my mind), so stuck with the Stainless Steel stems. Looks like there are good reasons for either.
I do have a Tire Pressure Monitoring system on my motorcycle and am considering it for the trailer (and maybe the trick too), So far, my short aluminum baseball bat has been pretty accurate - bump bump
Will save the TPM for a different thread. ( The one on the bike times out and has to be reset every 30 minutes.
SleepyC
