DodgeRam
Joined: 26 Nov 2004 Posts: 199 City/Region: Vancouver Isl. CANADA
Vessel Name: SeaRam
Photos: SeaRam
Posted: Sun Sep 18, 2005 2:01 pm Post subject: Bunk Trailer |
Hi I noticed on Da Nag pictures, that he as 4 boards bunk trailer . Is this trailer for a 25' or 22' . I have 2- 11' boards on mine , so all you long time owners of C-Dory that are using Bunk trailer would you go 2 or 4 boards if you would have a choice? Gary SEA RAM |
SENSEI
Joined: 01 Nov 2003 Posts: 1067 City/Region: Stanwood
Vessel Name: SENSEI
Photos: SENSEI and SERENITY
Posted: Sun Sep 18, 2005 2:49 pm Post subject: |
Gary
I have a King bunk trailer. it came with four boards and when we first put the boat on it we took two off and just used the two set out wide. I had a lot of trouble getting the Sensei loaded straight so we put the other two back on in the middle of the trailer leaving enough room for the center rib to slide between. The boat slides into position easily and I have had no problems loading on center since. _________________ Roger on the "SENSEI"
1993 22 Cruiser (sold 2014)
1983 22 Classic (sold 2017) |
C-WEED
Joined: 14 Mar 2004 Posts: 338 City/Region: New Brockton
State or Province: AL
Vessel Name: C-Weed
Photos: C-WEED
Posted: Sun Sep 18, 2005 10:17 pm Post subject: |
My trailer came with four boards. The front boards support the front of the boat, center it on the trailer and allow downward pressure when you really snug the bow against the roller. I think my trailer (magic-tilt) is a bit short as the stern hangs about 1 feet off the back bunks. When I get time I will try to move it forward.
It took a few times to make some adjustments to get the boat to sit and load like it should. More boards is more support surface area. _________________ Chris |
Luna C
Joined: 25 Feb 2004 Posts: 404 City/Region: Lake Goodwin/Center Island
C-Dory Year: 2019
Vessel Name: Panthera
Photos: Luna C
Posted: Sun Sep 18, 2005 10:51 pm Post subject: |
King with 4 planks. I did not like the plastic "easy slid" stuff so ordered mine with the "carpet" covering the boards. _________________ Janet & Chris without CD22 Luna C
Now with Panthera 255 TC |
DodgeRam
Vessel Name: SeaRam
Photos: SeaRam
Posted: Sun Sep 18, 2005 11:02 pm Post subject: |
This forum is awsome. Thank you Roger and Chris , with both of your replies you have solved two of the problems I am having when loading the boat. First even with my side board guides the boat is a bit difficult to center, second the bow does not sit good on the front roller. I will be ordering two boards for the center, thank you again Roger & Chris. Gary |
Joined: 23 Oct 2003 Posts: 5314 City/Region: Warrenton
Posted: Sun Sep 18, 2005 11:13 pm Post subject: |
Just this morning I finally made a couple of the patented B~C Centering Shoes for my trailer, and they worked great. It's just a carpeted chunk of 2x4 with an angle bracket on the back that slides down over the side guides. After the boat is on the trailer, and still deep enough in the water to move sideways, put one of these deals on each side and they hold the boat snugly between them while you pull it out. Then you take 'em off, and the boat is centered and the side guides are not even touching it.
I'll see if I can find the old picture that Ken posted and edit a link to it in here. Ken might play the part of an undereducated educator educated beyond his intelligence, but he is mighty crafty and a fine craftsman. And his centering deals are a stroke of genius.
By the way - my King for the CD25 has four boards. My CD22 trailer had rollers, so it doesn't count in this discussion. _________________ TyBoo Mike
Sold: 1987 22' Cruiser |
Posted: Sun Sep 18, 2005 11:32 pm Post subject: |
The things I made today don't look anything like the ones B~C has. Don't know what I was thinking. Here is a shot of his original design.
The ones I made are just small chunks of 2x2 about 8" long, and they fit lengthwise along the inside of the guide rails. All they do is fill up the space and force the boat to center, then hold it there while pulling it out of the water. Ken's look like they help guide it to center.
By the way, my trailer still has the four boards. |
C-Hawk
Joined: 02 Nov 2003 Posts: 2146 City/Region: Carpinteria / Channel Islands
Vessel Name: C-Hawk
Photos: C-Hawk
Posted: Mon Sep 19, 2005 10:45 am Post subject: |
I have a TrailRite trailer with 4 boards. I have the boards slotted at the stern for hoisting the boat with a sling. _________________ Roger
2008- CD22- "C-Hawk" Sold
KJ6VVB
A Brat I am, At sea I be
God is Great, Beer is Good.... and People are Crazy |
Luna C
C-Dory Year: 2019
Photos: Luna C
Posted: Mon Sep 19, 2005 8:53 pm Post subject: |
Ah, the sling. Keep those hubs out of the water whenever possible! I have 4 inches of overhang - just enough to get a strap on the stern end. I just lift and shift, reposition the straps and in it goes. Easier than modifying the bunks. |
sailor-d
Photos: Sailor-D
Posted: Fri Feb 03, 2006 8:12 pm Post subject: Combination Rollers/Bunks |
Seriously thinking of getting rid of my new EZLoader that I have never really been happy with. Checking out a Road Runner 4800, www.roadrunnerltd.com (not sure if it is available in the USA) and one configuration option is rollers in front and bunks at rear. Has anyone had experience with this combination?
Cheers - Dave |
DodgeRam
Vessel Name: SeaRam
Photos: SeaRam
Posted: Sat Feb 04, 2006 2:21 am Post subject: |
Hi Dave , I look into bunk in the rear and rollers in front , but I got my trailer customize by Road Runner , 11' bunk, 102'' wide axle, 9' tongue 13'' tandem . I just love this trailer it is very well made. I got the regular light ,I had problems with my last trailer with led. And I have regular bearings I also had problem with the last trailer with oil bath oil! I don't believe that rollers in front would make a difference . But if you ever go that way let me know how it work .
Gary SEARAM |
sailor-d
Photos: Sailor-D
Posted: Sat Feb 04, 2006 3:06 pm Post subject: Thanks Gary |
Hi Gary
Would you pls send me your phone no: cdoryman@hotmail.com
Thanks - Dave |
C-Bill
Joined: 08 Feb 2004 Posts: 208 City/Region: Carson City
State or Province: NV
C-Dory Year: 1991
Vessel Name: CharkBait
Photos: CharkBait
Posted: Sat Feb 04, 2006 5:50 pm Post subject: |
Dave,
You've got my attention. That could be an easy conversion for me. I like the idea!
Bill |
