26 Venture
Z50
City/Region: Alachua
C-Dory Year: 2018
Vessel Name: Beach Donkey
Photos: Beach Donkey
PostPosted: Wed Jan 09, 2019 4:39 pm    Post subject: 26 Venture Reply with quote
New to the group and interested in purchasing a venture 26. My local dealership has a 23 that I can sea trial. How would the ride of the 23 compare to the 26. If I like the 23 how much better of a ride would the 26 be? I'm trying to get a baseline before I order a 26 Thanks in advance
PostPosted: Wed Jan 09, 2019 5:18 pm    Post subject: Reply with quote
In my opinion the 26 will have a considerably better ride than the 23. As the 25 is its better than the 22. But all of the C Dory line, benefit from both Trim Tabs and outboard foils (Permatrim is the preferred brand). These will push the bow down when needed going into chop. Remember that all of the C Dorys are semi Dorys--with very low dead rise. They will not ride like a deep V....except the Tom Cat-255 which will ride very well in chop up to about 2 to perhaps 3'--depending on the Period. I have run the Tom Cat along side a Regulator 26 and in 2.5' chop and the rides seemed. comparable. With the monohulls you will slow down. However the boats plane at far lower speeds than deeper V's.
We find that any of the C Dory work well in FL--in giving sun protection. But air conditioning is a necessity for overnight use, especially in S. Florida--and the entire state during the summers. With windows open, there is plenty of air flow when running.
South of Heaven
City/Region: Sharon
Photos: Blue Water
PostPosted: Thu Jan 10, 2019 7:22 am    Post subject: Reply with quote
Z50: If you're buying new and your budget can allow it then buy the 26!
<><><> Jason <><><>
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Thu Jan 10, 2019 8:05 am    Post subject: cd-23 Reply with quote
We have the cc23 venture with a 115 ct merc With the trim tabs down and engine tucked in we keep up with our boat club in 2-3 ft out in the gulf of Mexico . doing about 19-21 mph With that said its ok but it likes smoother water . I looked at a venture 26 and drove it .It weighs about 1000 lb more then the cd23 venture so it will drive better in bigger seas .The 26 was not as agile as the 23 .We do tubing with our Grandkids and the 23 works more like a runabout . These boats are not meant to do 30-40 mph in 4 ft seas they are semi dory hulls that like slower speeds . What I enjoy about these boats is I can go in 1-2 ft. of water and not run aground .Planes off at 10-12 mph and gets 0ver 4mpg .Also I don't have to see my Dermatologist as often with a hardtop .Jim
Foggy
C-Dory Year: 2014
Photos: W B Nod
PostPosted: Thu Jan 10, 2019 5:51 pm    Post subject: Reply with quote
I had a CD 26 Venture not long ago. I liked it. It was the "biggest" C Dory, save
the cat version, but realize it is not a "big boat".
Remember, on the water, "length is ride".
Got ???'s. PM me. It's still early but the sundowners are going' down easy...
Aye.
Foggy
C-Dory Year: 2014
Photos: W B Nod
PostPosted: Thu Jan 10, 2019 6:17 pm    Post subject: Reply with quote
So, now I'm here I'll spend a minute on deep "V"s since mentioned above.
If you want to go "fast" in seas over 3' or so, you're going to appreciate a
deep V hull.
I had a 28' Saber Offshore deep V. It was powerful: twin 415HP V8s
lettering her rip 80mph or so in appropriate conditions. The best was
going 45 - 55 mph in 3+ footers "on top" (of the waves) while watching
others slog through it with bow spray bouncing along getting sea sick.
Speed changes you. But it's not for everyone. And this boat drew a
different following then CBrats.
Bottom line is if you want speed stay away from semi-displacement,
partial V'd with flat aft hulls, go for full deep V'd hull with lots of muscle
and forget about mpg.
Aye.
Grandpa used to say, "You gotta get your hair blown back a few times
to know you're alive."
Back to the sundowners...
