johnbenj
Joined: 14 Jul 2007 Posts: 110 City/Region: Bainbridge Island
C-Dory Year: 1990
Vessel Name: Amoreena
Photos: Rabbit Rabbit
Posted: Sun Apr 12, 2020 2:03 am Post subject: Part name for the plate where the steering rod connects? |
What is the name of the part of the Honda BF90 engine which the steering rod connects to push and pull and turn the engine? Mine is so rusty i don't think it is safe anymore and I'd like to try and replace it.
Thanks in advance
John |
tomherrick Guest
Posted: Sun Apr 12, 2020 8:38 am Post subject: |
Not exactly certain which part you mean, but you might find it in one of these two pages from a 2004 Honda Rigging Guide.
johnbenj
C-Dory Year: 1990
Posted: Sun Apr 12, 2020 12:01 pm Post subject: Steering arm |
Thanks! In the second page it is called "steering arm." Mine is almost rusted away so now I need to find if it is replaceable. |
tsturm
Joined: 01 Nov 2003 Posts: 1173 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Sun Apr 12, 2020 12:10 pm Post subject: Re: Part name for the plate where the steering rod connects? |
johnbenj wrote: | What is the name of the part of the Honda BF90 engine which the steering rod connects to push and pull and turn the engine? Mine is so rusty i don't think it is safe anymore and I'd like to try and replace it.
Thanks in advance
John |
If I recall correctly(50/50 crap shoot) the piece your describing is a cast steel bracket, bolted to cast steel engine swivel bracket.
To remove the two bolts & replace it might cause more broken bolt, drilling & tapping, cussing, throwing stuff & headache than it's worth it. It's a pretty substantial cast piece, I would scrape, file, sand etc. & see how much metal is there & paint as nec.
Or the 2 bolts will come off just fine & you put on a new one in 10 minutes & away ya go.  |
tsturm
Photos: JMR-TOO
Posted: Mon Apr 13, 2020 3:27 pm Post subject: Re: Part name for the plate where the steering rod connects? |
tsturm wrote: | johnbenj wrote: | What is the name of the part of the Honda BF90 engine which the steering rod connects to push and pull and turn the engine? Mine is so rusty i don't think it is safe anymore and I'd like to try and replace it.
Thanks in advance
John |
Lets try a pict http://www.c-brats.com/modules.php?set_albumName=JMR_II&id=BF_90_1&op=modload&name=gallery&file=index&include=view_photo.php
It looks like my memory was the wrong 50% but close, with luck & the studs instead of bolts you might get by with the bracket. |
johnbenj
C-Dory Year: 1990
Posted: Mon Apr 13, 2020 3:51 pm Post subject: Re: Part name for the plate where the steering rod connects? |
Thanks very much. From more research, and your comments, I am going to try sanding off what ever loose rust i can and using a Rustoleum / POR-15 product.
Thank you! |
Posted: Mon Apr 13, 2020 4:33 pm Post subject: |
The arm is $46 at boats.net and if you figure in the cost of the rust spray and the top coat you're money ahead by ordering a new one and replacing it. You have to pull it off anyway.
Boris |
johnbenj
C-Dory Year: 1990
tsturm
Photos: JMR-TOO
Posted: Mon Apr 13, 2020 5:30 pm Post subject: |
That will Clean up just fine & be good for another 20 yrs  |
tomherrick Guest
johnbenj
C-Dory Year: 1990
Posted: Mon Apr 13, 2020 7:15 pm Post subject: |
Hi Tom - that URL takes me to the top-level of all the diagrams. Could you tell me which assembly diagram you are looking at?
john |
Yakmandu
Joined: 03 Nov 2017 Posts: 70 City/Region: Lake Lanier
State or Province: GA
C-Dory Model: 19 Angler
Vessel Name: Miss April
Photos: Pops GO!
Posted: Mon Apr 13, 2020 7:47 pm Post subject: |
Looks like “Stern Bracket -Swivel Case” page.
Good luck! _________________ Patrick Rohde
Miss April
Lake Lanier, GA |
johnbenj
C-Dory Year: 1990
Posted: Mon Apr 13, 2020 8:14 pm Post subject: |
Yakmandu wrote: | Looks like “Stern Bracket -Swivel Case” page. |
Thanks! |
tsturm
Photos: JMR-TOO
Posted: Mon Apr 13, 2020 10:27 pm Post subject: |
johnbenj wrote: | Yakmandu wrote: | Looks like “Stern Bracket -Swivel Case” page. |
Thanks! |
005
50100-ZW1-030ZA
FRAME, MOUNTING *NH282MU* (OYSTER SILVER METALLIC-U)
1000001
9999999
$317.03
Buy a lot of paint & scraping for that & lots of labor to change. |
tomherrick Guest
Posted: Mon Apr 13, 2020 11:07 pm Post subject: |
Yup, the Stern bracket was diagram I was hoping would post. Looks like $300+ for the part. Good luck! |
