bmcminn
Joined: 20 Jul 2019 Posts: 65 City/Region: Bellingham
C-Dory Year: 1992
C-Dory Model: 19 Angler
Vessel Name: Polū
Photos: bmcminn
Posted: Mon Feb 17, 2020 4:01 pm Post subject: 3M marine grade silicone sealant vs 4200 |
Which one for lazarette hatches? They are a tight fit and did the overdrill and fill with 205 and the screw holes. |
srbaum
Joined: 30 Aug 2010 Posts: 877 City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
Posted: Mon Feb 17, 2020 4:22 pm Post subject: |
Bmcminn,
You will fall in love with butyl rubber tape. Buy it in white, 1/8" x 3/4" and you will rarely need any other caulk. Hinkley Yachts, many of my fellow boaters and I have been using it for years with great success.
The stuff remains pliable, you don't need any chemicals to clean-up and you can roll it in any shape, thickness or size.
It also does not go bad while sitting in your shop, waiting for its next use.
Here is a link to what I have purchased the last two times around. https://www.ebay.com/itm/DEHCO-COLORIMETRICS-BUTYL-TAPE-PUTTY-TAPE-BLACK-GRAY-WHITE-MANY-SIZES/231095305882?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 _________________ Steve Baum
Homeport of Portsmouth, VA
Joined: 02 Nov 2003 Posts: 20813 City/Region: Pensacola
Posted: Mon Feb 17, 2020 4:50 pm Post subject: |
I go with the 4000, it does not turn yellow. The silicon can hold, or it cannot hold--does vary. My own experience with the butyl tape is that unless you can keep the screws and bolts tight, eventually water and dirt will get under it. I know a lot of folks like it--and it is certainly easier, faster, and cheaper for the boat builders to use....but then again, most boat builders do not properly put in solid glass or epoxy potting when they put fasteners thru a hull, into a cored structure. _________________ Bob Austin
Joined: 30 Sep 2006 Posts: 4656 City/Region: Lake Stevens via Honolulu
Posted: Mon Feb 17, 2020 5:08 pm Post subject: |
I use butyl only on thru bolted items. If screws are used, sealant. Just what I do. Don’t claim to be an expert. When I replaced our cockpit hatches I used 3M 4000. _________________ "We can go over there...behind the 'little one'....."
srbaum
Vessel Name: Osprey
Photos: Osprey
