New guy with electrical config question?
PostPosted: Wed Feb 26, 2020 10:38 am    Post subject: Reply with quote
Stearmandriver2 wrote:
Follow up question: no downside to getting a triple output charger for use with two batteries, right? I could see maybe wanting to add a second house battery and it would be good to have an extra charging channel available if I do...
The ProMariner chargers that have triple outputs automatically deal with two or three batteries connected without special wiring. On the Guest chargers that came with some boats, you have to wire the 2nd and 3rd outputs together if you only have two batteries (at least the one that was on my boat).
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
PostPosted: Wed Feb 26, 2020 2:40 pm    Post subject: Reply with quote
You may already know this, but be aware that multi-channel chargers usually divide their stated output among the channels. So for example, you want a 30 amp charger. If it has 3 channels, then only 10 amps will get delivered to any one channel. So if you only hook up one channel, your 30 amp charger just effectively became a 10 amp charger.
There are chargers (the more expensive) that will sense this situation and direct all the available charging power to whatever channel needs it, but you have to look for that feature.
Gene Morris
City/Region: Eureka CA
Vessel Name: Reef Madness
Photos: Reefmadness
PostPosted: Thu Feb 27, 2020 10:07 am    Post subject: Reply with quote
I have the Xantrex Pro 40. It charges 3 bank at 40 amps each. It has been very adequate for my two Optima start batteries and the 4 6 volt golf cart batteries for the house.
Gene
tight lines
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
PostPosted: Thu Feb 27, 2020 1:27 pm    Post subject: Reply with quote
Gene,
Perhaps your battery charger does do this, but I have never seen a consumer model that does. Every battery charger I've looked at can only deliver its rated charge (40 amps in your case) in total. When the manufacturers rate them at, say, 40 amps, they do not mean that each of the 3 outputs can deliver 40 amps simultaneously, but rather that the 3 outputs will share the total capacity of 40 amps. This limit is not often made clear in their documentation....for marketing reasons I presume.
Some chargers divide the total output equally across the outputs such that each output can only deliver a maximum of its share (for example, a 60 amp charger with 3 outputs, each can only deliver 20 amps max ever). Other units are smart enough to share the total amps dynamically (for example, a 60 amp charger with 3 outputs could deliver 60 amps to one output if there is no draw on the other 2 outputs).
Perhaps there is a charger advertised as a 40 amp charger with 3 outputs that can deliver 40 amps to each of the 3 outputs at once (i.e., a total of 120 amps), but I've never seen one in the typical consumer market.
PostPosted: Thu Feb 27, 2020 6:10 pm    Post subject: Reply with quote
That would make it a 120 amp charger. I agree 100% with smckean.
An example of a "large charger" is the Victron 80 amp charger ( & inverter) I have on the 25. I have run the freezer and refrigerator for almost 24 hours, and the Li batteries were down about 60 amps. In about an hour that charger had gone from full output of 80 amps to float at about 2 amps, and it will taper every further. Most batteries will not tolerate this rapid a rate of charge.
Gene's 4 golf carts will handle 40 amps (I have put 100 amps into 4 GC, in an RV setting with a temperature probe on the batteries.). But the average group 24 (60 to 85 amp hours) might be damaged a 40 amp charge, Each type of battery has a maximum safe charging capacity. It is relatively low for flooded lead acid, and high for Li. AGM are in the middle. It also has some relevance to the max rate of discharge.
Page 1-2 of the Xantrex True Charge 40 (also for the 20) states:
The total current into the batteries is a maximum of either 20 amperes or 40 amperes, depending on the model, which is divided amongst the batteries according to their state of discharge.
Note: The three outputs are not independently voltage regulated so it is important to avoid systems with mixed types of batteries.
Reading the manual, it didn't directly address if the full charge (40 amps) was available to only one battery, but I believe that it is. Some other high end chargers (MasterVolt, Victron, Blue Seas, and some of the Pro Mariner/Sterling series, as well as the NOCO) will allocate full charge to one battery if the charger senses the other batteries are nearly 100% charged. But one should have a temperature sensor, to limit the charge if the battery begins to overheat.
Micahbigsur@msn.com
City/Region: Big Sur
Vessel Name: Sierra
Photos: Sierra
PostPosted: Thu Feb 27, 2020 8:48 pm    Post subject: Reply with quote
I still don't understand why with a paralleled house bank and the start battery linked in with a VSR or a ACR you would need more than one channel, seems like wasted complication and money to me.
Micah Curtis and Dana, RN
Micah, KJ6GUF, Dana, KJ6GXG
PostPosted: Thu Feb 27, 2020 9:15 pm    Post subject: Reply with quote
Yes, I agree. Take the VSR out of the equation, by disabling it, the battery will be better proportioning the amount of charge necessary with multi channel charging. Paralleling with a VSR or "All" Switch, leads to over charging the start battery many times.
