Motor configuration questions
Two Happy
City/Region: Bothell
PostPosted: Tue Jul 30, 2019 8:18 pm    Post subject: Motor configuration questions Reply with quote
Hello All, We are considering a 22 cruiser and want to know if a 40 hp and 30 hp configuration will push the boat around. We prefer to travel at under 10 knots so we think we would need a much smaller motor than a 40 horse for 5-10 knot cruising but want to be able to kick it up to 20 knots if need be. Would the weight differences cause the boat to be unstable? Primary waters would be San Juans into Canadian North. Or can one primarily cruise with twin forties at low speed without damaging the motors? We have read a 9.9 kicker is of no use in heavy seas so we don't want to rely on a kicker. Thanks!
Happy Travels
MikeR
City/Region: Mill Creek
C-Dory Year: 2016
Photos: MikeR
PostPosted: Tue Jul 30, 2019 8:44 pm    Post subject: Reply with quote
Hmmm, interesting idea, but not sure I follow? Why would cruising around with twin 40s be worse for the engines than cruising around with a 40 + 30? There are many who slow cruise with twin 40s, twin 50s, twin 60s, and singles from 75-115 hp, engines with multiple thousand hours of such cruising. I'm sure those with the twin 40s will chime in! Some downsides that come to mind for the 40 + 30 combo - probably lower alternator amperage on the 30 for charging batteries while cruising, and then of course the resale value - aesthetics is one of the coolest things about "twins" (some will argue otherwise) Very Happy
-Mike
22' C-Dory Cruiser (2016)
16' C-Dory Angler (1989)
10' C-Dory Row Boat (1995)
PostPosted: Tue Jul 30, 2019 11:31 pm    Post subject: Reply with quote
I don't see the reason--a 40 at low speed will do fine--just alternate engines to get equal number of hours. On the other hand, a 9.9 hp will certainly push the boat at hull speed--and putting a 20 on it will do very little more.
Either way, you are paying for maintenance on two motors. The fuel burned on a 30 and 40 at the same speed will be so close that it probably will not noticed.
If you have 30 and 40, there will be a little difference in throttle to get the boat balanced when going on a plane--may be a bit trickey, where the two 40's will have about the same thrust. Weight should not be an issue--just move a battery if it is.
PostPosted: Wed Jul 31, 2019 2:59 am    Post subject: Reply with quote
I don't think there is any advantage to the 30-40 setup vs twin 40's, and as Bob mentioned it would take differential throttle settings to maintain a strait ahead course. I slow cruse with twin 40's quite a bit, usually with both running, but at times on a single also. Either one works, but the throttle speed (RPM's) are lower when running the twins than it takes if running a single to maintain the same speed.
South of Heaven
City/Region: Sharon
Photos: Blue Water
PostPosted: Wed Jul 31, 2019 6:31 am    Post subject: Reply with quote
Get twin 40s. Many of C Brats have that setup and love it. No need to reinvent the wheel!
<><><> Jason <><><>
ken35216
City/Region: Destin, Florida
C-Dory Year: 2017
Vessel Name: Lady Onyx
Photos: ken35216
PostPosted: Wed Jul 31, 2019 10:14 am    Post subject: Reply with quote
What is this "slow cruise" and " under 10 knots" nonsense? I don't like going too fast but these boats are made to plane and that's the reason I bought mine. They have the perfect cruising speed for me (18-22 mph) Cool
2007 25 Cruiser 150 Suzuki (2013-2016)
2017 25 Cruiser 200 Yamaha (2017-present)
Two Happy
PostPosted: Wed Jul 31, 2019 11:38 am    Post subject: Thanks for the info - I meant a 40/ 20 configuration Reply with quote
However, it appears there is no good reason to change the 40/40, especially when taking in all the well thought out considerations posted here. We are looking at a 22 cruiser that has a 90 hp but then that meant us having to put a kicker on. We have read a 9.9 kicker will not push the boat in a four knot and above current should we have an emergency with the one larger motor. The 40/40 makes a lot of sense since a 40 will push the boat in an emergency. Does anyone have experience with a 9.9 kicker in 4 knot and above current? And with regards to speed- to each their own. As for us, we prefer to cruise at low speeds but have the option to kick it up when needed and so that is why I posted the question about efficiency and possibly damaging the motors if we want to cruise 90 percent of the time at 5-10 knots max.
BillE
City/Region: Nashville
State or Province: TN
Vessel Name: TBD
Photos: BillE
PostPosted: Wed Jul 31, 2019 12:46 pm    Post subject: Reply with quote
Your under ten knots will likely be done at about half of that. Above that you will either be on plane in the low teens or plowing a huge wake around 10mph.
The 9.9 will be plenty to push a 22 at slow speeds but I do think that you will prefer cruising with your main engine. I would recommend that anyone wanting to slow cruise on a C-Dory try doing just that on one before purchase. These are not at their best cruising that slow, imo, and I find mine much more enjoyable in the mid-teens.
I used to enjoy poking along in my 22' sailboat with the kicker at around 5mph, but I had a keel that kept me tracking straight and a rudder that gave great control. Both are missing on a C-Dory!
