Horn does not work.
Goto page 1, 2, 3  Next
ken35216
City/Region: Destin, Florida
C-Dory Year: 2017
Vessel Name: Lady Onyx
Photos: ken35216
PostPosted: Mon Dec 09, 2019 5:07 pm    Post subject: Horn does not work. Reply with quote
I just back from a nice 18 day cruise of SW Florida. I put in in St Petersburg and went down to Ft Myers and back. I really do love it down there.
The first morning as I was leaving St Pete I was boarded by the Coast Guard for an inspection. I had an inspection done at my marina and had a 2019 sticker but the CC guy said does not matter. So I welcomed them aboard and wanted him to know that C-Dory owners are safe boaters.
Everything went well and I had everything, feeling smug, then he asked if I had a horn or whistle. I said "of course" and pushed the horn button....
The horn is located above the helm window, under the overhang, above the windshield wiper.
Crook Cry
2007 25 Cruiser 150 Suzuki (2013-2016)
2017 25 Cruiser 200 Yamaha (2017-present)
ken35216
C-Dory Year: 2017
Photos: ken35216
PostPosted: Mon Dec 09, 2019 5:09 pm    Post subject: Reply with quote
Seadog says:
"MaxBlast Single Mini Compact Horn is constructed of an injection molded housing under a stamped 304 stainless steel cover. Corrosion resistant stainless steel cover protects the internal components. After a 600 hour salt spray test, this electric horn was completely rust-free! Mounting bracket can be used as a wiring template. When installed, horns should point slightly downward to permit water drainage."
I'm calling bs on the corrosion resistant stainless steel part!
ken35216
C-Dory Year: 2017
Photos: ken35216
PostPosted: Mon Dec 09, 2019 5:11 pm    Post subject: Reply with quote
Here is the horn button:
Just an FYI to Northwest Marine Industry... white lettering with gray background is HARD TO SEE WITH OLD EYES!!!!
[url]
Here is the wiring behind it.
The yellow wire on the left was not plugged in anything and it's the one for the horn... could that be causing the problem or is it the rusted horn?
[/url]
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Mon Dec 09, 2019 5:21 pm    Post subject: Reply with quote
Ken,
Mine crapped out also. Resons were the same... I was going to focus on a really nice horn, but it would not fit the space, up under the eyebrow.
I ended up buying the one listed below. It fits the space and should last about 10 years, as the previous one did... https://www.amazon.com/gp/product/B0019LY8DY/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Lastly, I have an air horn laying near the shifter, in case I have a failure and have a need for an extra horn in the future.
Steve Baum
Homeport of Portsmouth, VA
ken35216
C-Dory Year: 2017
Photos: ken35216
PostPosted: Mon Dec 09, 2019 5:30 pm    Post subject: Reply with quote
srbaum wrote:
Ken,
I bought an extra air horn a couple of days later. I'm going to keep it near the shifter too (good idea) as the horn will go out at the exact moment you really need it! Like an inspection or worse warning another boat.
Will the existing wiring work to add that horn?
srbaum
Vessel Name: Osprey
Photos: Osprey
PostPosted: Mon Dec 09, 2019 5:55 pm    Post subject: Reply with quote
Ken,
I cut the old wires near the old horn and mounted the new horn and used crimp connectors that are heat sealed. It saved me time and effort, from running new wire back to the switch. I was fortunate that that new horn also had the same screw mount pattern as the old one (no new holes and the job took less than 20 minutes).
Example: https://www.amazon.com/Kuject-Connectors-Connector-Waterproof-Automotive/dp/B07B518GCJ/ref=sr_1_13?keywords=butt+connector%2C+heat+sealed&qid=1575932144&s=industrial&sr=1-13
PostPosted: Mon Dec 09, 2019 6:09 pm    Post subject: Reply with quote
The little yellow wire is usually the illumination circuit--goes on when you turn the running lights on. Probably the cheap Chinese SS on the horn...you could take it apart--it is just a coil and a plate which vibrates--very simple... or you could buy a new one...probably 50/50 as far as work.
Or you could get one of those "train horns" which are 135 dB....Wolo makes cheap plastic ones, which don't rust--no tank, and work fairly well--about 10x the sound level of the standard C Dory issue.
PostPosted: Mon Dec 09, 2019 8:43 pm    Post subject: Reply with quote
Good point to note that we should be carrying a backup horn, such as the can air, or there are also manual horns available. Also a good idea to check them (both the electric and the back) up occasionally.
