Part name for the plate where the steering rod connects?
johnbenj
C-Dory Year: 1990
Vessel Name: Amoreena
Photos: Rabbit Rabbit
PostPosted: Sun Apr 12, 2020 2:03 am    Post subject: Part name for the plate where the steering rod connects? Reply with quote
What is the name of the part of the Honda BF90 engine which the steering rod connects to push and pull and turn the engine? Mine is so rusty i don't think it is safe anymore and I'd like to try and replace it.
Thanks in advance
tomherrick
Guest
PostPosted: Sun Apr 12, 2020 8:38 am    Post subject: Reply with quote
Not exactly certain which part you mean, but you might find it in one of these two pages from a 2004 Honda Rigging Guide.
johnbenj
C-Dory Year: 1990
PostPosted: Sun Apr 12, 2020 12:01 pm    Post subject: Steering arm Reply with quote
Thanks! In the second page it is called "steering arm." Mine is almost rusted away so now I need to find if it is replaceable.
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Sun Apr 12, 2020 12:10 pm    Post subject: Re: Part name for the plate where the steering rod connects? Reply with quote
Thanks in advance
If I recall correctly(50/50 crap shoot) the piece your describing is a cast steel bracket, bolted to cast steel engine swivel bracket.
To remove the two bolts & replace it might cause more broken bolt, drilling & tapping, cussing, throwing stuff & headache than it's worth it. It's a pretty substantial cast piece, I would scrape, file, sand etc. & see how much metal is there & paint as nec.
Or the 2 bolts will come off just fine & you put on a new one in 10 minutes & away ya go. Thumbs Up
tsturm
Photos: JMR-TOO
PostPosted: Mon Apr 13, 2020 3:27 pm    Post subject: Re: Part name for the plate where the steering rod connects? Reply with quote
tsturm wrote:
Thanks in advance
Lets try a pict http://www.c-brats.com/modules.php?set_albumName=JMR_II&id=BF_90_1&op=modload&name=gallery&file=index&include=view_photo.php
It looks like my memory was the wrong 50% but close, with luck & the studs instead of bolts you might get by with the bracket.
johnbenj
C-Dory Year: 1990
PostPosted: Mon Apr 13, 2020 3:51 pm    Post subject: Re: Part name for the plate where the steering rod connects? Reply with quote
Thanks very much. From more research, and your comments, I am going to try sanding off what ever loose rust i can and using a Rustoleum / POR-15 product.
Thank you!
PostPosted: Mon Apr 13, 2020 4:33 pm    Post subject: Reply with quote
The arm is $46 at boats.net and if you figure in the cost of the rust spray and the top coat you're money ahead by ordering a new one and replacing it. You have to pull it off anyway.
johnbenj
C-Dory Year: 1990
PostPosted: Mon Apr 13, 2020 4:37 pm    Post subject: Reply with quote
Thanks, but that is the Steering Arm Rod. What I need is the Steering Arm.
Here is a picture of mine currently:
http://www.c-brats.com/modules.php?set_albumName=Rabbit-Rabbit&id=steering_arm&op=modload&name=gallery&file=index&include=view_photo.php
tsturm
Photos: JMR-TOO
PostPosted: Mon Apr 13, 2020 5:30 pm    Post subject: Reply with quote
That will Clean up just fine & be good for another 20 yrs Thumbs Up
tomherrick
Guest
PostPosted: Mon Apr 13, 2020 6:53 pm    Post subject: Reply with quote
From your pic it appears to be part number 5 in the diagram shown in this link:
https://peparts.honda.com/marine#/browse/me/bf/bf90/BF90A1-LHTA
johnbenj
C-Dory Year: 1990
PostPosted: Mon Apr 13, 2020 7:15 pm    Post subject: Reply with quote
Hi Tom - that URL takes me to the top-level of all the diagrams. Could you tell me which assembly diagram you are looking at?
john
Yakmandu
City/Region: Lake Lanier
State or Province: GA
C-Dory Model: 19 Angler
Vessel Name: Miss April
Photos: Pops GO!
PostPosted: Mon Apr 13, 2020 7:47 pm    Post subject: Reply with quote
Looks like “Stern Bracket -Swivel Case” page.
Good luck!
Patrick Rohde
Miss April
Lake Lanier, GA
johnbenj
C-Dory Year: 1990
PostPosted: Mon Apr 13, 2020 8:14 pm    Post subject: Reply with quote
Thanks!
tsturm
Photos: JMR-TOO
PostPosted: Mon Apr 13, 2020 10:27 pm    Post subject: Reply with quote
johnbenj wrote:
Thanks!
005
50100-ZW1-030ZA
FRAME, MOUNTING *NH282MU* (OYSTER SILVER METALLIC-U)
1000001
9999999
$317.03
Thumbs Up
Buy a lot of paint & scraping for that Wink & lots of labor to change.
tomherrick
Guest
PostPosted: Mon Apr 13, 2020 11:07 pm    Post subject: Reply with quote
Yup, the Stern bracket was diagram I was hoping would post. Looks like $300+ for the part. Good luck!
Page generation time: 0.0481s (PHP: 66% - SQL: 34%) - SQL queries: 29 - GZIP disabled - Debug on