Bill & Sherry C-25 sold 2020, next?
Hunkydory
State or Province: WY
Vessel Name: Hunkydory
PostPosted: Wed Jul 31, 2019 1:27 pm    Post subject: Reply with quote
Two Happy, I’ve run many thousands of miles at displacement speed switching back & forth between our twin 40’s as Bob suggested. I now have about 2365 hours on the twin 40’s & they would be over 4000 hours apiece if both had been run all the time instead of switching back & forth between. Most of these slow cruising miles have been done at between 6 & 7mph with both motors down & the non running motor in neutral. The two legs in the water making boat control & ease of steering very good. At between 6 & 7 mph I average about 7 mpg on one motor & 3.5 on plane with both running. I normally cruise with a very heavy boat set up up for long range cruising. There are many good reasons for slow speed cruising in a CD22 with fuel range extension between fueling my number one reason, but for those of us who are into enjoying the cruise not just getting some place it’s an enjoyable alternative. The even better part is if needed or wanted both motors can be turned on, power upped & much higher speeds can be obtained & held. I think you will eventually find you go back & forth between displacement & higher speeds & enjoy the advantages of both. I will be starting another thread on why I’m now replacing my 20 year old Honda 40’s with new Honda 60’s.
ken35216
C-Dory Year: 2017
Photos: ken35216
PostPosted: Wed Jul 31, 2019 4:52 pm    Post subject: Reply with quote
My Garmin autopilot does not work as well going slow either. Works fantastic on a plane.
PostPosted: Wed Jul 31, 2019 8:26 pm    Post subject: Reply with quote
Auto Pilot and slow cruise Thumbs Up Thumbs Up Love
Hunkydory
PostPosted: Wed Jul 31, 2019 9:39 pm    Post subject: Reply with quote
[quote="hardee"]
Harvey, yes the auto pilot is what makes the slow cruising work so well & my auto pilot is a now way out of date Raymarine S1000 that I installed in 2005. We have had many 16 hour slow cruise days & some even more with full enjoyment. One I remember well was from Skagway, Alaska to Hoonah & only the last 15 miles of 115 miles done on plane. Watching whales & other wildlife & the scenery 360 degrees around the boat while not being tied to the helm with the auto pilot doing the work encompasses many of our better days on the water.
PostPosted: Wed Jul 31, 2019 11:15 pm    Post subject: Reply with quote
Two Happy:
The efficiency of a kicker of 9.9 or 8 hp is determined by the size and pitch of the prop. Most 8 and 9.9 hp outboards (The 9,9 configuration is only because some lakes only allow motors less than 10 hp). have small prop diameters and a large pitch--which is fine what most folks do with these motors--they are used on small boats; dinghies or aluminum skiffs.
An 8 or 9.9 hp motor will push the C dory 22 at hull speed if properly equipped with a "big foot" or "sail drive" outboard--with a low pitch. An example I use often was my father's 26 foot sail boat--same hull form as a C Dory--arc bottom, no dead rise, and hard chine. Weight and windage were equal to a c Dory 25 or more- was easily driven to 6 knots with a 1932 5 hp Johnson outboard. So it is not the HP, but the way it is propped.
As to the 4 knot current--lets say that the kicker will push the boat at 5 to 6 knots, then you are making 1 to 2 knots over the bottom. I have been there in our Cal 46, where I had to get thru a pass, and the current was running over 6 knots, and the boat was capable of 8 knots under power. (we had to pick up our dog after surgery) Any boat is easily driven to the theoretical hull speed: sq root water line length x the constant 1.34. Lets say the C Dory22 has a LWL of 19' and the formula gives a speed of 5.8 knots. So if you can make 5.8 knots--you will be making 1.8 knots across the bottom into a 4 knot current. I see a kicker as a way of getting some steerage way on the boat, and getting to a safe place, where you can anchor until you sort out the issue with the main engine. We use a dinghy motor as a kicker--3.5 hp. Never worry about what speed, or going against a 4 knot current (even though we have done a lot of boating in the PNW). It would take a set of very unusual circumstances where you were forced to go against a 4 knot current. Most would go with the current and find a safe anchorage.
On the other hand, modern outboard motors are very reliable. I have been running outboards for slightly over 70 years. I have had one failure; there I still was able to get on to my destination under reduced power. That one failure was the oil pump on an early Fitch technology Evinrude 90 hp (2 stroke, direct oil injection to the crank shaft 1996 vintage). Looking at the thousands of miles the C Dory's go there are a hand full of stories of motor failure--one was a larger Honda where the thrust bearing gave out which lead to catastrophic failure. Good maintenance makes the modern outboard about as reliable as modern cars.
If you feel safer with twin motors--then go for that configuration. The most common problem with outboards is bad fuel. When you have a kicker, it is wise to have a separate fuel supply and separate starting mode--either a separate battery or hand start.
Page generation time: 0.0555s (PHP: 68% - SQL: 32%) - SQL queries: 30 - GZIP disabled - Debug on
