Connecting VHF with AIS to MFD
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Wed Oct 30, 2019 10:28 pm    Post subject: Connecting VHF with AIS to MFD Reply with quote
Has anyone connected a VHF radio with AIS to their MFD (chartplotter)
Connecting a Standard Horizon GX2200 VHF with GPS and AIS receiver to a Garmin chartplotter Echomap Plus?
How was the AIS performance?
Brent Barrett
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Wed Oct 30, 2019 10:52 pm    Post subject: Re: Connecting VHF with AIS to MFD Reply with quote
Works great! Thumbs Up
I can sit in the slip & watch tankers come into the inlet.
The first time the collision alarm that you haven't set up properly goes off it will scare the S___T out of you!!
chromer
C-Dory Model: 19 Angler
Photos: Checkpoint II
PostPosted: Wed Oct 30, 2019 11:05 pm    Post subject: Reply with quote
Brent
I wired SH to Lowrance. Works great. Overlay awesome
Checkpoint II (SOLD 10/2020)
Alure Bertram 28
PostPosted: Thu Oct 31, 2019 2:09 am    Post subject: Reply with quote
I wired the same radio to my Garmin 3210 and it worked great for a while and then just quit sharing the data. I disconnected the main plug on the back of the Garmin and found one pin that was broken off and shorter than the rest. I figured that is the problem and have not yet checked the wire splices. I will get around to it soon. It was really quite a cool thing to have.
BrentB
Photos: BrentB
PostPosted: Thu Oct 31, 2019 9:23 am    Post subject: Reply with quote
All
Thanks a million!
BrentB
Photos: BrentB
PostPosted: Thu Oct 31, 2019 9:58 am    Post subject: Reply with quote
To connect the radio to MFD on my system, is connecting a few wires together. I dont have a network (yet)
Micahbigsur@msn.com
City/Region: Big Sur
Vessel Name: Sierra
Photos: Sierra
PostPosted: Thu Oct 31, 2019 10:20 am    Post subject: Reply with quote
I had to order a special cable that plugs into the back of my new Simrad MFD and then goes to individual wires for the Standard Horizon end.
Micah Curtis and Dana, RN
Micah, KJ6GUF, Dana, KJ6GXG
tsturm
Photos: JMR-TOO
PostPosted: Thu Oct 31, 2019 10:22 am    Post subject: Reply with quote
Mine is hard wired also. my radio is not nema 2000 ready. neither is my fruno radar (hard wired into another 0183 nema sonar)
chromer
PostPosted: Thu Oct 31, 2019 10:41 am    Post subject: Reply with quote
A shop locally has SH on sale for $300. You get a good deal Brent?
BrentB
Photos: BrentB
PostPosted: Thu Oct 31, 2019 10:49 am    Post subject: Reply with quote
Chromer
That is a great deal.
Thanks!
Same deal online
Standard Horizon VHF Matrix AIS/GPS 30W Hailer Black GX2200B.
Buy on Google
$319.95
Save 20% extra, up to $20
Code: SHOPNEW19
Google Shopping•Ends November 03. See terms
Ships from and sold by The GPS Store
$300 plus sales tac
https://www.google.com/shopping/product/144548098391442984?q=standard+horizon+ais+vhf&prds=epd:10220579359645279484,prmr:3,tpim:CJ-_09Oj__qXRxDxsNmUlbSKoQEYsJnImAEiA1VTRCjw2oLuBTDqlfUC,pdprs:5&utm_medium=tu_cu&utm_content=eid-lsjeuxoeqt&utm_campaign=6114026&gclid=EAIaIQobChMIn4idxN7G5QIVAtvACh1CdgSqEAQYASABEgKrjvD_BwE
PostPosted: Thu Oct 31, 2019 11:01 pm    Post subject: Re: Connecting VHF with AIS to MFD Reply with quote
Brent, Are you asking about a VHF with AIS recieve which is the more common type, or are you asking for performance of a VHF with an AIS transmit/recieve system, a less common device with a more complex system?
BrentB
Photos: BrentB
PostPosted: Thu Oct 31, 2019 11:15 pm    Post subject: Reply with quote
Hi Harvey
VHF radio with AIS receiver
I was planning to upgrade radio to SH GX2200 with DSC and AIS receiver and interface to a Garmin Echomap Plus MFD and gain AIS overlay
PostPosted: Fri Nov 01, 2019 11:40 am    Post subject: Reply with quote
I have the earlier model radio (without internal GPS), and it's connected to my Garmin GPSMAP via the older NMEA 283 (I believe) system. Works well. Hardest part is just figuring out which wires connect to which wires. Have wiring diagrams from both your radio and MFD, and study closely which tiny wire is which. If you're MFD is like my GPSMAP 541 or 840, you can turn the AIS repeater on or off. It is definitely nice having the targets pop up on the larger MFD screen, than the tiny VHF screen. But if you are in a crowded marina where everyone seems to leave their AIS on, it's also nice to turn off the display of targets. If both your electronics have the newer 2000 network system, it's just easy plug and play, if you have the proper backbone cables. Colby
PostPosted: Fri Nov 01, 2019 12:44 pm    Post subject: Reply with quote
The NMEA protocols are 0183 (released in March of 1983) which is a simple network. The second is the 2000 which uses the backbone. Unfortunately not all brands are fully compatible in either protocols. But the 0183 is more likely to be shared. Nothing wrong with 0183--just requires some soldering, or making small wire connectors (soldering is fine, as long as you "splint" the joint with adhesive shrink wrap.
We have used older and smaller Garmin MFD to show only the O183 data from the Standard Horizon radio. That keeps the clutter from AIS off the Primary chart plotter used for navigation.
PostPosted: Fri Nov 01, 2019 5:56 pm    Post subject: Reply with quote
Bob is correct (as usual Smile ) I meant to say 0183. I used small wire solderless connectors with mine. The kind that are usually used with telephone wire.
Page generation time: 0.1165s (PHP: 87% - SQL: 13%) - SQL queries: 33 - GZIP disabled - Debug on
