cattlejack
Joined: 22 Jul 2008 Posts: 46 City/Region: Leonardtown
State or Province: MD
Posted: Sat Feb 23, 2019 6:09 pm Post subject: What's better? |
What's better? 2004 Honda 90 with only 190 hours or a 2004 Honda 90 with 1500 hour on it? |
CaptMac
Joined: 01 Mar 2005 Posts: 225 City/Region: Amelia Island / Jacksonville
Photos: Blue Manatee
Posted: Sat Feb 23, 2019 6:41 pm Post subject: honda 90 |
i have a 2000 honda 90 with over 3,000 hours and so im partial to the honda outboards but believe most 4-strokes nowadays are dependable with proper use and maintenance.
which one is better depends upon at minimum a visual inspection under the cowling for signs of corrosion, maybe a compression test of the cylinders and a trial run.
fresh or salt water use? flushed after each use if saltwater? what size boat have they been pushing? any maintenance records?
good luck with your selection!
_________________ Capt Mac Daniel
Flounder Gigging Charters
Amelia Island, Florida 32034
http://www.floundergigging.com
"The Adventure of a Night-time"
904-556-0230 Cell/Text |
South of Heaven
Photos: Blue Water
Posted: Sat Feb 23, 2019 6:56 pm Post subject: |
We need more info Jack. _________________ <><><> Jason <><><>
Joined: 02 Nov 2003 Posts: 20822 City/Region: Pensacola
Posted: Sat Feb 23, 2019 8:25 pm Post subject: |
Both have carburetors. I would rather have the low hour- 190 hrs engine.
The high hour engines like CaptMac, are in good shape because they are probably run at least several times a week, if not every day in charter service.
When you are buying a used engine, you don't really know how it was cared for. If only in fresh water--and documented--that is a plus.
Salt water--was it really flushed each time? A friend of mine bought a Honda was told it was flushed each time--had low 800's hours--and the cooling system was destroyed by corrosions--he had to buy a new engine.
Has the engine oil been changed each year, even thought there were only 20 hours use each year? If the engine was not used for a few years, was it properly fogged, and the oil / gear lube changed just before the storage? _________________ Bob Austin
