Corrosion on BF200
forrest
City/Region: Chehalis
Vessel Name: Long Story
Photos: Long Story
PostPosted: Tue Nov 19, 2019 9:44 am    Post subject: Corrosion on BF200 Reply with quote
[img]Corrosion on BF200[/img]
Should have listened to Les. Les said to get the ETEC.
If someone can post the picture from my album to this post please do so. If that can't be done you can go to my album and look at the last picture. In the area of the corrosion there is a brass bushing in a rubber sleeve around the stainless drive shaft surrounded by the aluminum housing. Poor design by Honda. Outboard mechanic says the new part will last another ten years and then fail again. Nothing can be done to solve the problem.
NORO LIM
City/Region: Olympia
Photos: NORO LIM
PostPosted: Tue Nov 19, 2019 10:01 am    Post subject: Reply with quote
Bill, Formerly on NORO LIM
2001 CD 16, 2001-2006
2006 CC 23, 2006-2014
Hunkydory
State or Province: WY
Vessel Name: Hunkydory
PostPosted: Tue Nov 19, 2019 11:02 am    Post subject: Reply with quote
That sure doesn’t look good. What year is this motor. I see in 2018 the larger motors including the BF200 were upgraded for corrosion & other improvements. My just replaced 20 year old Honda 40’s with half their time of 2365 hours in salt water were corrosion free at least on the outside & no indication of it being bad on the inside either.
Salmon Fisher
City/Region: Arlington
Vessel Name: Kim Christine
Photos: Kim Christine
PostPosted: Tue Nov 19, 2019 3:41 pm    Post subject: Reply with quote
Can it be welded? Is the part to be replaced important for the operation of the engine?
When I had my 22 cruiser with twin Honda 40s a stick was kicked up by the prop and broke a chunk of the anti cavitation plate. I took the lower unit off and to it to a prop shop and they fixed by welding a new piece. I couldn't tell where the patch began when I got it back. They left it for me to prime and paint.
Patrick and Kim Walker
2004 25 Cruiser-Present
1985 22 Classic -2019 (Sold)
PostPosted: Tue Nov 19, 2019 9:36 pm    Post subject: Reply with quote
Duplicate post.
PostPosted: Tue Nov 19, 2019 9:40 pm    Post subject: Reply with quote
Salmon Fisher wrote:
Can it be welded?
Looks like a cast part. I assume the innards we see are the drive/prop shaft and brass bushing in the lower part of the crack, which means the shaft spins inside the damage area. Nope.
forrest
Photos: Long Story
PostPosted: Wed Nov 20, 2019 1:43 am    Post subject: Reply with quote
Nope on the welding (it's already fixed). Even if it could be welded the rubber piece holding the brass bushing would catch on fire. I fished the month of August out of Westport with it in that condition all the while being aware of the problem. Made me very nervous.
The motor is a 2006.
Page generation time: 0.0332s (PHP: 59% - SQL: 41%) - SQL queries: 24 - GZIP disabled - Debug on