PostPosted: Thu Jan 10, 2019 7:25 pm    Post subject: Reply with quote
Although I agree with almost all of what Foggy says here, I would not call a C Dory a "semi Displacement" boat. The C Dory has very low dead rise, and reverse chines to give even more lift--and is definitely a planing boat designed for low speed planing, but also runs well up to the 30 knot speed. Some of the fastest early boats are almost fully flat bottom. For example the early hydroplanes. I also used to drive a flat bottom 18' mahogany runabout powered with a Paxton supercharged Ford 312 engine in 1957 which would easily reach 75 mph. (I was told that the hull was designed by Jack Davidson of Sanger fame.) However these boats required smooth water.
forrest
City/Region: Chehalis
Vessel Name: Long Story
Photos: Long Story
PostPosted: Thu Jan 10, 2019 10:34 pm    Post subject: Reply with quote
If you are a fisherman the Cdory line will give you a much more stable fishing platform without all the rocking and rolling a deep V gives you.
Foggy
C-Dory Year: 2014
Photos: W B Nod
PostPosted: Fri Jan 11, 2019 8:47 am    Post subject: Reply with quote
Grandpa used to say, "You can't have everything."
Aye.
san juanderer
City/Region: Stanwood
C-Dory Year: 1990
PostPosted: Fri Jan 11, 2019 10:46 am    Post subject: Reply with quote
All boats have compromising qualities. Depending on what your use is, and the local waters you travel, choices are made by individuals with there "own" priority of important factors. Everyone makes there own choice.
Cdory 22 Angler
Rosborough RF246 (sold)
Commander 30 Sportfish (sold)
Olympic 26 XL (sold)
Glassply 19 (sold)
Olympic 23 (sold)
Bayliner 38 Motoryacht (sold)
Olympic 20 (sold)
Fiberform 16 (sold)
Olympic 18 (sold)
Foggy
C-Dory Year: 2014
Photos: W B Nod
PostPosted: Fri Jan 11, 2019 4:48 pm    Post subject: Reply with quote
No disrespect intended here.
You must have traveled, changed use and priorities and compromised a fair
amount to have made the choices for the lineage of boats you include in your
post. And I understand. Tastes, priorities, usage change.
My therapist has mentioned the same to me about relationships...
Aye.
Grandpa used to say, "If you can, try'em before you buy'em."
san juanderer
C-Dory Year: 1990
PostPosted: Sat Jan 12, 2019 12:06 am    Post subject: Reply with quote
You are exactly correct;
For many years I fished several days a week out of the Edmonds Marina private garages above the live bait shop. Those facilities have been long gone. Boat had to fit into the garage and pulled by hand to the private sling launcher.
For many years I kept a boat out near Neah Bay on the NW tip of the WA coast. Traveled every other weekend to fish out in the ocean. Different boat for big waters, and to fit into someone's pole building.
For many years I did the yacht thing, two full bedrooms and two full bathrooms. Traveled with all the comforts of the home, 20 gph fuel burn when fuel costs were $ 1.00 per gallon of diesel. Hard to fish.
Sold my home, moved to the area of the best cruising and boating on the US west coast. Sitting here in my living room, I see 5 of the San Juan Islands. Sold the large yacht, bought a smaller fishing kind of boat. Then added a wife. Boat situation changed. Had to have a " real " head ! And on and on.
Lives change, times change. I have truely enjoyed all the different rides (boats). The DW thinks I love boats more than her. No more to say.
Foggy
C-Dory Year: 2014
Photos: W B Nod
PostPosted: Sat Jan 12, 2019 7:43 am    Post subject: Reply with quote
We're all "on the way to Omaha". We just take different paths.
Aye.
Grandpa used to say, "The wise man speaks when he has
something to say; the fool when he has to say something."
Z50
C-Dory Year: 2018
PostPosted: Sun Jan 13, 2019 3:15 pm    Post subject: Reply with quote
just got back from sea trial on the 23. I really liked it. Very different coming from a cc bay boat. Not concerned about speed really. 30 is plenty fast. my only real concern would be the Florida heat in mid summer. Maybe a few fans and AC down the road. Think I will pull the trigger on the 26. Need storage ideas or shelves in the v berth.
South of Heaven
City/Region: Sharon
Photos: Blue Water
PostPosted: Sun Jan 13, 2019 3:32 pm    Post subject: Reply with quote
Nice!
Page generation time: 0.0374s (PHP: 75% - SQL: 25%) - SQL queries: 32 - GZIP disabled - Debug on
