Service for my Furuno Autopilot
Forfun1960
City/Region: Carmi
State or Province: IL
Vessel Name: Journey former Noro Lim
Photos: Journey
PostPosted: Sun Feb 02, 2020 10:07 pm    Post subject: Service for my Furuno Autopilot Reply with quote
My Furuno 511 Autopilot makes a very hard left when I engage it and then gives me a Rudder Error. Furono says it may have air in steering after bleeding no improvement. II will be coming down to the Hontoon event next month from Illinois. Anyone have a recommended service shop I can take my boat to for the repair while I'm in Florida? I have extra days before and after the event.
Donnie Wilson
PostPosted: Mon Feb 03, 2020 10:06 am    Post subject: Reply with quote
I know several like and have used Astor Marine.
Avidmagnum12
City/Region: Ocklawaha
C-Dory Year: 2011
Vessel Name: C-Otter
Photos: C-Otter
PostPosted: Mon Feb 03, 2020 5:44 pm    Post subject: Reply with quote
Astor Marine is a great shop but I doubt that they can help with an autopilot. You probably need a electronics shop. I messed my Garmin Auto pilot up a couple times by setting speakers and fans by the compass unit. I should know better. My boat turned the wrong way. I also clean contacts if something is not working right. Not much help but who knows.....Tom
See you at Hontoon
Tom and Joyce Schulke
PostPosted: Mon Feb 03, 2020 9:32 pm    Post subject: Reply with quote
Not near Hontoon, but if you want to drop by Pensacola by the way, you are welcome to stay with us. Georges Marine Electronics is not far away.. They are a well respected electronics outfit and do work on/carry Furuno. Some times the folks want the boat in the water, and there is a nearby ramp and we have a dock. I suspect it may be a relay, or could be an issue in the main board. I have suffered thru a number of those "bump in the night"--hard right or left issues thru the years with auto pilots. Really aggravating when they go out on a 2000 mile passage across an ocean...or only steer gong South, and you want to go North!
We are only 8 miles off I 10, and about 30 miles off I 65 (coming South--one of the ways we go to our farm In Illinois. We also take Hwy 45 thru Mississippi and then Alabama, picking up I 10 in Mobile. This is a little further than going directly thru Georgia to I 75.
You might want to call Georges and talk with them, about making an appointment if you are interested.
PostPosted: Mon Feb 03, 2020 9:46 pm    Post subject: Reply with quote
Are you just looking to have the steering hydraulics re-bled, or to actually work on the autopilot electronics? or both? If just rebled, we probably have enough expertise right there at the gathering to help with that. Colby
Forfun1960
City/Region: Carmi
Photos: Journey
PostPosted: Tue Feb 04, 2020 10:32 am    Post subject: Reply with quote
I have already bled the system, at this point looking for service.
Hunkydory
State or Province: WY
Vessel Name: Hunkydory
PostPosted: Tue Feb 04, 2020 11:07 am    Post subject: Reply with quote
This will happen minus the rudder error on our older Raymarine S1000 auto pilot, whenever I reengage the auto pilot following going to a low enough speed where it loses steering control. The fix in my case is to completely shut off the system restart & after initializing do a couple circles both left & right then a straight course before reengaging. Sometimes I’ve been able to just do the circle counter circle then straight course without restarting to stop the abrupt right or left turn when engaging. Lots of differences in the working of the auto pilots between makes & types, so for sure not a fix for all & likely you.
NORO LIM
City/Region: Olympia
Photos: NORO LIM
PostPosted: Tue Feb 04, 2020 12:35 pm    Post subject: Reply with quote
If I had to guess, I'd say it might be the rudder sensor. Furuno AP uses a Telex "Smart Stick" sensor attached to the outboard's mounting bracket. The stick itself (or a connection) may have failed, or the sensor or its reference magnet may have gotten knocked out of alignment.
https://www.furunousa.com/-/media/sites/furuno/document_library/documents/manuals/installation_manuals/fapar4502_manual_of_installation_instructions.pdf
Bill, Formerly on NORO LIM
2001 CD 16, 2001-2006
2006 CC 23, 2006-2014
Page generation time: 0.0422s (PHP: 63% - SQL: 37%) - SQL queries: 25 - GZIP disabled - Debug on