I was at Sucia Island one time when a fellow came in on a TC24, recently purchased, and this was their maiden voyage. I noticed that the VHF antenna looked damaged. When I asked him about it he admitted that the VHF did not work. I asked him about the horn and he said "It's right here", pointing to the switch, but when he pushed the button there was deafening . . . silence.
He came up to Sucia Island from Everett with no signaling device, and was going to go back same way, with wife and kids and a couple of relatives on board.
I recommended that he get a voluntary safety inspection done, and gave him a canned air horn to take with him as a reminder.
PostPosted: Mon Dec 09, 2019 9:45 pm    Post subject: Reply with quote
Ours died last summer. Didn't know it until I was on a trip. I just replaced it; like $40 on Amazon. I took the old one apart and it was a rusted mess.
https://www.amazon.com/Seadog-Line-Double-Compact-431120-1/dp/B00EVIODE6/ref=sr_1_35?dchild=1&keywords=sea+dog+horn&qid=1575946066&s=sporting-goods&sr=1-35
https://www.amazon.com/Sea-Dog-431125-1-Blast-Twin-Compact/dp/B01CJ0159S/ref=pd_sbs_200_1/133-3585119-7916410?_encoding=UTF8&pd_rd_i=B01CJ0159S&pd_rd_r=66c79f83-4b80-458e-87b7-b034fb07f69f&pd_rd_w=kSiaH&pd_rd_wg=Qqbff&pf_rd_p=5873ae95-9063-4a23-9b7e-eafa738c2269&pf_rd_r=30SVFHRHXHDAKJPZDZJ7&psc=1&refRID=30SVFHRHXHDAKJPZDZJ7
Capn Jack
City/Region: La Conner
C-Dory Year: 1988
Vessel Name: Pocket Yacht
Photos: Pocket Yacht
PostPosted: Mon Dec 09, 2019 10:25 pm    Post subject: Electric Horn Reply with quote
When mine quit working, I took it off and dug all of the mud out of it that the Mud dubber Wasps had put inside. Sad
Now it has a piece of window screen over the opening. Wink
PostPosted: Mon Dec 09, 2019 10:53 pm    Post subject: Reply with quote
Hi Bob,
Hey, regarding those Wolo Train Horns you mentioned. My horn works, but I like the idea of something that is much louder! Can you provide a little more information? Like which model horn? Thanks. Colby
PostPosted: Tue Dec 10, 2019 12:58 am    Post subject: Reply with quote
My horn died last year. Got a replacement online. The original sounded like a horn from a much larger boat. It was kind of funny to have such a deep sounding horn on a relatively small boat. The new horn just sounds like a regular car horn and is not as attention getting.
The form factor of the new horn is the same as the old one. Too bad it doesn't sound the same.
ken35216
C-Dory Year: 2017
Photos: ken35216
PostPosted: Tue Dec 10, 2019 8:44 am    Post subject: Reply with quote
colbysmith wrote:
Hi Bob,
I'd like to know that also.
Loud horns save lives or something like that (Harley Davidson fans).
cmetzenberg
City/Region: Santa Barbara
Vessel Name: Kanaloa
Photos: Kanaloa
PostPosted: Tue Dec 10, 2019 1:11 pm    Post subject: Reply with quote
my horn is on the way out too. I'm curious about a good replacement. What the boat came with is so quiet it's useless even when it did work. I just have no idea how i'd mount a horn under the visor.
Conrad Metzenberg
07' Tomcat 255 "Kanaloa"
87' Boston Whaler Guardian 17 (BlackFlag, 03-14)
Chester
City/Region: home
Photos: Chester
PostPosted: Tue Dec 10, 2019 10:28 pm    Post subject: Reply with quote
I put air horns on my last Harley.
When I went down to get my MC endorsement on my Hodaka Wombat the horn didn't work and they would not pass me account of that. Fix it, he said.
I went to Coast-To-Coast and bought a bicycle squeeze bulb horn. The examiner didn't like it but it was legal. He rolled his eyes as he gave me the paperwork. Ha!
One other guy was trying to get his endorsement at the same time. He was a county commissioner with an identical Wombat in the back of his pickup.
His looked like it had just rolled off the showroom floor and mine looked like it had seen lots of dirt. He looked down his nose at the long haired kid on the dirty dirt bike... and failed the riding test. Ha!
Page 1 of 3
Page generation time: 0.0628s (PHP: 68% - SQL: 32%) - SQL queries: 32 - GZIP disabled - Debug on