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
PostPosted: Thu Feb 27, 2020 11:50 pm    Post subject: Reply with quote
As I understand it, it is never a good idea to combine 2 banks (I'll assume 2 banks) via ACR etc unless you need to overcome a temporary problem (i.e., dead start battery).
As long as you separate the banks via an ACR (and why have an ACR if you don't), then the 2 banks will be in 2 different states of charge (i.e., say, start battery at 95% and the house battery at 60%). If combined (non-emergency) the higher state of charge battery will feed charge to the lower charge state battery because the higher state of charge will be at a higher voltage (electron always flow from higher voltage to lower). This is not good for battery life.
Indeed, the entire purpose of an ACR is avoid this situation by isolating the 2 battery banks.....although the ACR does give you a "combine" option if you should ever need it. For myself, I have never combined batteries via an ACR.....no need to.
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
PostPosted: Fri Feb 28, 2020 1:52 am    Post subject: Reply with quote
P.S. It just occurred to me.....I don't know this for a fact, but I presume that the ACR does combine the 2 banks once both banks are at 100% state of charge so that the charger can maintain all the batteries properly with a trickle charge or float charge (or whatever the term for that "steady state" at the end of the charge cycle is called).
Stearmandriver2
City/Region: Port Orchard
Vessel Name: Notayot
PostPosted: Fri Feb 28, 2020 3:09 am    Post subject: Reply with quote
All good discussion.
I've been debating myself as to whether I need (or want) a 3 bank charger, but 15a seems a reasonable output capacity, and the ones I'm looking at seem to be 3 bank chargers. The Promariner Promarine series are smart chargers, so they will divide current between banks, send all current to one bank etc. as necessary. So that still seems like a reasonable choice?
I was wondering whether I even needed to use two banks of the charger, since it seems with the VSR I could just wire one bank of the charger to whichever battery is the closest and both batteries would charge? (The batteries are on opposite sides of the boat, is why I'd be tempted to do this... less leads to run). AGM batteries, if that's relevant.
And now a new question: on a 22 cruiser, where would this charger typically be located? I'm thinking port side battery locker, since that's where I have the most room. I don't see a way to mount it without drilling holes in the side of the boat though (the inside wall of that battery compartment, facing the splash well). This I've never done, and am not entirely comfortable with it, out of water intrusion concerns. Clearly there's a right way to do this... but I don't know it. Wink Could anyone point me towards an explanation of what I'd need to ensure an absolutely watertight seal around the mounting bolts?
Thanks again for indulging me... I'm sure this is all extremely basic knowledge. All I've owned previously was a Catalina 27 with a shore power system already installed, and while much tinkering was necessary to keep the Atomic 4 behaving, I never cut or drilled any holes, and surprisingly in the 10 years I had her she never needed any electrical work, so I just used everything as it was.
Joe
Micahbigsur@msn.com
Vessel Name: Sierra
Photos: Sierra
PostPosted: Fri Feb 28, 2020 8:05 am    Post subject: Reply with quote
Joe, you can use the full output of your charger in one channel into your house bank and have your ACR, (VSR) manage the charging between your house and start banks.
I have been using a Balmar and Blue Seas ACRs on 3 boats for 15 years. They are smart enough not to overcharge a charged start battery, they cut off the charge above a set voltage so I've always had perfectly charged start batteries, and the motor has always perfectly charged my house batteries through them. I have always wired in a manual combine switch that I have never had to use. Using separate channels on a battery charger takes more computing power to keep things balanced and more ways to fail and you still need to have a manual switch or ACR to charge from your motor to your house bank. (I hate those cheap solution, manufacturer installed 1, 2, both, off switches). Then you also need more heavy guage wire runs for your multi channel charger.
Using more than 2 banks, house (multiple balanced batteries in parallel) and start on our small boats with conventional batteries is absolutely not necessary and a waste of time and money.
I still think a smart ACR combine (not the older dumb ones that were inefficient) is far better and simpler solution to 2 bank balancing than using a multi channel charger, the Balmar version was basically a 12v to 12v charger that keeps the banks balanced, I now prefer the Blue Seas ACR to keep my system smart charged.
Just my opinion for what it is worth.
Micahbigsur@msn.com
Vessel Name: Sierra
Photos: Sierra
PostPosted: Fri Feb 28, 2020 8:50 am    Post subject: Reply with quote
On the subject of having separated instead of paralleled house batteries and why it makes no sense.
Conventional lead acid batterys will lose longevity if the discharge goes down to 60% very often. So if you separate your house batteries, discharge 1 in half the time that battery will not last as long as it would have if it had been in parallel with its twin and only discharged by half as much. Battery chemistry changes over time and having 2 separate house batteries, over time will not be balanced and balanced is better if you ever combine them with a switch. More rapid Sulfation is likely to occur in the more heavily discharged battery which can also lead to shorter battery life.
