Check your gas cap o-rings
little wing
City/Region: Oakland
Vessel Name: Toots
Photos: Toots
PostPosted: Fri Oct 18, 2019 5:41 pm    Post subject: Check your gas cap o-rings Reply with quote
On our last trip, the marina gas pump attendant noticed the gas cap o-rings were quite deteriorated. Both gas caps as well as the water cap looked the same. I'm sure these are original (2005) and it's obviously time to replace them.
Replacements are 2/$12.49 at WM.
These are the same and available for $0.79/ea at Ace Hardware.
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Fri Oct 18, 2019 5:48 pm    Post subject: Re: Check your gas cap o-rings Reply with quote
Also, any hydraulic shop will have these CHEAP.
I picked up 10 for $2.00 a few years back. Thumbs Up
PostPosted: Fri Oct 18, 2019 9:03 pm    Post subject: Reply with quote
Great reminder, and I have been eying my O rings on both the fuel and water caps. You want to be sure that the "O" ring is resistant to gasoline for the fuel tank. Also resistance to UV and Ozone is important. I tend to favor FKM/FPM/Viton™ (Flurocarbon) over the "NBR" or Nitrile O rings. Any "rubber" which is not one of these is probably not the best choice for longevity in the fuel environment. Ethylene-Propylene / EPDM:is not resistant to gasoline. The Vitron is going to be a bit more expensive. On the other hand, West Marine charges $12.95 for two "Perko" O rings which are listed as "rubber". Wholesale Marine has "Sea Dog" O rings for $1.27 each...but again don't list the composition of the material. Grainger has the 1 5/8 OD in Nitrile at about 10 cents each, Viton for about 40 cents each, and Silicone for about 20 cents each. These prices are all in packs of 25. Can you say "marine markup"?
I like to keep my fills clean and a light coating of "Superlube O Ring silicone Grease" on the o rings and threads.
little wing
Vessel Name: Toots
Photos: Toots
PostPosted: Fri Oct 18, 2019 9:25 pm    Post subject: Reply with quote
The o-ring in that bag is nitrile. It is compatible with gasoline...and water.
PostPosted: Fri Oct 18, 2019 9:26 pm    Post subject: Reply with quote
Thanks--I didn't see that on the package. Sure cheaper than West Marine!
C-Green
City/Region: Houghton
Vessel Name: C-Green
Photos: C-Green
PostPosted: Sat Oct 19, 2019 10:55 am    Post subject: Danco o ring at Ace Reply with quote
According to the Danco website the #50 o ring is made of "Durable rubber construction". So is nitrile a rubber? Not trying to stir the pot, just trying to get a gas resistant o ring.
PostPosted: Sat Oct 19, 2019 1:05 pm    Post subject: Reply with quote
A nitrile is any organic compound that has a −C≡N functional group.[1] The prefix cyano- is used interchangeably with the term nitrile in industrial literature. Nitriles are found in many useful compounds, including methyl cyanoacrylate, used in super glue, and nitrile rubber, a nitrile-containing polymer used in latex-free laboratory and medical gloves. Nitrile rubber is also widely used as automotive and other seals since it is resistant to fuels and oils.
It is a vague description on their website, though.
PostPosted: Sat Oct 19, 2019 1:25 pm    Post subject: Reply with quote
Description of Danco #50 O ring:
Made from Buna-N rubber to provide superior resistance against abrasion and water swell.
Buna N rubber is Nitrile. So Little Wing is correct that the O ring is Nitrile.
"Rubber" is a bit ubiquitous (a polymer with viscoelasticity) --we normally think of "rubber" as a material made from Latex, and a natural rubber. However, Many items are also described as "silicone rubber", Neoprene Rubber, "EDPM rubber" or "nitrile rubber". The latex product from a plant is more likely to be described as "natural rubber". There can also be some synthetic compounds described as Latex.
C-Green
Photos: C-Green
PostPosted: Sat Oct 19, 2019 10:09 pm    Post subject: Reply with quote
Dr Bob and Localboy, Thanks for the clarifications. Where did you find that description of the Danco o ring?
PostPosted: Sat Oct 19, 2019 10:35 pm    Post subject: Reply with quote
The information for the composition comes from Supplyhog.
C-Green
Photos: C-Green
PostPosted: Sat Oct 19, 2019 10:50 pm    Post subject: Reply with quote
Dr Bob,
Thanks again. C-Brat site is invaluable with your help, the administrators and other contributors.
PostPosted: Tue Mar 03, 2020 6:42 pm    Post subject: Reply with quote
Old thread:
The o-rings pictured above do fit the water & waste caps but both our fuel ones are much larger & thicker. I'm going to try to find them at Ace also so I don't have to pay $6 each.
little wing
Vessel Name: Toots
Photos: Toots
PostPosted: Tue Mar 03, 2020 7:05 pm    Post subject: Reply with quote
On my 2005 CD22, the fuel and water caps are the same (except for the external fuel/water markings) and use the same o-ring.
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
PostPosted: Wed Mar 04, 2020 12:46 pm    Post subject: Reply with quote
I had a great experience at O-Rings West in Lynnwood. Although clearly geared as a commercial wholesale supplier, they took the time to analyse an old o-ring and sell me two new ones for a dollar when the OE supplier wanted $30 each.
Based on what I learned, I recently measured and bought a "kit" for rebuilding my vintage Wagner 701 hydraulic steering. $4 at Ace instead of $29 for the increasingly rare "official" rebuild kit (which does include a paper gasket). I just happened to have a "ring mandrel" from another project that really helps quickly measuring ID on smaller o-rings. OD is simply adding twice the o-ring thickness measured with a caliper. Easy peasy.
The most difficult part was that the little bins at Ace were a mess based on customers mixing up the sizes (plus metric mixed with imperial). I lucked out after close examination, but I should have taken the mandrel and caliper to the store. That would have saved me 10 minutes of tedium.
Mark
https://www.amazon.com/Rosenthal-Collection-Ring-Sizer-Mandrel/dp/B01MG5HOEO/ref=pd_sbs_261_t_0/133-5166576-4422325?_encoding=UTF8&pd_rd_i=B01MG5HOEO&pd_rd_r=8286e083-87de-46d6-84dd-349ec2617c44&pd_rd_w=JHSGh&pd_rd_wg=HRyKK&pf_rd_p=5cfcfe89-300f-47d2-b1ad-a4e27203a02a&pf_rd_r=TD7BCAQN9BHY6BKTZ1DX&psc=1&refRID=TD7BCAQN9BHY6BKTZ1DX
PostPosted: Wed Mar 04, 2020 12:55 pm    Post subject: Reply with quote
OK, I'm confused. What are the O-ring OD and ring thickness? For both the water and gas caps.
Page generation time: 0.1415s (PHP: 87% - SQL: 13%) - SQL queries: 33 - GZIP disabled - Debug on
