Installed a Lone Star GX2 anchor winch
AKFisher
City/Region: Venice
C-Dory Year: 2013
Vessel Name: NELLIE GRACE
Photos: AKFisher
PostPosted: Thu Sep 26, 2019 12:55 pm    Post subject: Installed a Lone Star GX2 anchor winch Reply with quote
I had a Lone Star GX2 anchor winch installed on my 22 Cruiser. it is amazing. About 425 feet of chain 1/4 inch Dyneema line. No more having to walk up to the bow and drop or raise anchor. It will make it a lot easier on the cool Alaska mornings. [/img]
AKFisher
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Thu Sep 26, 2019 3:01 pm    Post subject: Reply with quote
Nice keep all the stink up on the deck.
Jody Kidd
KE7WNG
Northern, Utah
PostPosted: Thu Sep 26, 2019 3:26 pm    Post subject: Reply with quote
Impressive spool winch! Did you really put 425 feet of chain, or is that a combination of the Dyneema and chain--if so, how much of each?
What splice did you use to the chain, and did you use a thimble?
AKFisher
City/Region: Venice
C-Dory Year: 2013
Photos: AKFisher
PostPosted: Thu Sep 26, 2019 4:39 pm    Post subject: Reply with quote
There is about 400 feet of Dyneema spliced into a bout 10 foot of nylon line as a snubber which is linked to about 20 foot of chain that is hooked to a swivel and then the anchor.
AKFisher
City/Region: Venice
C-Dory Year: 2013
Photos: AKFisher
PostPosted: Thu Sep 26, 2019 8:56 pm    Post subject: Reply with quote
Update to the break down of the complete rode:
Lonestar GX-2 winch. This winch is holding 380' of Dyneema, 12' of nylon and about 30' of chain, for a total 420 feet of rode
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Thu Sep 26, 2019 9:22 pm    Post subject: Re: Installed a Lone Star GX2 anchor winch Reply with quote
"No more having to walk up to the bow and drop or raise anchor".
How are you going to keep it from loading up on one end or the other? Guy in Palmer fix you up? Nice winch!!
Thumbs Up Beer
bridma
City/Region: Comox
Vessel Name: Nomad
Photos: Nomad
PostPosted: Thu Sep 26, 2019 9:40 pm    Post subject: Reply with quote
When I bought my boat, the chain was attached to a swivel and the swivel to the anchor. I changed that immediately to....the chain to the swivel, the other end of the swivel to 3 links of chain, the other end of the 3 links to a shackle, then the shackle to the anchor.
My local chandler showed me a drawer full of bent and failed swivels that had been attached directly to the anchor. When there is side tension (pull) on the swivel it becomes the weakest link in your ground tackle.
Martin.
AKFisher
City/Region: Venice
C-Dory Year: 2013
Photos: AKFisher
PostPosted: Thu Sep 26, 2019 9:54 pm    Post subject: Reply with quote
tsturm...I was told that with how far back it is mounted that it should load evenly. It was recommended to go to a deep spot to let it out and rewind it. This would allow the line to releave any twist and tighten the line on the spool. It should also aid in loading up the spool evenly.
I am open to any other recommendations
PostPosted: Fri Sep 27, 2019 1:17 am    Post subject: Reply with quote
"My local chandler showed me a drawer full of bent and failed swivels that had been attached directly to the anchor. When there is side tension (pull) on the swivel it becomes the weakest link in your ground tackle."
I second what Martin says about the swivel. When I went to the new anchor (Rocna) several years ago, I was going to put on a new swivel. After considerable research bot here and other sites, and talking with many experienced anchoring folks, I opted to leave the swivel out and get a good shackle, seized on well and have not regretted that since, with somewhere over a hundred nights on anchor since and no issues. The Rocna always comes up right.
tsturm
Photos: JMR-TOO
PostPosted: Fri Sep 27, 2019 9:06 am    Post subject: Reply with quote
Great, no recommendations just questions. I have been looking at that winch for a couple years.
Let us know how it works!
Beer
C-Wolfe
Vessel Name: C-Wolfe
Photos: C-Wolfe
PostPosted: Wed Jan 26, 2022 6:04 pm    Post subject: Reply with quote
AKFisher, Now that you had a bit of time to use it, how are you liking that Lone Star GX2 and the setup you got? Did you purchase the unit in Palmer?
Stephan B.
C-Wolfe 22 C-Dory cruiser 2020- present
AKFisher
City/Region: Venice
C-Dory Year: 2013
Photos: AKFisher
PostPosted: Wed Jan 26, 2022 7:59 pm    Post subject: Reply with quote
Everything worked extremely well. I have anchored as deep as 315 and I spent many nights on the hook. Never had the thermal fuse pop. It has been worth the money without a doubt. I purchased it and had it installed by Ashbreeze Boat Works in Anchorage. They did great work and kept all wiring and set up very clean looking.
Page generation time: 0.0508s (PHP: 64% - SQL: 36%) - SQL queries: 30 - GZIP disabled - Debug on