Some larger boats run a whole extra bank linked with an ACR for the anchor windlass and thrusters that is not necessary on our boats.
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
PostPosted: Fri Feb 28, 2020 12:25 pm    Post subject: Reply with quote
I had a re-think about all this overnight. Micah's insights have raised questions in my mind about just how all this works. I thought I understood it all (or almost all), but now I realize there are holes in my understanding. I'm going to do more thinking about all this. For one thing, it now occurs to me that I have not given sufficient thought to the various scenarios batteries are subjected to. For example, at times, there could be no charging going on; at other times charging is occurring from the alternator on the engine; at still other times charging is occurring from a charger plugged into 120v. Overlay all of that with the circumstance that the battery switches could be on or off under most or all of those scenarios.
One thought that has occurred to me is concerning the need for multi-channel chargers. Micah makes a good case that single channel is all you need since the ACR will insure that both banks are connected while being charged. However, I can think of one case where multi-channel is a benefit; namely, when the boat is in its boathouse (or whatever) and the battery switches are turned off. In that case it is recommended that the charger provides a float charge to all the batteries to keep them topped off and therefore healthy. A single channel charger would not be able to do that with the batteries cut out of circuit with their on/off switches. OTOH, does the ACR typically connect the 2 banks upstream of the on/off switches such that both banks can "see" the single channel charger when they are at full charge and the switches are off?
I am beginning to think that as thataway suggests above it might be best for me to remove my ACR since I have a multi-channel, smart charger that has independent connections directly to the battery posts of both banks. OTOH, it seems to me that I would still need the ACR when the engine alternator is providing the charge and the battery charger is out of the picture. Hmmmmmmm......
Like I say.....I gotta think more about this. Ironically, I thought I had answers to this stuff (and I do have some), but now I have more questions than answers Wink Laughing
P.S. BTW, one thing I've noticed as I've been doing some reading on this stuff is that the battery charger manufacturer materials tend to not mention or diagram the engine alternator source of charging; whereas the engine folks tend to draw diagrams etc leaving out a possible charger. Of course, in the real world of the boat owner like you and me, we do have both.
Micahbigsur@msn.com
Vessel Name: Sierra
Photos: Sierra
PostPosted: Fri Feb 28, 2020 6:11 pm    Post subject: Reply with quote
smckean, I believe I did wire my ACR from the strip of studs that are the first thing that my house and start battery are connected to before my main house and start batterys so they stay balanced. (along with the bilge pumps on the house side). An ACR if I remember correctly does use a few milliamps so it must have at least a small charging source.
To make my charging system even more of a complicated mess I have a 3 stage solar controller in a solar system that can put out up to 15-20 amps that is tied into the TRIPLE charging system. In an earlier system on another boat if I left the solar on when motoring it would apply enough voltage at a few amps when motoring on a 600 AH house bank that my 80 amp alternator decided the batteries were charged and went to float charge leaving my batteries mostly uncharged.
This is where my lack of technical knowledge limits my ability to solve the problem, so now when I am motoring I have to turn off my solar manually.
Electricity is fun to plan out the wiring for but it can throw a few curves and weird feedback at you as I am an amateur at it and when Dana asks why something isn't working as designed I just tell her it is MK I, I'll have it sorted by design MK II or III!
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
PostPosted: Fri Feb 28, 2020 7:53 pm    Post subject: Reply with quote
Micah,
I did some research today. I won't say "I got it figured out", but I will say I've made progress. I certainly learned some things. I also snagged a couple of useful diagrams -- which I may try to post in this thread later.
One consideration is that there is definitely 2 basic ways of hooking up a ACR: on the load side, and on the battery side (as the pros called them) of the switches. If you place the ACR on the battery side, then putting a charger on either battery will charge both batteries regardless of how one sets the on/off switches; and a one channel charger is all you need. OTOH, if you place the ACR on the load side, a single channel charger can only charge one battery at a time if either switch is turned off; so you then need a multi-channel charger unless you manually intervene while charging. A load side installation with a smart multi-channel charger is preferred (though less common) since then the charger can manage each battery separately....each according to its individual needs. OTOH, if you want to use a single channel charger then you must install the ACR on the battery side, but then the smart charger can't see that there are 2 different batteries, so it charges them as if they were one giant battery. This single channel charge might not be good if the two batteries don't accept charge in the same way (for example, one battery might be weak even tho there are both the same model).
I'm not sure I understand your 1st sentence above, but it sounds like you have a battery side installation.
Page 2 of 3
Page generation time: 0.0523s (PHP: 60% - SQL: 40%) - SQL queries: 32 - GZIP disabled - Debug on
