Cooler Storage on the Roof
kaelc
City/Region: Saanich
Vessel Name: Island Magic
Photos: Stil-Afloat
PostPosted: Fri Jul 12, 2019 10:38 am    Post subject: Cooler Storage on the Roof Reply with quote
Any tips for putting big fish coolers on the roof? I'm thinking of putting a little padding and then tieing both handles down. Hope to catch our limit this weekend off Bamfield on Vancouver Island.
PostPosted: Fri Jul 12, 2019 11:53 am    Post subject: Reply with quote
Some of the early modern 25's had a fairly thin laminate on the middle section --my 2003, flexed with my weight standing on it. My 2007 does not, and seems substantial. Air conditioners weight 90# (I will probably re-inforce and level the top, but should be able to handle the weight.
Some have made racks, which distribute the weight to the hand rails, for heavy loads. There will be some minor handling differences with 100 plus lbs up there, with slight change of center of gravity.
I would put a light weight back packing foam pad--such as we get at WallMart for $5. under the cooler.
Most keep the coolers in the cockpit or fashion a rack over the splash well for a cooler.
Lashing the handles to the hand rails would be the normal point to secure. I would have one forward and one aft (being the uprights of the railing) to keep the cooler from sliding.
What weight do you aticipate? Some coolers full of fish can weigh in the 400# category--and that would make a difference as to where to put it.
PostPosted: Fri Jul 12, 2019 1:50 pm    Post subject: Reply with quote
...What weight do you aticipate? Some coolers full of fish can weigh in the 400# category--and that would make a difference as to where to put it.
You'd have to have some method of getting a heavy cooler like that on the roof in the first place.
PostPosted: Fri Jul 12, 2019 3:58 pm    Post subject: Reply with quote
Is this what you expect to be carrying in terms of weight, plus ice?
(From your album.)
"First Fish on the boat 49,33 and 15" lbs
kaelc
Photos: Stil-Afloat
PostPosted: Sat Aug 03, 2019 3:05 pm    Post subject: Reply with quote
Well, we only managed one small halibut a "chicken" as we called it but 15 springs and coho and a couple rockfish. Cooler went on the roof nicely empty, put on from the dock it was pretty easy and second cooler went into the cockpit filled with ice and was replaced by fish as fast as it melted but was a pain to dance around. Didn't touch the second big cooler on the roof. Still debating throwing roof racks on, but between the dingy and solar plans, it is tough to decide what to do on so versatile a boat.
PostPosted: Sat Aug 03, 2019 5:00 pm    Post subject: Reply with quote
Sounds like you need to build a rack up over the engine splash well to get the cooler up off the floor and keep it off the roof as well. This also makes it conveniently accessible. I did this and found it worked great! Only big drawback is the extra weight near the transom, but, as you'll remember, everything on a boat is the result of a whole bunch of compromises. Is there anything inside the cabin you could move forward a bit to balance things out?
kaelc
Photos: Stil-Afloat
PostPosted: Wed Aug 07, 2019 9:35 am    Post subject: Reply with quote
Yeah I think we may need to. I think there a build thread and pictures that I have seen of this but I can't seem to find it? I browsed a few dozen pictures of yours as well.
PostPosted: Wed Aug 07, 2019 1:20 pm    Post subject: Reply with quote
kaelc-
Most cooler racks are made from stainless pipe life rail fittings, which adapt well to the task, but there are a great variety of materials used and designs constructed.
You can see the one I did below, then click below it for further views, and, hopefully, some other C-Brats will also offer references to theirs.
Good Luck! Joe. Teeth Thumbs Up
More photos:
http://www.c-brats.com/modules.php?set_albumName=SeaWolf&id=IM003306&op=modload&name=gallery&file=index&include=view_photo.php
PostPosted: Thu Sep 12, 2019 3:24 am    Post subject: Reply with quote
On SleepyC we have availability of 2 coolers, on fits on behind (aft) of the bar and hangs over the splash well and then one that hangs forward of the bar over the aft part of the cockpit, but not on the sole.
kaelc
Photos: Stil-Afloat
PostPosted: Thu Sep 12, 2019 2:09 pm    Post subject: Reply with quote
Sea Wolf wrote:
kaelc-
More photos:
Thanks Joe and Harvey. Really appreciate the shares. Planning to get the boat to Mayne Island to stay at a friends cabin but may take the Ferry due to logitics and weather Sad. Thanks again
bridma
City/Region: Comox
Vessel Name: Nomad
Photos: Nomad
PostPosted: Thu Sep 12, 2019 4:10 pm    Post subject: Reply with quote
Go fishing with me. You won't catch diddly squat and a cooler doesn't enter the equation!
Martin.
kaelc
Photos: Stil-Afloat
PostPosted: Fri Sep 13, 2019 12:46 pm    Post subject: Reply with quote
bridma wrote:
Go fishing with me. You won't catch diddly squat and a cooler doesn't enter the equation! Martin.
There is some great fishing off Kitty Colman beach at the Hump and the Denman Hornby area and you are not far from Browns Bay and so much closer to Nootka and the North Island! My brother and his friends have always done amazing. They even went and got 104 Tuna a couple of weeks ago.
Would love to go fishing with you but I don't know all the techniques for the area. I grew up in Courtenay/Comox but didn't get serious into fishing til I moved to Victoria. Winter springs are supposed to be on Plugs trolling fast if I remember correctly!
gastone
PostPosted: Tue Oct 15, 2019 8:34 am    Post subject: Reply with quote
Great pic!
Teufelshunde
City/Region: Sebastopol
Vessel Name: Fish Wisher
Photos: Fishwisher
PostPosted: Wed Oct 16, 2019 12:17 am    Post subject: Reply with quote
I purchased an Elkton Outdoors Insulated Fish Cooler Bag (kill bag) on Amazon for $109 for the 40 inch they also make a 60 inch bag for $139.
I’m going to hang it most likely under the rail out of the way so there is no need for a bulky cooler taking up deck space. Once installed I’ll post a picture.
What ever you are, be a good one 🇺🇸
kaelc
Photos: Stil-Afloat
PostPosted: Wed Oct 16, 2019 11:49 am    Post subject: Reply with quote
Thanks! Would love a review!
Page generation time: 0.1362s (PHP: 77% - SQL: 23%) - SQL queries: 33 - GZIP disabled - Debug on
