propellers for 25 c-dory with twin 90 hondas
Post new topic   Reply to topic    The C-Brats Forum Index -> Propellers
dwilks
Vessel Name: C-Yalater
PostPosted: Sat Apr 20, 2019 7:56 pm    Post subject: propellers for 25 c-dory with twin 90 hondas Reply with quote
bent my aluminum props and thinking of buying stainless
Are there any noticeable advantages with stainless props
I have a 25 C-dory with twin honda 90's
We operate out of Prince William Sound and travel pretty far for fishing
Thanks for any input
PostPosted: Sat Apr 20, 2019 10:09 pm    Post subject: Reply with quote
Compared to aluminum props Stainless steel are
stronger, harder to bend, slicker (more polished), easier to make in more sophisticated shapes, more expensive, and will give you (properly selected) faster speeds, more gas mileage, less corrosion, and higher repair bills when they're damaged.
Aluminum props are cheaper, slower, offer less gas mileage, cheaper to repair and replace, corrode easier, and less likely to be stolen off your boat/motor.
Best of both worlds:
Get stainless prop(s) for normal use, and aluminum for back-ups and when you're operating in shallow water.
My 2 cents!!
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Sat Apr 20, 2019 11:41 pm    Post subject: Reply with quote
I have 13.5"D x 15"P aluminum 3-blade props on my CD25 with twin Yami 80's, they're essentially perfect for the various loads I carry. I think i could go with 16"P, but not 17's with same diameter. You need to hear from those with your same engine setup. Hope this helps.
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
PostPosted: Sun Apr 21, 2019 11:13 pm    Post subject: Reply with quote
To be honest, I never really noticed a difference running SS vs. Aluminum on a prior boat, a SeaRay 268 Sundancer with single 454 Merc. But regarding your bent Aluminum Props. Had that been a SS prop, what kind of damage might it have done to your lower unit? No thanks. I'd just as soon stick with something cheaper that breaks easier than the more expensive part of my drive gear! Colby
Post new topic   Reply to topic    The C-Brats Forum Index -> Propellers All times are GMT - 5 Hours
Page generation time: 0.0363s (PHP: 60% - SQL: 40%) - SQL queries: 22 - GZIP disabled - Debug on
